71 Ford 4500 Backhoe won't keep running
   / 71 Ford 4500 Backhoe won't keep running #1
pope
Rindge, NH
Ford
My 4500 diesel backhoe died yesterday. It was low on fuel but I just had a small hole I needed to dig. I was working on a hill went it just quit running. I immediately suspected the angle I was working on made it run out of fuel before it was really empty. I added more fuel but it will not keep running now. When starting, it will run for a few seconds and then quit. I tried bleeding the fuel filter & pump to ensure no air but it still will fire for a couple of seconds and then quit. I have also tried either to help it get going but with the same results.
Any ideas what's going on?
Thanks,
Mike
   / 71 Ford 4500 Backhoe won't keep running #2
Thanks,
Mike
usual problem is a lack of fuel. Drain the filter bottom and look for water in what drains out. Then bleed the fuel system to the injector connection and than see if that helps. Try and keep the fuel tank as full as possible to reduce water condensation in the tank..Don't use starting fluid to try to start it. It's easy to break rings doing that.
NEW Landhonor 9200LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
2003 International 9200I (A53317)
2003 International...
2019 Deere 35G (A53317)
2019 Deere 35G...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2019 GALYEAN...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
