Ouch... maybe watch before you purchase a Mahindra.
/ Ouch... maybe watch before you purchase a Mahindra. #61
I'd say it's not chucks fault for working on the wiring, it's Mahindas fault for not making a safety switch that wont last a year. My tractor is almost ten years and the neutral switch still functions with out issue. Me, I hate change, but do like improvements.
You have to remember NEITHER safety switch was the fault that prevented his tractor from starting. He wired around both and his tractor still would not start.
/ Ouch... maybe watch before you purchase a Mahindra. #62
In the chaos it's easy to forget the obvious. :)
/ Ouch... maybe watch before you purchase a Mahindra. #63
/ Ouch... maybe watch before you purchase a Mahindra. #64
I think I would jump the switches before I cut the wires off.
/ Ouch... maybe watch before you purchase a Mahindra. #65
I was thinking the same thing, or for that matter get a couple of straight pins to pierce the insulation and use your ohmmeter or continuity checker and actuate the levers. It ain't hard to do, and it is even quicker that cutting and splicing. Not to mention it don't tear chit up..
/ Ouch... maybe watch before you purchase a Mahindra. #66
Sometimes a few minutes of "step back and reflect" time is beneficial. But it don't play good in videos. :)
/ Ouch... maybe watch before you purchase a Mahindra. #67
I can remember many old "tough dog" electronic devices I have worked on that were so frustrating and you just beat your head against the wall, and If you would just quit and go to lunch, and come back and fix it in a few minutes. Also another strategy is have someone else (provided they are competent help) take a look at it. Often a new approach will find problems. It doesn't mean that the next guy is smarter than you, he/she was just a different person with a different approach.
/ Ouch... maybe watch before you purchase a Mahindra. #68
Exactly!!!! And how exciting would that have been in a video???? :D
/ Ouch... maybe watch before you purchase a Mahindra. #69
Did he ever determine what the problem was? Was it the solenoid?
/ Ouch... maybe watch before you purchase a Mahindra. #70
No.
My guess is a failed starting relay
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
BE HW4013HG HOT WATER PRESSURE WASHER (A59823)
BE HW4013HG HOT...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
Mufflers for vacuum pump system (5 units) (A60736)
Mufflers for...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
203201 (A60429)
203201 (A60429)
