BX floor mat replacement
/ BX floor mat replacement #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Decided to give my BX a little spruce up after 330hrs of abuse. Try to treat her special so she stays around.:D
Replaced the original floor mat with the latest version. Much thicker is the new one. Here is before and after pics. Did also buy new push pins for securing it as the old ones were pretty much destroyed on removal of the old mat. Cleaned up underneath... surprised how much debris was trapped. Pic was after blowing off with air and before pressure wash. See p/n if you are interested.
Liking the mat but one thing it didn't solve even though it is thicker... is the possibility of slipping on the corners when climbing on/off. I have slipped a couple times stepping aboard in the past. So... today I put some anti-slip take on the side. Big improvement!
/ BX floor mat replacement #4
Good mod. I like the new mat look and the non-slip idea is good too
/ BX floor mat replacement #5
Go Google Specialty Repairs or Paul Short and look at some of his BX-25D mods. You'll like a few of them and he has done a LOT.
/ BX floor mat replacement #7
Looks nice, .. I had my floor boards and step Linexed when I got it. Been on there almost 6 years and has worked out well.
Dad would ALWAYS say "Give credit where credit is due" :thumbsup:
Yep, you are absolutely right and apologies for not specifically mentioning... went back and read my post and realized no credit was given. :ashamed: This was definitely where I got the inspiration. Thanks Paul!!!
/ BX floor mat replacement #9
What a beautiful and professional installation 4shorts did on this. I don't like the phrase "better than new" because not much is but this really is better than new.
/ BX floor mat replacement #10
Very nice! Does anyone know if a premium mat like this is available for the BX-25? I believe the layout is different than on the BX-25D, correct? Thanks ahead of time!
/ BX floor mat replacement #11
DAT pretty positive its the same mat. Even on the Kubota parts list site, doesn't list just BX25 they have the BX25DLB and DLB-1 listed.
The 25D had different rops, instrument cluster and backhoe I believe.
/ BX floor mat replacement #12
Sorry. Nothing like that for the BX25 :hissyfit:
/ BX floor mat replacement #13
Bummer.........thanks Paul, BTW your mods are top notch!
/ BX floor mat replacement #14
DAT, Paul is right, your brake is on the right instead of the left on the D model. Not saying it wouldnt work with a little modification and a left hole, your gamble. A year ago I looked and they where $125 but now $68 at messicks.....
/ BX floor mat replacement #15
Thank you. To make that mat fit on yours it would be cut up by the time you laid it on the machine. I had a deal made with my Kubota parts guy to try this mod way back. I have one of the very early BX25D and none of us knew for sure it would even work. Turns out it was an exact replacement so I was lucky.
Really like the new mat. Much thicker and tougher. Old one is so flimsy in comparison.
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2022 Case CX220E Hydraulic Excavator (A61572)
2022 Case CX220E...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
