Wagtail
Super Star Member
- Joined
- Jan 15, 2013
- Messages
- 13,867
- Location
- St Helens, Tasmania, Australia
- Tractor
- JD 4105 / JD Z355E (48" deck)
Intermittent faults/problems are the worst!
6 months ago (my Autumn) I was happily chain harrowing a fairly flat paddock, HST in Low, revs at 2000 and I'd been at it for about 30 minutes. I'd filled the diesel in the tractor prior to the task. The FEL was raised for visibility. About 380 hours on the rig and all maintenance (50 hour oil & grease) done at the required time... when the tractor just shut down. The battery & engine lights came on as the engine 'withered' away like one of those safety switches would do. I tried to re-start = no joy.
Bugger.
Key off, I put it in Neutral, set the brake and dropped the revs. Hopped off and checked the fuel bowl (red disk at the bottom) then checked the tractor over for, well, anything. Nothing obvious. So I hopped back on and tried starting it again and, after a few turnovers, it fired back up again as if nothing had happened. OK, back to work... for about 10 minutes and the same thing happened. I turned it off, revs down, brake on, Neutral, count to 10 and re-start... It fires back up again and I'm able to finish the job.
Once or twice again it would do this over the next month. Sometimes in Low and sometimes in High, usually when I give it just a wee bit more acceleration on the FWD pedal.
So I reckoned that I was close enough to the 400 Hour maintenance period. I changed the oil & filter and the fuel filter. Did my full hydraulic oil & filter change. Greased everything and inspected the safety interlocks... the 'seat' one was a bit wobbly so I duct taped it in solid! After all of this I took it out again and it eventually happened again. Then it hit me (inspiration, nothing physical... although I may have smacked myself upside the head)... The diesel tank cap! I backed it off and have had trouble free tractoring ever since. HUZZAH!!!
Until yesterday. It's back. :thumbdown:
The only thing I've done different is top up the diesel fuel... could it be the culprit or am I missing something?
Bugger.
