lets discuss preps for disasters
/ lets discuss preps for disasters #542
Don't forget animal traps for food beside a 22 also.
Conibear 110 and 220 traps will take most small game.
ry%3D400
/ lets discuss preps for disasters #544
Can you use that setup without grid power? My understanding is that modern inverters that are grid tied, as yours apparently is, will shut down if they do no sense grid power. This is to protect workers if the grid is down. Keeps grid tied solar from back feeding the lines when lineman expect it to be off. In the event of no power panels and inverters that were grid tied would be useless, right?
StorEdge™ Solution with Backup | SolarEdge The short answer is no, but it has to be set up that way, like the drawing I provided. HS
/ lets discuss preps for disasters #545
My neighbor got in on that Solar power Gov. Giveaway. He had a choice of going with cells tied into a separate inverter or each panel having it's own inverter. He went with the latter and now won't be able to use the cells in an emergency.
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2012 MACK GRANITE-GU713 (INOPERABLE) (A65643)
2012 MACK...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
2004 International 8600 Tender Truck (A63688)
2004 International...
