Almond Huller
/ Almond Huller #1
OldMcDonald
Mainland, Orkney Islands.
None
Has anyone built their own?
A neighbour and I want to make a pto driven machine. There are lots of YouTube videos. Search almond huller or smallatrici mandorle to see the size of machine we need. They are between about 6 and 10 feet long, and mainly electric motor driven, but that is not a problem. There is limited other information on the net. All the info I can find relates to Italian or Greek machines and importing from there is very expensive.
As in the US, the bigger frowers (none in my vicinity) bulk their harvest to a co-op or private huller and sheller. My nearest is about 150 miles and we want to reduce the volume and weight of what is transported by removing hulls. Also, and this is important, want to keep the nutrients in the hulls on the property.
We are currently planting young trees so have a couple of years before the huller is needed, but want to make an early start on the project. There could be a third person also planting so we are looking at hulling the produce of about 1500/1700 trees to start with, possibly up to 2500. This means very small scale hullers are not appropriate.
Making the general frame seems straight forward (need to confirm the bar spacings) but the "beaters" inside will probably be the critical part, and I am having problems getting any info.
/ Almond Huller #3
I watched the video and several others. They all seem to work the same and you aren't shown the inside mechanism.
instead of mounting this on a three point hitch, any consideration to using a separate small gas motor and belt arrangement that can be pulled say by a UTV?
Take a small utility trailer and mount the mechanism on that. Tow it wherever needed. If it never needs to be moved, electric motor makes the most sense.
You have to build the same cage and internal mechanism anyway it appears. With the right width openings for the nuts you want to harvest.
It would be nice if one of those European brands would post their parts manual online with a schematic; then you can see at least what parts are needed, not that you have to do it exactly the same way. Part lapidary tumbler and part nut wacker.
I'm seriously considering putting in a pecan orchard on my small farm. Already have a large fruit orchard.
I wonder if pecans use them same style machine.
Pecan Cracking Machine - Pecan Shellers - Pecan Equipment has a different style of nut cracker but again,
no one is illustrating their internal features. No here's how it's made.
good luck on your quest for a less expensive alternative.
/ Almond Huller
Many thanks for your reply. I have tried many times to stop a lot of videos to see if I could find out what sort of "beater" arrangement is in there, but with no success. I do not know anybody (or anybody who knows anybody) in an almond growing area where these machines are likely to be used. If I ever find out the mechanism used I will post here. I had hoped somebody on TBN was at least familiar with them and could provide some info on what is inside the cage. I note that most of them are horizontal and not angled so that gravity could move the nuts from the filling box to the outlet - suggesting the possibility that the beaters might be in the form of a screw or auger.
The reason for pto preference is that we already have the tractors and pto shafts. My neighbour (five miles away) does not have electricity on his property and we presently share some equipment that is either carried on the tpl, or on a trailer - lift-on lift-off with tpl. It is no problem though to use a gas (petrol to us) motor instead. If the third person comes in (a mile) then having the huller as towable as you suggest is indeed an option worth considering.
I liked the video about the pecans - very effective, and whilst pricey, worth the money over a few years if you have a small commercial size orchard. Our intention is not to shell our own, but sell them to a processor in shell. One thing I am curious about is right at the beginning he talks about putting the nuts on the table after they are boiled and allowing them to dry. Is this a normal and necessary process? I have never heard of it before.
It also occurred to me that if somebody is building these pecan shellers, then presumably somebody is also building pecan hullers. If your harvest warrants that type of sheller, then it must surely warrant a huller? The almond ones are used for English Walnut hulling too. I have never worked out whether your Black Walnuts have a similar hull, despite having seen several videos of very small scale hullers for them.
I have looked into growing pecans because I believe the local climate will suit them, and I knew of a large plantation in Australia when I farmed there, with similar climate, but I have not been able to source any trees. Maybe the height puts off the southern europeans because they invariably harvest olives by climbing up ladders, and pecans are a wee bit tall for that. I keep my trees a little shorter in height and built a "cherry picker" type platform to fit in the tpl box. I take the tractor and box out to the olives and it is a quick job to reverse into a tree for the high branches. Finished harvesting 500 trees last week without needing a ladder.
/ Almond Huller #5
I have both, English and black walnut tree's... The English are "soft" shell, and the black are HARD shell, no comparison at all.
BTW, I also have Butternut tree's and they are hard shell too...
SR
/ Almond Huller
Sawyer Bob, No intentions of arguing, but do you say that your English walnuts have soft shells as in the soft shells of some almond varieties? English walnut shells are definitely hard, not that they need a lot of power to break them, but definitely "hard" in comparison to "soft" almond varieties.
I have no intention of shelling, so the hardness or otherwise of the shell is unimportant, I am only interested in hulling up to a few tons. The shelling will be done by the buyer.
/ Almond Huller
daugen, I have eventually found a video where you can see inside the cage. No measurements yet, but it will give me something to work on. ΚΑΡΥΔΙΑ ΑΠΟΦΛΙΩΤΗΣ - YouTube
They appear to be hulling English walnuts, but the principle is the same.
I know somebody in the UK who has recently bought a small plot and house between the neighbour who will be working on the project with me and myself - very convenient for the future. This new neighbour currently works for a firm who have made pistachio shelling machines, so they have a little bit of practical experience, and he has confirmed he will assist with our development plans for a machine. I will keep you informed of what we do because it might be suitable for your proposed pecans, or others like Sawyer Bob with different nuts.
/ Almond Huller #8
paddle wheels, simple paddle wheels like the tail of a beaver...and this time they are adding water to I assume flush away the small debris.
It all seems so crude and imprecise but sure better than doing them one at a time...
I don't understand why more of the broken shell doesn't get mixed in with the nut meat.
I wonder how much you have to pick out and how many times you have to put the whole ones back in,
in other words how efficient is this, which may be irrelevant because it is the only working solution.
and how does it adjust for different sized nuts?
/ Almond Huller #9
I keep going back and getting confused by this. What is the difference between shelling and hulling?
Black walnuts have a softer green shell so you have to get that off, then the hard nut case below.
I guess I don't understand in what condition you want to sell the nut. Like clean whole walnuts in the store?
Or broken open for the meat. I may have misunderstood you.
Does this machine only get the outside green case off?
That's what the last video looked like.
you have a fascinating website; I never knew that olive leaves by themselves were beneficial; makes sense, olive oil
despite the fat is good for you.
I hope Santa at least brings you one of these...:
Amazon.com: Reed's Rocket Nutcracker: Nut Crackers: Kitchen & Dining
/ Almond Huller
Thank you for taking the time to respond. I do appreciate it.
Almonds have a similar covering to walnuts (both Black and English) and that is what is normally called the "hull". At least that is the word used in California, where I believe at least 80% of the world's almonds are produced, so I use Californian terminology. It is only this hull I want to remove. Again, following California, the hard case is called the "shell", so shelling (also known as cracking in some places) is the next stage to leave the edible part of the nut, and this is called the "kernel". Shelling would be done by the buyer of the de-hulled nuts.
I think pecans have a similar hull, but have never seen one whole. In California there are hulling and shelling operators to deal with the enormous quantity of nuts harvested every year, so they have very complicated machinery.
I thought there had to be some sort of auger type arrangement to move the nuts horizontally along the cage, and as you say, simple beaver tailed paddles, angled to move the nuts in the right direction. Another interesting thing about the last video is that the machine shown there has horizontal cage bars, much easier to fabricate than bending the bar to fit the circle of the cage. The top half on all of them can either be lifted or removed for access to cleaning the cage after use.
The de-huller is not supposed to break the shell, but some of the broken ones may have been damaged during harvest as well as the odd one during de-hulling. The machine shown seems to be a bit short. Longer ones - up to 10 feet appear, do a better job. Probably depends on speed of rotation and throughput I suppose. Not enough nuts and they are not in there long enough to be de-hulled, too many and they are not abraised (is that a word?) enough to take the hull off. Combine harvesters can have the same problem, and the grain is not threshed from the ears.
I do not know the reason for the water. Possibly there was a lot of dust and dirt picked up with the nuts, I should think it makes things stick to the shells rather than clean them. Odd bits of husk in with the nuts "in shell" is not a problem, because the de-hulled nuts can be run over our olive sorting table. This is a table made of round bars (the same idea as the huller) set on legs to give a slope top to bottom, olives are tipped on from the sort of boxes shown in the last video, and the damaged olives, or ones that had died and dried off before harvest, the odd leaf or twig, etc. are quickly picked off by hand. Almonds/walnuts/pecans that still had hulls attached could be removed at this stage quite easily, and either put through the de-huller again, or if they are "stick tights", another Californian expression for hulls which are stuck to the shell, just discarded.
Thanks for the remarks regarding the website. It was made by the neighbour who will be working on the project with me. He is a professional graphic designer, but would really like to be a peasant. He is young enough yet, so should end up OK.
The nutcracker looks good. I have seen a home-made one in the background of a video from either Italy or Greece that I made a note of, that works on the same principle. The hand-cranked huller looks very similar to a gadget I saw for shelling corn. I think they are dual-purpose. Simply not available here. I have not grown corn for four or five years, and had less than acre when I did, so I just shelled by hand on wet winter days.
/ Almond Huller #12
/ Almond Huller
forgeblast, Thanks for your input. As can be seen from your first link (for those who did not know) the nuts are partly released from the hull when it is time to harvest. It is generally recommended to begin harvest when most of the hulls have split. The de-hulling is to completely remove them from this hull. Simple abraision does the job. A little more research indicates that it is normal to apply water when de-hulling walnuts. The size of the nut to be hulled determines the gaps between the bars of the cage. Walnuts are much bigger that almonds and a dedicated walnut huller can have bigger gaps than a dedicated almond huller.
Some of the photos in your second link do show the "beater" arrangement inside. You will note that the cage is similar to those shown in the earlier links, but these ones have a cover over. The last picture is of a tub shaped walnut huller and there are a few videos of these on YouTube for anyone interested.
I will ultimately need to make the decision about which type of internal mechanism to use. I rather like the idea of beaver tail paddles which act as an auger too, but beaters might be easier to fabricate.
/ Almond Huller #14
now this has nothing to do with hulling or shelling, but first you have to pick them up so maybe this will be helpful.
I was surprised at the number of models available.
Quick Find
/ Almond Huller
No, those are for Black Walnuts which are allowed to fall naturally. In the US tree shakers are used to dislodge the nuts from the trees. I will be picking by hand, direct from the tree.
PORTA POTTY (A67714)
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
INGERSOLL RAND VR90B TELESCOPIC FORKLIFT (A65056)
INGERSOLL RAND...
Generator (A64553)
Generator (A64553)
