Skid Plate??
/ Skid Plate?? #1
docsfarm
Williamsport, Pa
Mahindra 5035 HST
I have a Mahindra 5035 and I'd like to put some skid plates on it... Are there any good threads on DIY skid plates or any commercially available skid plates available? I tried searching and nothing came up.
I'd like them to be easy to remove for maintenance.
Thanks!!
Quinn
/ Skid Plate?? #2
I made one for my MF 1529. It was easy enough....started with a piece of cardboard and trimmed it to fit the area I wanted covered. I cut some right angle brackets and bolted the skid plate to the tractor. All the details of my DIY tractor skid plate are on my web site.
Here is a photo of it before I installed it.
/ Skid Plate?? #3
Forum member Rustyiron has an excellent write up on a skid plate he built
/ Skid Plate?? #4
Andy, you beat me to it... Perhaps there's a link to that thread, after mention of a skid plate in your ROPS thread, I'd like to review Rusy's work as well.
/ Skid Plate?? #6
Well, I will enter the contest for the smallest skid plate!
It covers the area where the front drive shaft and engine oil pan are exposed. Made it after the plastic drive shaft cover was damaged by something years ago.
Guess this could be submitted as an example of a area-specific protection plate... :)
(Hope the picture works!)
8493d1033784944-skid-plates-belly-pans-anyone-47-199898-plate2-jpg
/ Skid Plate?? #7
Thanks!!
Quinn
I'm planning to install one soon on my 3550 (same machine, slightly different motor). From what I've seen on the underside, and where I've seen sticks get stuck, the area that needs protection is between the loader brackets. Everything else is fairly solid. I'm planning to weld some tabs (with nuts welded in place), to the side of the loader brackets. Then a flat plate will bolt up to those tabs. I think 6-8 bolts would be sufficient, and would come off very quickly for maintenance.
/ Skid Plate?? #8
You're making me feel guilty about leaving my damaged plastic drive shaft cover as is -damaged and still exposed- on my B7800! For others with tractors like ours I'd suggest something under that middle core frame to cover the hole there (to the read of where your skid shield ends); I had some brush poke up there and knock the hydraulic fluid return hose from the pipe- left me stranded (HST)!
If there are accommodating holes for attaching the plate I'd suggest looking in to rivnuts (Rivet Nuts | Rivet Nuts & Threaded Inserts). The skid plates on my VW Golfs use them.
/ Skid Plate?? #9
It's been a while since I've looked at that post, not real descriptive or helpful. I need to drop the plate and clean out the junk that accumulates in there and try to do a little better explanation along with some more pics if you like. I really only had 3 places to locate a "crossmember" and used 3/8" X 2" bars running parallel with the tractor in between these 3 x-members.
/ Skid Plate?? #10
My skid plate is made of 1/2" thick steel. It would be rather heavy to take off without a jack or some other method of lowering and lifting it when I need to do maintenance. So the guy who designed and fabricated it for me made it in two pieces. The smaller front piece is more likely to be removed for regular maintenance. This is held on with 2 bolts near the front of the piece. The rear of the piece is held on by a tongue-and-groove section that slides on to the front of the larger rear piece. Remove two bolts, and the front piece slides off and is light enough to handle easily.
/ Skid Plate?? #11
Reminds me of the guy I bought my utility trailer from. He'd had someone build a heavier duty ramp and after lifting it around (and he was a big guy) he decided not to have a second one made!
Curious as to what is a realistic thickness (1/2" would be great, but I'm thinking that I wouldn't be able to work with that thick of metal). I think that in most cases it's a matter of trying to protect against brush, keep it from jamming in places. Rustyiron (I think the thread is great! pictures are worth a thousand words!) used some bedliner for some shielding. Got me to thinking... I'm seeing a bunch of diamond plated truck storage boxes popping up on Criagslist, wondering whether that material would work for being brush shields*. I'd think that as long as it is anchored securely that it then only need to manage light deformations: seems that there are lots of places where hard tractor parts are going to stop the material from deforming very much. Granted, slamming on a big rock or stump is going to be trouble for just about anything (other than 1/2" steel :thumbsup:).
* I've got some fairly thick aluminum skid plates on my cars. In this case it's an issue of high rates of speed meeting hard objects: just the other day I hit someone's escaped piece of firewood (at 50+ mph)- ouch! I need to check to see what kind of dent I got from that one!
/ Skid Plate?? #12
Removing and replacing a skid plate is easily accomplished using a floor jack. Raising the plate from the center approximately will allow you to slide it around to line up close then hold it in place to bolt on. Smooth steel on steel will slide easy enough and works great.
The skid plate on my 110tlb is about 5/16 with rolled edges and has no damage after about 12 years of use. I can not remember ever high centering the tractor on anything so I really don't know how it would hold up to that. Being a poor man I am cautious about damaging hard earned equipment.
/ Skid Plate?? #13
Curious as to what is a realistic thickness (1/2" would be great, but I'm thinking that I wouldn't be able to work with that thick of metal). I think that in most cases it's a matter of trying to protect against brush, keep it from jamming in places. ... Granted, slamming on a big rock or stump is going to be trouble for just about anything (other than 1/2" steel :thumbsup:).
High-centering on a rock or stump is exactly why he recommended going with 1/2". He's done a lot of these for people who use tractors in small logging operations (most of them bigger tractors than my NH TC33D). I was thinking 1/4", or even diamond plate spanning the gaps between my backhoe subframe rails. He strongly recommended going heavier, especially if I needed to get things on and off for maintenance. We both agreed that 90+% of what these do is protect from brush or other odds & ends poking up and damaging something. However he said that unless you are staying on prepared trails, sooner or later (especially in our rough, rocky terrain) you are going to hit something more solid. When that happens, you don;t want something that is going to deform easily. Once it bends, it's going to be hard to remove it for maintenance, and it will take a lot of work to get it back into shape so you can get it back on - you may end up having to rebuild it. He convinced me that we only want to make this thing once, we might as well make it tough.
I asked about whether 3/8" would be tough enough, given this was a smaller tractor. He thought about it, and now that you bring it up, I'm not sure where he ended up. I'll have to go out and measure it (tractor is 5 miles away right now).
/ Skid Plate?? #14
Just started mine. 2816hst.
/ Skid Plate?? #16
1/4 inch. Don't feel it's too heavy at all.
/ Skid Plate?? #17
Nice Vroom!
If I'm looking at this right, drive over it, jack up the back & slide it forward, jack up the front and 2 bolts. Slick:thumbsup:
Are you going to further support the front area?
/ Skid Plate?? #18
I took the fel off so I could remove the front bumper. I needed it for the hole pattern of the two plates that are bolted to either side. Tommorrow I'll weld a flat stock to the part of the skid plate that hinges upward. Then both the flat stock and the plates that drop downward on either side will mate and four bolts will fasten them together. Eventually I'll probably angle the plate up a little between the front and rear wheels. I'll also make vertical walls that will sit around the edge of the skid plate in the wheel cutouts and between the front and rear wheels. They'll be bolted there once plate is on the tractor. Your right, just drive over it, lift back end of the plate and slide it forward three inches. Then lift front of the plate up and insert one inch pins. Then fasten two bolts of the hinged portion of the skid. Very easy.
/ Skid Plate?? #20
Yes, I got the hinged portion ahead of front axle done. But had a lot of trouble getting the welder to work. Almost impossible. Not sure why it won't start and even keeping it burning is difficult. I re-installed the front bumper which receives the fel. So tomorrow I'll have to take a picture. I never answered rustyirons question if the front was supported more. Ahead of the one inch pins It isn't supported any more until just forward of the front axle. There I made a hinge, and there's another section you can see which angles up towards the front bumper. This hinged section of the skid plate will have flat stock on its edge that is drilled and matching it to pieces which are bolted on both sides of the tractor using the same holes the front bumper is bolted on with. It covers the front drive shaft which looked quite exposed as well as filters further back. The only problems are , because the front wheels turn so sharp, I had to cut the wheel wells out a lot. The portion ahead of the one inch pins is only 13 inches wide.
Some hard pipes run along the engine a little lower which could get caught with sticks running up through the wheel wells. That's why I'd like to back vertical walls surounding the wheel well and between the front and back wheels.
Also because it runs under the front axle, I will have much less clearance. Though I don't expect to be too rough with it either, it's mostly made for a decent cleared path and those un suspecting sticks poking where they shouldn't
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2022 CATERPILLAR 259D3 SKID STEER (A64279)
2022 CATERPILLAR...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
