Just bought first tractor and got ripped off
/ Just bought first tractor and got ripped off #21
I already priced the case and its $2700 for just the case itself.
Remove the old case and JB Weld it outside and inside. (or) Take it to a skilled welder and have crack welded shut.
I don't think I'm qualified enough to pull everything out of that transmission and put it back together right.
How do I post pictures? I will post pictures of the weld.
/ Just bought first tractor and got ripped off #24
-download pic onto your computer (small kb)
- use insert image tab on your reply
- from computer
-upload
That is basically it.
phillips iphone 138.JPG this is the bottom part of the weld it is leaking pretty much right at the end of the weld itself where i scraped the paint off
/ Just bought first tractor and got ripped off #28
View attachment 480749 this is the middle part of the weld
Since it was welded before there is a good chance that it can be ground back and rewelded. It takes a good welder to weld cast so find one and get it fixed. Shouldn't be all that bad. If push comes to shove, like others have said give JB Weld a try but be very meticulous about it, especially the cleaning part. You'd be surprised at what you can do with that stuff especially if there is no real pressure and it's just holding fluid.
I'm just worried about the stress that area takes since the tractor has a front loader. The crack is about 4" behind the bell housing.
/ Just bought first tractor and got ripped off #30
You could always try selling the tractor for the same price you paid or a loss equal to the cost to fix it.
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2005 Sterling Acterra Tender Truck (A61307)
2005 Sterling...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2012 ALTERFER  CAT GENERATOR (A60736)
2012 ALTERFER CAT...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
