5055E Issues
/ 5055E Issues
Well he pressure tested the coolant system and all is well. The last leak ended up being foam that had soaked up antifreeze and was seeping out and getting on the charge cooler. Tomorrow im strapping the bush hog to the back and actually do some work with it, we shall see what happens.
/ 5055E Issues
Sounds like my story. Told the salesman I won't keep my POS one day after the warranty has ended. Unfortunately I will most likely stay with deere but step up to a 5100e
Brett
This is my 4th john deere utility tractor, ive also owned 2 subcompacts. Until the last fiasco, I had had zero issues with any of them, the 5205 I had for 8 hard years, replaced an external clutch pedal spring and that was it, all others no issues. Maybe my last one was a fluke, and honestly alot of this tractors issues were dealer inflicted. The biggest reason I stay with JD is they stand behind what they sell, my case is an example and they fill voids in tractor sizing no other manufacturer does. Im crossing my fingers and see how it goes. If its junk I will be the first to let it be known on this site.
/ 5055E Issues #83
I know on my 5055E some of the coolant hoses had to be tightened about four or 5 times before they stopped leaking or at least it looks like they quit leaking. The dealer came out once to tighten hoses. Some of the leaks where showing up when it gets cold out. The engine and the older 9x3 transmission is a old design that has been proven and been around for a long time. I know on the 5400 I used it had 5,600 hard use hours. The 5310 had over 3,000 hours. Both had bucket loaders on them and where very reliable machines. Deere should get rid of the cheap stickers, the cheap hoses/clamps, the cheap battery, and beef up the QA. Also what about the heat issues from the transmission?? That was not an issue on there other machines of that size in past by Deere. I know some of this stuff has changed on the TIER4 machines but sounds like not much.
/ 5055E Issues
I thought the heat issues were on open station tractors only? I never experienced the heat thing. One thing I can say is this tractor has a good brake pedal on the first pump, not the normal faded first pump then firm second pump both my others had. I also asked a question as to emissions, mine is a 2015 and is an interem tier 4 with dpf only,2016's are final tier 4 and will have dpf and def.
/ 5055E Issues #85
I think the heat issue is mainly related to open station tractors. I was just referring to the 5055E tractors in general and just not the new ones that came out this year.
/ 5055E Issues #86
Mine has been split twice now and to the dealer countless times for many issues. They still haven't fixed a problem in 3rd and 4th gear that I have been complaining about since it was a year old.
I got the tractor back 2 weeks ago, still not fixed and they said they couldn't find the problem and don't know how to fix it so it's my problem now, they give up. Called John Deere NA and they said they would talk to the dealer and offer a solution. The solution they came up with is I trade in my tractor PLUS $35000 cash for a 5100e! Absolutely not!
I called John Deere NA again today and they said that is the end of the line, they won't do anything for me. I said are you sure? She said she was going to call the rep for my area and call me right back. 5 hours later I am still waiting for her to "call right back".
I don't know what happened to John Deere in the last few years, it's bad enough that the quality has gone down but now they don't even stand behind their product.
This is almost exactly what has happend to my husband. He is fixing to trade for a red one. What is a John Deere NA? He has not called the 1 800 number for JD but the Rep and dealership has basically said it is the end of the line. We bought this tractor May 2015 started having problems with it June July 2015 they said we could trade up and pay 3500 we said no its a month old we will not pay anything. They gave us 5 yr or 5000 hrs JD warranty with is a crock since it has a 200 deductable each time it is brought in for warrenty work. So far still under factory warranty I think it has 600 hrs on it as of now but the Dealership servicing has put on probably 200 of those hrs since they have had it almost every month since we bought it. So the sales man that sold it to us basically lied (he has been there for problably at least 10 yrs. Then the manager of the dealership doesn't want to fool with it and is hardly there because he has vertago alot. The owner of the dealership does not even think he owes us the time of day. I am not sure where to go next cause he has talked to the rep and he has acknowledged there is something wrong with it but said that they are basically fixing to throw up there hands and say I am done. I think JD should make it right. My husband has given them a good amount of business from referals and is a loyal customer when he is done right he would have been a life long customer but now he is pretty much done with JD unless they do something to make this right however I am not holding my breath on this.
/ 5055E Issues #87
Mines been split atleast 2 times at 256 hrs. Huge pos. Been in the shop for last two months. I hate it and wish I had gotten a bigger one made in USA or another brand. Dealer has been good but still very frustrating.
John Deere na is North America
Brett
/ 5055E Issues #88
Brett
Thank you for answering that. So does that mean he called the 1 800 number or there HQ or are we just SOL on this.
/ 5055E Issues #89
When you call HQ all they do is pass the info on to the dealer and do nothing else. I traded mine in for a Massey 5612, cost a bit more but it's 10x the tractor. My 93hp deere could lift 3300lb on the 3 pt hitch, the MF will lift 10,000, the Massey will also shift through all gears and ranges automatically and is 100% programmable. So much more capability and features for 20% less than an equivalent deere.
The big JD dealer here (13 dealerships I think) is in rough shape because they have lost so much business in the last few years. A huge number of big farms that used to run all green have switched to New Holland, Massey and Fendt.
/ 5055E Issues #90
My cousins all have Fendt... they really like them... too rich for me.
What I am seeing is more Kubota Orange in the field... even among those that said Kubota was a boutique line that would never be a threat to the big players.
/ 5055E Issues #91
Thank you! I guess considering the dealer here I won't waste my breath calling them. He is trying out a Case 75C for a week so I guess we will see how that goes.
/ 5055E Issues #92
I feel for your problem I have a 2015 3033R with broken spline washer.
As of now I in progress with a warranty claim with John Deere about my transmission. Broken Spline washer that there no replacement part at this time. There been other with the same problem and John Deere knows about it. The tractor had 180 hours on it when it broke.
It's been about 3 months and the dealer been very helpful. But John Deere don't seam to care. I have not seen the JD rep yet only talk to JD
Company.
My attorney ready to file a law suit soon if I get no response in one more month.
/ 5055E Issues #93
Company.
I always said that Deere didn't lose business to Kubota, they gave it way with actions like this. Kubota is now the elephant in the room in the small and utility tractor market and is now into the bigger tractors as well as hay equipment and some tillage. American makers are so short term sighted so that they have lost sight of the long vision. The competition hasn't.
/ 5055E Issues #94
Company.
I wish there was an attorney that had balls enough to file a class action suit against JD. All the ones we have talked to around here want nothing to do with it.
/ 5055E Issues #95
It's not just Deere... business school teaches to concentrate on your big customers which can and does boost short term profits...
A very good friend was the third generation owning a couple of local Men's clothing shops... they carried all the old brands going back to the 1920's and hung on through the 1930's...
It's been a few years since several of his suppliers severed ties... Levi was the largest... simply said they will no longer serve small businesses after nearly 90 years... it was a blow because the business had longtime loyal customers...
He was able to pick up Wrangler and many customers switched not liking how he was treated by Levi... I was one.
To their credit... one supplier that has been with them since day one is Pendelton and has assured them they value 90 year business relationship.
Maybe Deere needs a business model to reflect two entirely different customer bases?
The service I get from Deere "Yellow" is great... can't say about Deere Green because my business simply was not wanted.
/ 5055E Issues #96
Actually this local store is loosing business with the larger dealers around here too. 1 reason is Case will loan out about 6 tractors for trial where deal won't loan out any. Ending result a big catfish farm around here when with Case instead of Deere. This was however the manager of that dealerships call.
LandHonor LHR-UBF12 12in Utility Blower Fan (A60352)
LandHonor...
2018 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2018 FREIGHTLINER...
2007 Reefer Trailer 53ft (A61165)
2007 Reefer...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61569)
2018 Freightliner...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2020 Peterbilt 567 T/A McNeilus Rear Loader Garbage Truck (A61568)
2020 Peterbilt 567...
