Bent my BX!
/ Bent my BX! #11
487199d1478534622-bent-my-bx-1105161046-jpg
I bent it back and made operable again, tends to bind when it gets warm though. Will order replacement today.
BX ,,,,,, you RULE! Did you do it all by yourself (solo?) And get the last stump out too? D:
Maybe order a slightly bigger cylinder for the bigger rod and put a relief valve across it to drop the pressure?
/ Bent my BX! #13
That's what I'm thinking... it must be boosted or stuck.
/ Bent my BX! #14
Yeah, that's why I asked if he was using the tractor to pull the stumps. None of the cylinders on the boom should have the power to do that to the bucket cylinder.
/ Bent my BX! #15
Probably not a matter of hydraulics, the cyl bound up at full extension and anothe cyl (or driving the tractor) did it. :duh: dang that sucks.
/ Bent my BX! #16
If it bent only using the control levers it's totally a matter of hydraulics.
I bent a bucket curl cylinder few years ago using a Grapple. Did that by using the tractor to accomplish something the curl cylinders could not. :(
/ Bent my BX! #17
I bent my curl cylinder but not with hydraulics, was using bucket to lift telephone pole end and then dragged it down the road, when I got home, saw the damage and could only kick myself for the damage.
/ Bent my BX! #18
This is Not an Uncommon bend on backhoes, The relief valve has nothing to do with it, as that spool & relief valve was Likely Not being used at the time of the over stress on that cylinder & rod.
There are many bent hoe cylinder rods and they usually happen the same way. KennyV
/ Bent my BX! #19
Then you are thinging this person hook on to the stump, and then started to drive away with the tractor. To get it out that way.
/ Bent my BX! #20
Check with surplus center. When I bent the curl cylinder on the 3430 they had exact replacement cylinders in their close out section for a very good price. They were even orange.
2017 Ford F-550 (A55973)
2017 Ford F-550...
Water Tank (A61570)
Water Tank (A61570)
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A61307)
Snap-On Gold Medal...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2012 DOOSAN G25 GENERATOR (A60736)
2012 DOOSAN G25...
