Shallow well pump performance?
/ Shallow well pump performance? #41
Where are you up there? Somewhere near East Tawas? My Brother-in-law has a cabin in South Branch. His well is way over 100' deep and has a sub in it. I drilled a few wells in the Harrison area up there years ago.
One thing to remember when looking for a pump. Make sure the motor is totally separate from the pump. It should be the old style, C-Flange or Square flange. Nothing that has fins on it. All the imports I have sadly became familiar with don't hold up much past the years warranty. And if the motor gets noisy, the two I mentioned have "REAL" ball bearings not bushings. Take it to a motor shop and have the bearings replaced.
Hi Speedbump. Sounds like my Maytag 3000 series dryer. The **** thing was squeaking loud after about 3yrs of use from the idler pulley Wheel and Bearing "bearing bushing".
/ Shallow well pump performance? #42
From the run times you stated, the biggest problem you have is well production. It should fill that tank between 30 and 50 lbs in less than a minute if the well produces good.
I was wondering the same thing. My experience with a shallow well with this type of pump was poor, we had a 45' deep drilled well, about 20' from the house. during the 8 years i lived in that house, we learned to manage with low reserve, quick showers, and managed when laundry was done vs dishes vs whatever.
at the time i sold the home last year, i knew it was going to be an issue. my thought was to try a submersible pump (110v) with the idea that the submersible would
pump from the bottom of the well and we hoped recovery was better at the bottom. everything i read and was told was that the inside jet pump could only pull water from 25' deep (or 26). once the water in
the well dropped to a certain point, the pump would continue to run because it didn't have the strength to "PULL" the water up with enough volume to satisfy
the cutoff switch. if it would continue to run too long, i had to run down and kill the breaker and let the well recover a bit then start it back up. we would never run
out or suck air due to the water always being above the pickup, but after a long time running the pump you could tell the pump wasn't happy.
as the sale of the house progressed, and the submersible pump didn't improve volume, i had to install an inside storage tank system with UV to satisfy the
bank requirements.
in this case with the OP what is the height difference from your pump to the static water level? and then how low does the water level drop as you are running your garden hose?
I doubt that my static level ever falls very low, that my well (-pipe) is more than 15' deep, or that it is anything but a cavity for a point/ft-valve that's fed entirely from the stone pit (16'x18'), so apples to oranges I guess. I'd say my static level has never been less than 5' or more than 10' below the pump itself in my 15 yrs here and with the 3rd pump. Horizontal distance 'point to pump' is ~26'.
My flow problem has never been more than asking a single stage pump to do too much. (Of course I get great flow/pressure from the tank until it empties) I've never drawn air or sand into a pump or the filter/housing that I know of.
Dutch, I wish there was more info here that'd help you, but we just seem to have very different water sources and circumstances. Now I feel guilty thinking that I'm the one who 'might-could' use a submersible in a shallow well and perhaps not overdraw it.
btw, What I called a 'cap' is actually a plug with a 4 1/2" dia thread. I'm going to work on getting that off ... (we'll see what that takes :laughing:) and get a camera down there if I can't see(/pull) enough right away.
/ Shallow well pump performance? #44
I can relate to that. My Wife has used a few of those washers over the years until I was browbeat into getting off some money for a new one.
A shallow well jet pump can lift water 25' vertically. That is it's max lifting ability. If the well doesn't keep up with what the pump wants and you have droppipe in the well that will allow the level to drop. It will go down to 25' and stay there as long as you use water. Once you stop using the water, the pump will keep pulling until it gets up in pressure which will slow it's ability to produce volume down and the level will come up slowly as the pump recovers to shut off. With a direct vacuum like hooking the pump directly to the casing, the pump will pull a vacuum and get exactly what the well will let it have and no more. When putting droppipe down a well, we would always install 30'. That way the water level could never get down far enough to allow the pump to draw air and lose it's prime.
/ Shallow well pump performance? #45
Shallow well pump lifting 25 feet will use much more electricity per gallon than a two stage shallow submersible pump.
/ Shallow well pump performance? #46
But the two stage 4" submersible pump has a maximum pressure of only ~28 lbs.
As I understand it, a centrifugal pump will deliver max pressure at 0' of head, or max head at negligible volume/pressure. What you get is what trade-off works in a particular application, but that can confound selection if use is varied enough (mine sure is) and not just extreme enough.
A water column (height) of 33' exerts 1 atm of pressure. If we try to draw from much more than 25' we're asking for cavitation. Why the numbers don't match exactly must be due to inevitable friction losses and inefficiency of the pump. (not PD)
Wayne and Sta-Rite seem to have the two-stage and other higher pressure S-W pumps.
Not to stray OT :)laughing:) but I'm already looking at 'subs' again. Grundfos has several in the 3" QS lineup for <$1k. I suspect the 'depth/head' numbers mean a different number of pump stages. If used in a shallow well (~10' static level, here) I don't see why a 5gpm, even 1/2 hp wouldn't put my centrifugal to shame.
That said, can't rule out going cheap for a 'sub' tryout at a depth I can pull a pump from by myself. I've got a weed-burner torch, a HFT IR thermometer, and plenty of canning paraffin to work on loosening the iron plug/cap. Wish me luck on that. :rolleyes:
/ Shallow well pump performance? #48
Head is the vertical distance in feet plus the desired pressure. To convert pressure to head; multiply pressure X 2.3.
The only two stage shallow well pumps I have seen are two stage convertible jets with a shallow well ejector bolted on the front. Centrifugal's are normally single stage also. With more impellers (stages) you get more pressure, but less volume. There is always a trade off.
/ Shallow well pump performance? #49
Other Pump charts I looked at had approx 50psi per stage on a 4 inch submersible . Whatever they are a 12 stage pump is not required if a four stage pump in a shallow well can dead head 100psi at the well tank.
/ Shallow well pump performance? #50
I'm not sure if you and I are calling a stage the same thing. But a four inch submersible pump has impellers of less than 4" in diameter. The pressure that any four inch impeller can make is dependent on it's diameter and it's speed. At 3450 RPM's a 4" impeller (which is around 3-1/2" in diameter) can make very close to 14 lbs. Each subsequent impeller in the stack adds another 14 lbs.
Since I'm not getting the flow I'd hoped for from < a dozen ft of suction head I'm drawn to suspect something throttling-back my flow below ground, like a clogged/corroded pickup screen. Nothing is interfering with the foot valve, and it works ok. I still don't seem to be cavitating or drawing air, as released from the button on the filter housing every other day or so and with only a few cc from each burp with either pump in place.
'Worst case scenarios' include sinking a new pipe (~15' max to clay base layer) and/or digging for an outlet from the cistern that I can tap into for a 'sub'. First, I have to see what part(s) of the original setup can be used. I haven't ruled out creating a replacement for the cistern, sort of a septic-in-reverse w/lines laid out along shore several yards back from the waterline and up to 100' long with a concrete distrib box or poly ejector crock for a sump. (they'd have to be pretty tall to house a sub)
MY 'sub' of choice so far is Grundfos 3" 5SQ05-90. Its way of performing on par with 4" pumps is to use a 10k rpm motor, and I can easily go two-wire w/g with the 230v model and no controller needed. 'SQ/SQE' is said not to require a cooling shroud below 30C/86F and only fractional GPM for continuous running. That said, I could still shroud to lower intake if the pump is tall for my well or its tie-in from a cistern. Carbide over ceramic thrust bearings per stage is supposed to minimize thrust wear with its floating stages.
I'm cleaning and re-applying 50/50 ATF & acetone to the 4 1/4" pipe's top thread every few hrs to uncap it. (working better than Kroil or PBlaster, btw) Depending on what's in there I'll know what options I have.
/ Shallow well pump performance? #52
I'll try and find the info but your data is making more sense at one atmosphere per stage. I may have been thinking of a specalized 3-1/2" pump with a VFD and higher rpm ??? In any case it is possible to have too much of a good thing or too many pump stages for the application.
/ Shallow well pump performance? #53
The SQ pump is OK if you need something that can fit in 3" casing. They will also start easily from a generator or battery. But they cost more than a standard 3450 RPM pump, and the 10,700 RPM increases wear rate. From Grundfos' own engineering manual they say "doubling the RPM of a pump will quadruple the wear rate". So tripling the RPM would really increase the wear rate. Using the CU301 controller to make the SQ into a variable speed SQE increases costs and reduces dependability even more. Constant pressure pump controls are a good thing, but there are better and simpler ways than variable speed pumps to make that happen.
My 'casing' is 4 1/2" at the threaded plug I'm working to remove. I'd gladly consider a 4" sub, but I expect to want to shroud it for top-filling from the cistern, and I'd need clearance around the shroud, too. A lot depends on what I find 'down the hole' and whether I could use it for a sub if I can't get better results from the conventional SW pump and screen.
That said, initial cost and short pump life don't scare me if my drop pipe is to be <10' long, and so easily accessible. I should add that during our last serious power outage (2 1/2 days, temps in the teens) I felt no need to haul out the generator for water. I turned 2 stove burners on to med, lit a few candles downstairs in the workshop and three to read by. Temp indoors never fell below 50F as I waited it out. :)
I've been familiar with VFDs for decades as applied to 3ph shop machines (mills, lathes, my smaller mill has OEM VFD) and feel they are more complicated than I'd be happy with in the long run for this use. Since I now have a CSV I plan to incorporate it in future plans too, esp if better pump/well performance makes setting the exact output pressure easier.
I do want to stick with 30-50 sw and a 40psi output adjustment. Since final tank draw-down would be several gallons before the pump kicks on it'd seem to favor replacing my tank with a smaller one. (IME, with only yearly pressure checks a genuine Well-X-Trol will outlast several pumps, Flotec maybe 10 yrs w/same)
It all comes down to what I uncap or dig anew. Nice weather is still in my side if I fire up the mini-BH and make a big project out of this by digging away. :laughing:
OK, the plug is out and I don't know what I'm looking at just yet.
I lowered a bob from the top. It went 36' down and clunked on a wet-looking bottom, then came up dry. Note that the top of the pipe is atop a steep ~4' slope and no more than a foot higher than the pump. Of my half-dozen bore/inspection cams none will reach more that 15' so I can only guess that it's drilled well into the clay, but not drawing water. The hard bottom is far below the nearby/static water level on shore <50' away, to a depth beyond a S-W pump's ability to draw. (35' below the pump!)
I don't get why the metal pipe is isn't filled with water, or why it's even there. I suppose it could be from a failed attempt to drill, but IMO there's a lot of weird to guessing why it's all metal, fully cased, so deep, and hard/'dry' at the bottom. It seems to have nothing at all to do with my well or water supply. :confused3:
I do have room to dig into or around the stone pit, but with 16 sq of siding to put up (by myself) It'll have to wait for Spring. At least I'm doing my 'bucks-worth' better since upgrading the pump. :) t o g
/ Shallow well pump performance? #56
interfering with the foot valve, and it works ok. I still don't seem to be cavitating or drawing air, as released from the button on the filter housing every other day or so and with only a few cc from each burp with either pump in .
Filter pack in drawdown cone.
Non-reversing tremmy pipe separated from the waneshaft housing, then? I have no way to measure marzelvanes/hour in real time, so do I have to ship it all back for refit? btw, I've heard they're now using TiCN coating on face seals, so maybe I'll have them all replaced. (..???..)
Egon, whatever I have for point/screen I couldn't guess where it is, how deep, etc ... Is that something I should add, or should find and fix?
I'd have all Winter to design a new cistern/sump for a submersible and lay out a trench to the pump room. I can use the 2" pond pump or the sidelined Sta-Rite to assess flow, once dug. Maybe I can hire another $15/hr 20 YO who lives with Mom to stand around, with one hand in pocket and the other checking his phone every ten minutes and watch me (as usual) for a confidence boost. Naw, that would cost more in the long run than calling a well driller to go deep and to code. :laughing:
If the metal pipe (4 1/2" ID) is clear and closed at the bottom (it's not filled with groundwater yet) maybe I can tie it into the stone pit as I thought had been done and use that for a sump after all. There was condensation on the underside of the plug but no corrosion evident in the pipe, so it looks ready to use and might get me there with less backhoe work.
Pretty sure I'd have to go 3" vs 4" on a 'sub' to allow room to shroud/sleeve for top filling in a 4 1/2" hole. That could put the intake easily 20' below static level, even at seasonal low, as now.
I have a plan to extend the reach of one of my inspection cams to get a better look at what's at the bottom of the pipe.
/ Shallow well pump performance? #58
The present area that well bore is drawing water from is getting plugged with fines and limiting the water flow.
At twenty or so feet deep think about moving the well location. A hand operated post hole digger and water flushing should get you a hole for the casing. Then drive the well point.
No guarantee. .
/ Shallow well pump performance? #59
My head is spinning from reading all of this (it's all over the place) :confused2:
Nowhere did I see anyone verify the recharge rate of the water source. This is important. Assumptions must not be made here. Any well/water person wants to know what the recharge rate is in order to match up the appropriate solution. AND, you need to know what your casing capacity is (applies to hand dug wells too).
To figure out how much casing capacity you need to know depth as well as static water level. It was already mentioned how to measure depth. For static take the small float-able item (fish bobber works well) and tie it to the end of the line and drop down until the line goes slack- measure and you have your static. Knowing the volume/capacity is then factored in how much you can draw (and set the pump if you're doing submersible).
I've got a 38' well: somewhat newer so it's fully documented. It was not in use when I bought my property. Ended up rehabbing this well so I got a pretty good education. Output was recorded at 30 gal/min; I ran a 10 gpm pump for 24 hrs straight and had NO shortage of water, so I figure that output is still pretty high. I only really needed to know static to set my pump- no concerns about drawing down the static (pump was properly matched [under recharge rate]).
Pushing water seems better than pulling it (which is why above-ground pumps that pull water can only theoretically pull down to a level of 26').
I've researched all kinds of home water systems, even rainwater collection into cisterns (from roof tops and from lean-to-like structures specifically built to provide a surface for the purpose; created a spreadsheet to assess depletion rates given month-over-month rainfall collection abilities). I mention this because sometimes one might consider a lower-rate charge/fill to a larger storage, with the larger storage being sized to meet whatever draw needs that one has (be prepared to learn how fast one can use up water!).
Well professionals can sometimes frack wells such that you open up better channels. This may open up paths through gravel instead of sand. If sand isn't a huge problem then look to utilize a spin-type trap filter (I've got a Lakos twist-lock, though I really probably didn't need it because I don't have much in the way of sand- it was more for peace of mind).
DB, the oddity with the pipe is that it terminates so far below static level and I have no idea how a S-W pump could draw from so far down. In that area (50' from the beach) I can find groundwater easily with the Terramite or with the Earthquake PHD and no extension on the auger. There's 15-20 ac/ft of water minimum in this former sand pit, according to seasonal level. I've live within 1/2 mi of here since '89, 15 yrs here, and can guess from familiarity and by pond level whose sump pumps nearby are running at any time of year.
The bob I dropped (to 35' lower than my pump height) went easily to the bottom, hit something solid, and came up dry. Perhaps a pitless adapter is what's there, but that's 25' below static level anywhere near here. According to county records on a well drilled up front in '95 there's a dense clay layer not far down and 50' - 60' thick. It starts <10' below my lower lawn, the top of the stone pit, the patio and basement floor, and obvious on the pond's bottom where there are sidewalk-like exposures of clay that nothing ever grows on. (avg depth <6' was limited by digging ~to clay eveywhere)
So, if there's a PA that far down w/sump below it was bored well into the clay and if also connected to the pit or whatever its point is fed from that's at nearly one atm higher than my static level. IMO, that's like 'ersatz-artesian' and explains why I never draw much air or lose prime, but that a S-W pump works at all. It could literally 'pressurize' a point that far down and I'm back to drawing 'net' from much closer to static level after all. :scratchchin:
As to drawing down excessively, I can come home from a week away and jump in the shower or wash the car to see water pressure flag just as the pump comes on, it recovers flow/pressure no more noticeably quickly than when doing a second consecutive load of laundry or amid a vehicle washdown. Total flow/refill is never very high/fast but is always consistent regardless of use.
I'm working on getting a camera to the bottom of the pipe. If there's a PA there then what I described above seems to make some sense. It also means that there likely won't be much tinkering with what's there, being ok for now, and being willing to drill anew to the aquifer below the clay layer. That would put a submersible easily 60' below my static, as is the norm locally and it appears to bottom-fill from a typically 170'-190' bore.
btw, water from the lower aquifer here may draw from salt deposits that seep into say every other well within a mile. (Green fixtures common w/o softener installed) What I get from the shallow well is the most calcium and water-spotting water of anyone around.
Still learnin', still explorin' ....
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67737)
2012 INTERNATIONAL...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
2020 FORD F-150 XL CREW CAB TRUCK (A65054)
2020 FORD F-150 XL...
2000 PETERBILT 378(INOPERABLE) (A67714)
2000 PETERBILT...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
2025 XKH39 39in Hydraulic 4-Way Clamshell Bucket Mini Skid Steer Attachment (A66734)
2025 XKH39 39in...
