Massey Ferguson 230. The little tractor that could not
   / Massey Ferguson 230. The little tractor that could not
The lift control valve is internal and it moves in one direction to let flow out of the lift cylinder and the other to allow pressurized oil out of the pump to the lift cylinder.
I thought that was the case. This is why i began removing the side inspection plate. MY concern is once i get in there and move the lever or fork, in theory will the levers begin to work agin?
If the only prob was a stuck valve.
   / Massey Ferguson 230. The little tractor that could not #12
As I said before, I'm not familiar with that particular model but in theory, if the valve is sticking you have to fix the cause of the sticking. Sometimes jiggling the control valve is enough; other times, not so. What does your shop manual say? Read the section that covers the lift hydraulics and see what's supposed to happen when you command the lift to drop.
If it's stuck in the up position, have you tried standing on the lower lift arms with the control lever in the drop position? As others have stated, the 3 point drops by gravity so the more weight the greater the down force.
I live in Western Montana and it's pretty tough to diagnose a problem in Georgia from here. I'm more than willing to help but you have to take some action too. These tractors aren't an F-22 to the Space Shuttle and these problems are relatively simple to solve once you understand how the lift control system works and you do a few diagnostics so don't be afraid to try. . If you have a digital camera, take pictures of everything you do so you can put everything back together.
You might move this thread to the Massey Ferguson section for Vintage Tractors . You'll have a better chance of finding someone who has this model and can help you.
   / Massey Ferguson 230. The little tractor that could not #13
Im band new to the tractor world. I recently bought a home that came with a Massey Ferguson 230. I plan to use this to cut the large yard. I have started and driven the tractor but can not get the 3 point to drop or move.
I reviewed the manuals and see the there is an inspection plate on the right hand side where the dip stick is at. I have started removal of this but have no clue what todo once I get it off. One of the bolts is currently stuck. I have been spraying with PB Blaster.
I'll try to get some picture posted.
Any help with this would be greatly appreciated.
Are you sure the draft control lever, next to thr 3 point hiych raise and lower control is set in right place
Have you tried moving it up and down
I still have had no luck getting the side Hydraulics cover off can anyone tell me if the bolt around the 2 o'clock position should be removed and what type of Bolt it should be I will attach pictures mine looks like a big rusted.
   / Massey Ferguson 230. The little tractor that could not #16
Where is the lever to raise and lower the hitch?
Please help:shocked:
The draft control and hydraulics lever should be seen from this picture
   / Massey Ferguson 230. The little tractor that could not #19
From that picture, your draft control lever is in the upper position. Move both levers as far forward as you can then stand on the lower lift arms and see if they move down.
I have put the levers in every possible position and had two people standing on the arms. They dont budge.
I was hoping to remove the side cover to insure the levers are pushing and pulling on the pump control lever
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
