More residential well questions
   / More residential well questions #31
Steel casing? Is it the 1930s? PVC casing, around here residential would be a choice of 3" or 4"; with ag or multiple residential in a 6". Nothing wrong with PVC Sch80, but I like the idea of a lift cable.
   / More residential well questions #32
VFD's do have their place, for instance if you have a large lawn sprinkling system with uneven numbers of sprinklers per zone. But matching the VFD to the pump's curve to maintain the required pressure and flow rates, along with providing a control system that will really take advantage of the VFD (which is to reduce pump cycling while maintaining pressure at various flow rates) can be a pretty tricky task that the average pump guy may or may not be able to set up correctly.
And you are absolutely right, Valveman. For the average homeowner a VFD is overkill and wasted money. You may be spending $2 or 3K in total to avoid having a $150 capacitors replacement every 5-10 years or so (and have a $500 - $1200 VFD or controller replacement instead)
For retrofits, the VFD's require 3 phase power, versus 2 phase for conventional systems, which can mean a very large electrical service change fee. So VFDs might make more sense on new installations where you need to to provide a new power source, but even then I'd say it is highly questionable if it is worth it.
VFD's do have there place. I have one on a hydraulic pump for a plastic injection machine, another for a conveyor belt system, and even treadmills benefit from a VFD. But for any pump with a centrifugal impeller a VFD should be as rare as hen's teeth. Centrifugal impellers lose head by the square of the pump speed. What that means is you can't slow a centrifugal pump down very much or it won't produce any pressure or even get water to the surface of the well. 10% is about as much as you can slow a correctly sized centrifugal pump down and still produce pressure and flow. That doesn't leave much room for a VFD to work or cause ANY savings in energy, as energy required actually goes up not down when the pump speed is reduced.
The average pump guy these days is much more likely to be able to program a VFD than to actually know how a pump works, how to manually adjust a control valve, or to know that a VFD is not needed. Pump manufacturers make VFD's with simple setups and give classes on how to program them. They often tell installers they no longer even need to know how pumps work, just install a VFD and any pump will do any job you want. Of course none of that is true and an easy set up VFD doesn't have the parameters needed to properly control a pump. They add in "sleep" mode, "bump up" mode, and many other things to keep people from having to do the math and set things correctly, because every pump system would need different settings.
While a VFD can keep the pump from cycling on and off for scenarios like large lawn sprinklers with uneven zones, a control valve like a Cycle Stop Valve can do that even better for a fraction of the price, without all the complications of a VFD, and will make the pump last several times longer than a VFD. But that makes the Cycle Stop Valve a "disruptive product" to the pump industry, and they will do everything in their power to keep people from knowing about it or using one. They will even try to make people believe a VFD is the only way to vary the flow from a pump and using a CSV will damage pumps. Most people don't realize restricting a pump with a valve actually makes the pump work easier and run cooler. People have it in their heads that valving off flow from a pump is bad, and pump manufacturers just let people use their own superstitions against themselves. If you don't know a valve makes a pump work easier, they are not going to tell you any different.
They make VFD's that convert single phase house power to three phase to run a three phase motor. They also make single phase drives now that will run a single phase motor. They will pretty much do what ever is needed to make it easy to install a VFD on a house well, as that is incredibly good for their bottom line. I think capitalism is a good thing. But end users need to realize everything is made with planned obsolescence as a top priority and educate themselves to keep from being taken to the cleaners.
   / More residential well questions #33
In some cases, going VFD is the cheaper option.
Most VFD's designed for residential well systems do not require 3 phase power. Matter of fact, none do. It would always be cost prohibitive to bring 3 phase power into a house.
I have been to the classes at the pump distributors as well. They teach using a three phase motor is not only less expensive, but uses smaller and much less expensive wire. Along with the ability to use a smaller pressure tank this can make a VFD system less expensive than a large pressure tank system, especially on a deep well that needs a long wire to the bottom.
However, with a VFD, the longer the wire the higher the voltage spikes to the motor and the more problems you will have. Over the years I have helped many people go back and install larger wire, throwing the smaller wire away, and replacing the three phase motor with a single phase motor, just to get back to a standard type system that will last. After replacing the VFD 2-5 times and usually the pump a time or two over a few short years, they realize cheaper is not less expensive.
   / More residential well questions #34
Great info Sportsman, thanks.
Well location is SE Michigan.
From the 1971 well record: 4" threaded steel casing 97' depth. Drive shoe = yes. Johnson 4" diameter screen 20 slot/gauze 3' long set between 94 and 97 feet. K packer 12" blank 3" plug. Static water level 45'. Pumping level below land surface 55' after 4 hours 20 gpm.
Starting at the top 3' stony clay, 8' coarse gravel, 6' fine water sand, 32' clay, 15' stony clay, 8' sandy clay, 4' water sand, 10' clay, 3' stony clay, 8' water sand medium. It notes that at 76' they set a 12 slot screen but it would not produce enough water.
From previous home owner's receipts the pump was replaced in 1991 with a 1/2HP Goulds pump and 68' of 1" galvanized drop pipe was used. In 2001 the 1" pipe and wires between the house and the well were replaced using polyline. The neighboring wells are around 100' deep.
After 52 years in the ground I find it hard to believe that unprotected carbon steel pipe is not compromised. And assuming by some miracle it isn't, how many more years does it have left?
Wells in different parts of the country are done differently. We use 5", 6", and 8" PVC casing down to about 300'. 10", 12" and 16" casing and anything deeper than 300' gets steel casing. Most use Mill slots or wire screen at the bottom and all are gravel packed between the casing and larger well wall. Municipal wells are usually all Stainless Steel these days, which is very expensive but long lasting.
4" steel casing with a Drive shoe means hard drilling and they probably drive the casing down as they drill. 20 slot/gauze between 94' and 97' means the bottom of the motor needs to be set above 94'. I wouldn't give up on the old well. Sticking a pump in 4" casing is a common problem. If they can get it out, just go back with the 3" pump, which was not even available when your pump was installed back then.
   / More residential well questions #35
Oh yeah, Snappy pitlesses. 4" well with a 4" (3.75") pump is the only place I see for them. Other than that, stick with Mr. Martinson's design.
A spool uses a 5" or so casing above the pitless so you have zero protrusion into the well. They are nice to work on.
Thanks for posting the well log. Makes life easier. You have a screened well, it has a reasonable draw down. If you have to replace it I would do the same depth, with the same screen.
This is the one advantage of metal casing you fail to hit the water you want you can always drive it deeper.
Goulds was a good pump, they should have replaced the pipe in 91 when they replaced the pump. I rarely ever put a pump back with original pipe. This way you don't have another service call a decade later.
I have worked on wells with casings that were put in in the late 1800's. So depending on your water and prior owner's (no bleach) it could last a fair bit longer, or none at all. A driller can estimate case conditions when they stick a camera down the well.
I think that your best guess is how long your neighbors' well casings are lasting. For most steel water pipes, in typical water, the corrosion happens at a pretty narrow band where atmospheric oxygen gets to the water.
It also can happen if there is electrolysis between geological formations. My parents well went out right at the coal / clay seam for example.
If the last company did not send a camera down the well and tell you where the casing was breached I would not call them back. It is the first step if your having any problems pulling a pump.
It sounds like your recent well team fluffed something, but "hey, boss, sorry, the pump stuck coming up" leaves a lot out of the answer to my way of thinking. Until someone runs a borescope down your well to see what is up, I think nobody knows for sure, and it would provide a lot of information on the cause and possible solutions. It may be something very simple, and with a bit of fishing around, all that you need to do is put a new pump and waterline in. Or not.
As ponytug stated all we can do is speculate, once a competent company looks at the well they will come up with a plan of attack.
I would first find out if the casing was breached.
If it is then I would put in a similar well.
  • 97' casing (your choice on materials.
  • 3' of 12 slot stainless screen on a k-packer.
  • Spool type pitless adapter
  • 3" 3 wire pump
IF the casing is not breached, I would have another company pull the well out. The prior company does not sound like the best option for a challenging well.
  • I would first send a camera down to see what is going on.
  • Then i would clean the pump off using air.
  • Next I would start pulling it. After that it all depends on the cooperation of the pump.
  • Once the pump is pulled I would air lift the well to see how it is producing. If production is poor or there is sediment I would consider replacing the screen. I would also send the camera down to see the condition of the screen. Back then screens sometimes were galvanized and would rust out. You might have smaller sediment getting by and that destroyed the fins on the pump. Another option is that the screen is plugged and the pump ran dry damaging it.
  • Once everything checked out I would put a new wire, and drop pipe in.
Let us know what you end up finding out. Its interesting to see how things are done in different areas.
Wells is different parts of the country are done differently.
   / More residential well questions #36
Pulled mine last fall and it was difficult to get up. Must have been silt up to the intake ports on the side of the pump. I assume the silt was suctioning it keeping us from just lifting it. After much fiddling up and down as it would only pull up about 4", it broke free and we took one section of pipe off when I put the new pump in.
   / More residential well questions #37
What to do is the question?
To start with my knowledge is quite limited.
With that said I’d recommend a new well be installed with all the currently proper equipment. It’s a straight forward procedure At a known cost. There is a know/proven water bearing formation available. Reworking the present well may end up being less expensive as well as ending up with a system not really up to todays standards.
   / More residential well questions #38
That 'known' cost is probably $10k vs $1k to pull, and $500 for pump, to pull and replace.
   / More residential well questions #40
About 6 years ago, our well pump was failing. It's 105 ft, sand well, 4" pvc sch40 casing, 3" pump, with 1" sch80 threaded down pipe, 2 wire. I called around, as I was definitely intimidated by working on it. Got 3 quotes; #1: $1000 plus pump; #2; $999 plus pump; #3: $950+$1/foot, plus pump; all said that price was based on straight back truck up to well and pull, any obstacles or complications would be more. End up pulling it myself, and going back with a $350 2-wire, 4" pump from lowes. The new 4" is about 3 ft higher in the casing than the old one, as fine sediment had worked is way it through the sand point.
I just started pulling, and it came up; biggest problem was, even though Sch80 is pretty stiff, when you get 60 ft of it into the air, it doubled back and jammed on the ground. Had to hold it there, and Yell for wife (who was inside) to come lead the end out as I finished pulling. There Had been a galv cable on it, but it was gone. I did add a poly rope when I set the new one.
The 2 vs 3 wire thing seems to be an ongoing debate. Seems like most new ones are 3 wire, and I've heard far more problems, and 5-10 year life spans; when the old 2 wires would often last 30 years. Down side is, capacitor, if that $20 part goes bad on a 2 wire, you need to pull pump, and likely replace. Flip side, the control boxes seem to go bad at an alarming rate, between weather and ants, and those boxes aren't cheap.
Add; when I say I put 4" pump in a 4" casing; it's a 4" Nominal size pump, ment for a 4" casing, so its probably 3.5-3.75" true diameter. Also, we go though pressure switches like crazy, because when it rains a lot, ants/lizards/frogs get into switch where it's dry and warm, and they end up getting between contacts and burning contact points up, and letting smoke out of their butts...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Saddles (2) (A50860)
2012 Chevrolet Tahoe 4x4 SUV (A48082)
2012 Chevrolet...
2019 New Holland C227 Skid Steer (A50657)
2019 New Holland...
Gravely ZT2350 Zero Turn Mower (A50860)
Gravely ZT2350...
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
