Bent my BX!
/ Bent my BX! #1
bxbuggy
Member
western U.P. MI.
bx25
So this happened this weekend! Just as I was pulling last stump out. 1105161029.jpg
/ Bent my BX! #2
OUCH...doubt very much machine could fix.
/ Bent my BX!
I bent it back and made operable again, tends to bind when it gets warm though. Will order replacement today.
/ Bent my BX! #5
Did the hoe have the hydraulic power to do that or were you using the tractor when pulling on the stump?? Really surprised the hoe would have that much power built into it.
/ Bent my BX! #6
A hydraulic shop could probably make a new rod for much less than a new cylinder from Kubota.
Bruce
/ Bent my BX!
the hoe bent it. I was curling the ripper tooth against the stump and lifting out of the hole.
/ Bent my BX!
bcp, I am going to check on that. i think it is $185. from Kubota.
/ Bent my BX! #9
/ Bent my BX! #10
That's surprising. I would have expected $400-$700 from Kubota.
Bruce
/ Bent my BX! #11
487199d1478534622-bent-my-bx-1105161046-jpg
BX ,,,,,, you RULE! Did you do it all by yourself (solo?) And get the last stump out too? D:
Maybe order a slightly bigger cylinder for the bigger rod and put a relief valve across it to drop the pressure?
/ Bent my BX! #13
That's what I'm thinking... it must be boosted or stuck.
/ Bent my BX! #14
Yeah, that's why I asked if he was using the tractor to pull the stumps. None of the cylinders on the boom should have the power to do that to the bucket cylinder.
/ Bent my BX! #15
Probably not a matter of hydraulics, the cyl bound up at full extension and anothe cyl (or driving the tractor) did it. :duh: dang that sucks.
/ Bent my BX! #16
If it bent only using the control levers it's totally a matter of hydraulics.
I bent a bucket curl cylinder few years ago using a Grapple. Did that by using the tractor to accomplish something the curl cylinders could not. :(
/ Bent my BX! #17
I bent my curl cylinder but not with hydraulics, was using bucket to lift telephone pole end and then dragged it down the road, when I got home, saw the damage and could only kick myself for the damage.
/ Bent my BX! #18
This is Not an Uncommon bend on backhoes, The relief valve has nothing to do with it, as that spool & relief valve was Likely Not being used at the time of the over stress on that cylinder & rod.
There are many bent hoe cylinder rods and they usually happen the same way. KennyV
/ Bent my BX! #19
Then you are thinging this person hook on to the stump, and then started to drive away with the tractor. To get it out that way.
/ Bent my BX! #20
Check with surplus center. When I bent the curl cylinder on the 3430 they had exact replacement cylinders in their close out section for a very good price. They were even orange.
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A60352)
2015 Peterbilt 348...
2014 PJ TRAILER GOOSENECK TRAILER 40' (A60736)
2014 PJ TRAILER...
2014 Toro Workman MDE Electric Utility Cart (A61567)
2014 Toro Workman...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
