More residential well questions
   / More residential well questions #21
This may unfortunately be true is some areas. However where I live, the ones I know are exceptionally honest, knowledgeable and not at all out to fleece you. Maybe we are an exception, but I hope not.
Maybe it is because I talk to so many people who are trying to DIY after they have been taken in some way or another by a so called "professional pump installer". But I also sell to a lot of real professional pump installers, and you are correct, good ones do exist. Although, I find that even honest pump installers are tempted to try and sell a VFD system as they make so much more money from that than on a standard pump system. The installers are also being lied to as the manufacturers are pushing VFD's because they also make a lot more money than on a normal pump system. Saying a VFD saves energy or makes pumps last longer is just not true. But they say it over and over until people believe it and spend several times more on their pump system than they should.
I don't blame them though. They can offer to sell someone a standard old reliable pump system for 2K or a fancy new device that is supposed to save energy and make pumps last longer for 5K. They would be crazy not to take your money if you decided you wanted to spend 5K instead of 2K. But I don't know how honest that is. :rolleyes:
   / More residential well questions #22
VFD's do have their place, for instance if you have a large lawn sprinkling system with uneven numbers of sprinklers per zone. But matching the VFD to the pump's curve to maintain the required pressure and flow rates, along with providing a control system that will really take advantage of the VFD (which is to reduce pump cycling while maintaining pressure at various flow rates) can be a pretty tricky task that the average pump guy may or may not be able to set up correctly.
And you are absolutely right, Valveman. For the average homeowner a VFD is overkill and wasted money. You may be spending $2 or 3K in total to avoid having a $150 capacitors replacement every 5-10 years or so (and have a $500 - $1200 VFD or controller replacement instead)
For retrofits, the VFD's require 3 phase power, versus 2 phase for conventional systems, which can mean a very large electrical service change fee. So VFDs might make more sense on new installations where you need to to provide a new power source, but even then I'd say it is highly questionable if it is worth it.
   / More residential well questions #23
In some cases, going VFD is the cheaper option.
Most VFD's designed for residential well systems do not require 3 phase power. Matter of fact, none do. It would always be cost prohibitive to bring 3 phase power into a house.
   / More residential well questions #24
I honestly had never heard of them, but you are right, Steve, But as I do a quick research, many people say that the quality of a single phase vfd is considerably less than a 3 phase vfd. And I know from experience that 3 phase vfd themselves vary considerably in the quality of the sine wave they produce
   / More residential well questions #25
A few questions:
* Is the well a screened well (casing to a screen) or is it open bore (casing to rock then a hole drilled through the rock)
** If the well is screened how long is the screen?
** If the well is an open bore how long is the casing?
* What depth is the pump hung at? (how far below the surface is the pump)
* Can you provide more details on the failed casing? Did the driller send an inspection camera down and tell you it was breached at XX feet?
* What state are you in? There is significant differences in well construction by state. For example in Valveman's area (Lubbock TX) I doubt they require underground discharge at 6' or more like they do in MN.
Without knowing all the details I am going to make the assumption that the casing is not breached. If the casing is breached then your going to need to get a new well. Not all drillers are good at fishing. (a fish is what is stuck in the well you want out) Fishing requires lots of different tools then drilling, and different skills. Valveman has hit the nail on the head.
There is not much room between a 3.75" pump and 4" steel casing.
Call a few well companies and see what they say, if one gives you a name of who they believe is the best fisher then go with them. A competent well company that knows how to fish will have a good assortment of tools to get the job done.
It is challenging to sort out a good from a bad driller. That is why I like to talk to several, and if one driller recommends another you know they have to be good. (guy I worked for did not even have signs on the side of his truck because he had too much business, all of them recommendations)
First thing they will do is try to clean the pump off using water and / or air. Then they will start working the pump free. 1" galvanized pipe is the best thing you can ask for when dealing with a stuck pump in my opinion. You can work it up and down, to clear obstructions. Try pushing on an aircraft cable. Also if the galvanized pipe breaks it is easy to get an overshot to set on it to resume the pull. If you break the pump head off a nice pointy taper tap will go right through the motor and pull it out.
Once the pump is out you need to fix the problem on how well is getting sediment. If it is an open bore then it just needs cleaned out. If it is a screened well then the screen most likely needs replaced.
For a new well, I like an PVC casing with galvanized drop pipe, in some situations a metal casing can be better, and the driller will advise. But that is my opinion. Galvanized is easier to fish and hold the pump more stable, PVC never rusts out and is more affordable, neither is wrong, both have their place and there is a strong personal preference.
PVC drop pipe is a better choice.
Don't install a safety cable of any description. I have never rescued a pump because of one, but have lost some.
2 wire motors last for a decade, 3 wire motors last for decades.
Family business now for 87 years, been doing it since I was 7.
Safety cables are a pain to deal with when they break and coil up around the top of the pump. It makes retrieving the pump much harder.
The driller will determine if the well is an open bore or screened well, how deep to drill, what size screen if needed or how deep to set the casing. This varies by region, and what works in one area will not work in others. I know where I was working a quarter mile could make a significant difference in what attributes a good well needed. If it is a screened well I would go with a stainless screen held in by a k-packer. I abhor slotted casing. I would use a 3 wire pump as others have mentioned.
I would also go with a spool type of underground discharge such as the ones shown on page 6. They are easy to get to seal, limit what can fall into the well, and rarely stick.
Next best is the V notch type. They are bit more of a pain to set and if junk falls into one once you have removed the drop pipe can make it hard to get one to seal. They also take up room in the casing.
I hate snappy's. I cause bodily harm to the person who invented them if we ever met. The pain they have caused me. (actually they have made me a ton of money. Get to sell the customer a new underground discharge and charge for the backhoe to dig the old one out after they freeze up and the aircraft cable snaps) We had several special tools to try to free them up, but sometimes they would win and we had to get the backhoe. They are the worst to tell if they are set correctly and will drop without warning if not properly seated.
I agree with Valveman and am not sold on VFD pumps for normal usage. In certain situations they make sense such as cabins where a pressure tank is one more thing you have to drain prior to winter.
The guy I worked with did mostly fishing. It was not uncommon to have to retrieve another company's tools they lost before we could start pulling the pump. Minnesota had a law that if a house sold all wells had to be functioning or they had to be pulled and sealed, health department was adamant we get everything out but the screen. Many of the wells had not been functioning since the 60's. Dirt on a pump was a normal situation, as was drilling out cemented in wells that lacked proper paperwork. Your well assuming no breached casing sounds like standard work.
Great info Sportsman, thanks.
Well location is SE Michigan.
From the 1971 well record: 4" threaded steel casing 97' depth. Drive shoe = yes. Johnson 4" diameter screen 20 slot/gauze 3' long set between 94 and 97 feet. K packer 12" blank 3" plug. Static water level 45'. Pumping level below land surface 55' after 4 hours 20 gpm.
Starting at the top 3' stony clay, 8' coarse gravel, 6' fine water sand, 32' clay, 15' stony clay, 8' sandy clay, 4' water sand, 10' clay, 3' stony clay, 8' water sand medium. It notes that at 76' they set a 12 slot screen but it would not produce enough water.
From previous home owner's receipts the pump was replaced in 1991 with a 1/2HP Goulds pump and 68' of 1" galvanized drop pipe was used. In 2001 the 1" pipe and wires between the house and the well were replaced using polyline. The neighboring wells are around 100' deep.
After 52 years in the ground I find it hard to believe that unprotected carbon steel pipe is not compromised. And assuming by some miracle it isn't, how many more years does it have left?
   / More residential well questions #27
Your local water chemistry is going to be the key to knowing almost everything about the possible lifetime of your steel casing, with a minor amount of local ground currents and the quality of the original pipe. I think that your best guess is how long your neighbors' well casings are lasting. For most steel water pipes, in typical water, the corrosion happens at a pretty narrow band where atmospheric oxygen gets to the water. That's way above where your pump is supposed to be according to your well report above, so it would not be my first thought for a cause on the jamming. Anything is possible, but not in my top three, especially in SE Michigan. You have great alluvial soils and aquifers generally, though not insignificant amounts of iron typically.
To your underlying issue(s), I thought that @Sportsman762 laid out the issues pretty clearly.
What isn't clear to me is what your actual problem in the well is. It sounds like your recent well team fluffed something, but "hey, boss, sorry, the pump stuck coming up" leaves a lot out of the answer to my way of thinking. Until someone runs a borescope down your well to see what is up, I think nobody knows for sure, and it would provide a lot of information on the cause and possible solutions. It may be something very simple, and with a bit of fishing around, all that you need to do is put a new pump and waterline in. Or not.
I would get on the calendar to have the well folks back to pull your pump, since you seem to have a pump issue, and in the interim ask them, or another well group, for a borescope examination of the well, so everyone knows what they are up against.
FWIW: Around here, good practice would have been to set your pump deeper, but I suspect that is a reflection of the general lack of reliability of water tables here due to droughts, unlike SE Michigan. It is only a few bucks more in pipe and wire.
All the best,
Peter
   / More residential well questions #28
Your making assumptions and that gets costly quick.
   / More residential well questions #29
Oh, if your well hasn't actually failed, I would have them clean it out while they have the pump out as you are having sand and sediment issues.
All the best,
Peter
   / More residential well questions #30
Oh yeah, Snappy pitlesses. 4" well with a 4" (3.75") pump is the only place I see for them. Other than that, stick with Mr. Martinson's design.
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
John Deere turbo 6620 Combine with head (A52128)
John Deere turbo...
DRUM OF MISC HOSE CLAMPS (A51244)
DRUM OF MISC HOSE...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
