Can I cut and weld two wrenches to make a longer one?
   / Can I cut and weld two wrenches to make a longer one?
   / Can I cut and weld two wrenches to make a longer one? #22
Try to imagine the specialized tool used at the factory to build the thing in the first place, then go make one!
   / Can I cut and weld two wrenches to make a longer one? #23
Two things, one, crows are crazy smart.
Two, depending on how big of a job this is, I might modify two wrenches, a regular box end to break the nuts free, and a ratcheting wrench to get them loose. I just don't like to trust the ratcheting wrenches for breaking reluctant fasteners. Again, just depends on how many you have to do.
   / Can I cut and weld two wrenches to make a longer one? #24
Same point I was getting at earlier. Ratchet wrenches are great, but I dont trust them quite the same as I trust a regular wrench. Just the same, I dont trust ratchets that much either. Not like a breaker bar.
   / Can I cut and weld two wrenches to make a longer one? #26
I do this kind of stuff all the time to make wrenches for special jobs. I wouldn't even use two wrenches for the job you're describing. Cut your wrench as described above and add a piece of 3/16 x 1 or 1/4 x 1 flat bar as long as you need it to be. If you don't need the open end then throw it an a box to be saved for some other custom job at some point in time.
Do you even need to cut up a flat wrench? I have a bunch of cheap sockets that I've collected over the years. Weld one onto the end of a flat bar as described in the above paragraph and there you go. If a socket is too long then just shorten it a bit before welding.
Edit: I'm not totally sure I have the right picture but I would make two wrenched for the job. One as described above and the second being a cheap ratcheting style stubby wrench with a hole drilled into the shank or the open end. Bolt a flat bar onto that leaving it loose enough to swivel and just use the flat bar to operate the ratcheting flat wrench to quickly turn in the bolt. Then use the first wrench to tighten it to the final torque.
Hopefully I described s clear enough word picture.
We should turn this thread into a "custom hand tool pic" thread. Once the OP gets his problem solved, of course!
   / Can I cut and weld two wrenches to make a longer one? #27
I have 2 wrench sets at work. Standard box end for high torque, ratchet wrench for high speed once loose.
Good luck... I'm waiting to see the outcome!
Here you go. I think the tines (slitters) are on a 2 3/4" center and the tines themselves are long enough that when the wrench is on them I can only grab the last little bit of it and can't get enough torque to fully tighten. That's why the longer wrench thinking. A ratchet will not fit and the only solution seems to be a pair of extra long 12 point box end wrenches. That's all that will fit.
I'm really trying to stall this job until spring so I'll have time to think about it --plus I don't really want to do it. I'll feel better in the spring. :D
Land Honor Quick Attach Articulating Boom Brush Cutter (A50514)
Land Honor Quick...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
15 FT Trailer (A50322)
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
