New L2501 seems really loud! Suggestions?
/ New L2501 seems really loud! Suggestions?
My L2501DT is not quite as loud as the video. I would ask the dealer if he could stop by your house/place one day when he is nearby and take a listen just to be sure. This is my first diesel and it is louder than my old Ford 8N that has a newer muffler on it. I use the full cover type of headphones (like the one's for shooting guns) that has a built in radio and just turn it on when riding the diesel. The first time I used my 5' finishing mower, good Lord...I thought I was completely deaf when I finished. Never again without hearing protecting. Three blades whirring close behind is a lot more noise than the diesel. :eek:
Yes those old 8N run like a sewing machine. I have a Ford Golden Jubilee. Sounds like a car engine when idled. Real smooth!
Thank you for the info
/ New L2501 seems really loud! Suggestions? #22
ProjectKing,
I have a L3901DT and I find that around the PTO speed there is a drone sound. If I run the engine at that speed I find that I can still hear the drone when I go inside. I can't remember if it is just below or just above the PTO speed. I wear ear plugs all the time when using the tractor.
/ New L2501 seems really loud! Suggestions? #23
Maybe Kubota is cutting back on noise dampening.
If by cutting back you mean "none", then yes. The standard L models don't have any of this.
/ New L2501 seems really loud! Suggestions? #24
Hearing damage is cumulative.
I suggest ear muffs or ear plugs. I wear one or the other when operating my tractor .
good advice!
I'll have to compare to my L3830 and maybe add similar materials to the L2501
/ New L2501 seems really loud! Suggestions? #26
Ok so some particulars. This was inside my garage with the garage door in front of it open. The other 2 doors were shut. Its crappy out. Occasionally raining sideways.
Kubota L3301 Engine Noise - YouTube
@ startup and lowest RPM it measured: 71dB avg
@1500rpm 80dB avg
@2000rpm and PTO speed 88dB avg
Those dB ratings were taking via iPhone so take them for what theyre worth. Comparative to themselves.
The ambient dB with the rain/door open was 54dB avg
@1500rpm 80dB avg
Excellent video sir! I really appreciate you doing this. Your certainly sounds quieter than mine. And the dB measurements support that.
Your tractor is a L3301 correct?
/ New L2501 seems really loud! Suggestions? #28
Correct.
Hours are visible on the dash. Engine was still not up to full operating temp but had been running a few mins prior to vid.
If its louder than that....have you checked all your fluid levels?
--edit--
Mine also has a full tank of winterized offroad diesel with Amsoil injector cleaner/conditioner
/ New L2501 seems really loud! Suggestions? #29
A L3301 is going to have the tier 4 emissions DPF on it that will act as a bit of a muffler that a L2501 won't have.
2012 HEIL (A60736)
2012 HEIL (A60736)
set of 4 tractor trailer tires Roadforce (A61307)
set of 4 tractor...
500BBL WHEELED...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2013 CAT 950K WHEEL LOADER (A60736)
2013 CAT 950K...
2004 CATERPILLAR 416D BACKHOE (A59823)
2004 CATERPILLAR...
