Oil Filter Removal
/ Oil Filter Removal #41
"It was a day surrounded by unexpected tractor drama." Eric by the looks of your avatar pic. a little drama now and then wont bother you, wonder if your dogs was laughing at you............good pictures, least it was fixable.:thumbsup:
/ Oil Filter Removal #42
Remember, before the truck...there was the hammer.
/ Oil Filter Removal #43
That was trully novel. I've used my truck for all sorts of things but never used it to remove a filter.
Where are you? It sounds kinda close to my neck of the woods. Never know when I might need help getting a filter off.
Hey there. I am in the Sierra Nevada foothills about 50 miles east of Fresno Ca - about 15 miles west of the entrance to Kings Canyon National Park. We had tried about everything we could think of to get the filter off and the guy was ready to give up - but I wanted the filter changed out so suggested the pick up chain idea. I have had dumb ideas before (ask my wife - she was particularly skeptical about my idea for solving the problem where a cow's horn was turned down and growing into the side of the face). Some of my dumb ideas work and some . . .well not so much. But the chain and pick up idea worked instantly. Since then I have done my own servicing and have not had a problem getting the filters off - always spread some clean oil on the new filters though - I think that makes a big difference.
/ Oil Filter Removal #44
Think it would be wise to try to loosen the filter on a brand new tractor before heat and time makes it way harder to remove? Maybe just try to back them off a little by a method that doesn't damage them? Seems like it would and they would be easier to budge.
/ Oil Filter Removal #45
Think it would be wise to try to loosen the filter on a brand new tractor before heat and time makes it way harder to remove? Maybe just try to back them off a little by a method that doesn't damage them? Seems like it would.
I'm sure that would improve the odds. Whether it's worth worrying about would be another question. :)
/ Oil Filter Removal #46
How about before it leave the dealer's lot, they loosen and/or replace it? Or, that ought to be 'dealer prep' item...Mine was a turkey to get off (did an oil change @ 10 hrs) - had to use the screw-driver method
-Simon
/ Oil Filter Removal #47
The Mitsu S3L2 engines in the Max26 and the 1526 generally do not have painted on filters. The 1533/38 do, and I agree with DickFoster that the paint makes it tougher to remove the filter initially. But with the correct assortment of tools, it's generally not too tough. On the Max26, it's just pretty tight in that area with the loader installed. Seems the filter engineers did not talk to the loader engineers....
I have had a number of new Cummins equipped pickups over the years, and the initial filter removal is no fun on them either. Nor is the placement of the filter on the 6.7 engines.
/ Oil Filter Removal #48
I say this with due respect. If paint is the factor that stops me from removing a filter, I'm using the wrong tool. :)
/ Oil Filter Removal #49
Or the wrong hand...:)
/ Oil Filter Removal #52
Soon it will be the white stuff. Snow yet?
Nope. We are in complete denial......
I'm grading roads now, getting ready for the big freeze-up in the next month. Our long range says above normal temps, below normal moisture. We're gonna duck and let it slip on over to you my friend!!!! :)
/ Oil Filter Removal #53
Nice guy! Thanks much... Happy Thanksgiving to you and yours.
/ Oil Filter Removal #54
Have used everything mentioned at one time. Oil filter put on by Walmart required the harbor freight set of 4 cup sockets and a wobble extension to remove. Strap wrench did not begin to work. Was surprised when the cup like sockets worked so well.
/ Oil Filter Removal #55
I've tried everything known to man I have them hanging everywhere and here is what I find works best for my needs. There are some things you can't get them on but it will do 90% of the cars, mowers etc. I have owned.
Those are identical to the HF pliers at likely 1/3 the price of Gemplers
/ Oil Filter Removal #56
I learned about lubing the gasket with oil on your fingertip from the chimpanzee in the Valvoline commercial. Not kidding.
/ Oil Filter Removal #58
I didn't notice anyone mention this style. My apologies if they have...
They utilize a square drive ratchet with an extension if needed. I have five size/ranges which covers most of the filters I use.
Terry
/ Oil Filter Removal #59
2025 Pabreak 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2016 Jeep Renegade 4x4 SUV (A61569)
2016 Jeep Renegade...
2012 MACK GRANITE-GU713 (INOPERABLE) (A60736)
2012 MACK...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
