Just bought first tractor and got ripped off
/ Just bought first tractor and got ripped off #11
Well keep all the records but going to court without a lawyer you've got the signed "as is" and getting a lawyer and going to court will probably mostly benefit the lawyer.
How much does it leak? Can you quantify it?
I've an '88 Ford diesel van that leaks tranny fluid at about the rate of 2 pints a year even when I DON'T use it, but 2 pints is cheap compared to a new transmission. I've had a tractor leaking a pint of hydraulic fluid every few hours I used it, until I replaced a hose.
I always trust sellers to do what is in their interest.
I wouldn't trust ANYTHING that the guy that sold you the tractor said. Rather I'd trust he was lying through his teeth.
A 12" weld is pretty substantial but if you stick around someone here might be able to talk you through how to fix it. It might just be a case of needing a careful cleaning and application of JB Weld will slow the leak so it's manageable.
/ Just bought first tractor and got ripped off #12
What the seller says now, after you signed the AS IS, NO WARRANTY, BILL OF SALE, is not germane.
It is your tractor now, not his. Whatever he says now, you explicitly accepted tractor condition when you signed the Bill of Sale.
I agree with NEWBURY. Move on. Make it work as well as you are able. JB Weld is good stuff used on clean surfaces.
/ Just bought first tractor and got ripped off #13
I once had a similar case that involved fraud of an automobile. An attorney was hired. I won the case and a judgement. I never collected. The Sheriff told me at the property that he could only confiscate things on the outside of the house to use as a 'payment'. It was a hovel. I'm telling you this as a 'been there done that' story.
As the others have said, 'As Is' is a binding contract. As I have shared above, even a win isn't a win necessarily. I'm terribly sorry for your having been mislead, for your disappointment, and for the money that you believe has been wasted.
However, if the tractor is operational then it didn't burn up from loss of fluid. That is a good thing. There are really smart and patient folks on here willing to help. That is a really good thing. You may have to get dirty. You may have to do a repair/refurb/modification/fabrication that you weren't expecting but I wouldn't count your money down the toilet, your emotional frustration notwithstanding.
You can document and try to appeal to the seller, but in the end unless he is just a stand-up guy and wants to clear his conscious you have bought a tractor that needs a serious leak fixed. Again, I'm sorry, and feeling as wronged as you many years ago I went to the mat in a serious way. It only led to prolonging my frustration.
Fix your new tractor and when you finally wipe your hands clean, literally and figuratively, you will feel greatly relieved I believe.
Ed Fisher
Dallas
That's what I'm afraid of but a $5000 dollar fix on a $8000 tractor hurts real bad.
/ Just bought first tractor and got ripped off #15
/ Just bought first tractor and got ripped off #16
My F2560 has a cracked transmission case. I JBwelded it up and the leak is only about a 1/2 gallon a year. I could probably get it better, but it's a job to get it clean enough. A new case is $700, but it's a job to change it. The minor fluid leak isn't enough to justify spending the time and money to change it.
I already priced the case and its $2700 for just the case itself.
/ Just bought first tractor and got ripped off #18
A little fluid loss doesn't look so bad does it? The seller has no legal obligation to do anything since you signed a contract. You're wasting time and money in court.
/ Just bought first tractor and got ripped off #19
My sentiments exactly, "don't wish for the worst case".
Assess. Observe. Ask for help. Research. Look again. Re-assess. Ask for more help. Plan an approach. Research some more. It all bolsters your confidence. JB Weld is an amazing product. Clean up that area and see about that weld. Fluid is a hard thing to stop, but perhaps the weld buttressed up the main crack/flaw and there is just a small void allowing the fluid to pass. Scrub it. Clean it. Get a good light and look at it. Assess.
You may have gotten a bit of a lemon, but that isn't the last round of the fight unless you allow it.
That car to which I alluded earlier turned out to be a fantastic automobile. 1970 Torino GT, 351, bucket seats, console, hidden headlights, and shaker scoop. To this day it was one of my all time favorite cars, and I've had 50 or so through my many years. It didn't start out like I wanted it to, but I persevered and have great memories as a young lad.
Don't fold your hand when your bet is already in the pot.
Ed
/ Just bought first tractor and got ripped off #20
I would drain the fluid and discard. Who knows what fluid that jerk put in there?
I would let it drain for days. Maybe put a little pressure in there with a Shop Vac cleaner set to blow, rather than suck. ThenI would clean the outside repeatedly, applying a little heat gun or hair drier heat, to sweat the crack some. The heat will expand the metal, squeezing out residual fluid. Then tape specialty oil absorbent pads over the crack and let it sit another couple days. Then clean again with brake cleaner.
When it becomes time for the actual repair, USE ALL NEW, FRESH MATERIAL. This repair is not occasion to use old stuff. I will wager the successful 25 year JB repairs were all made with fresh material and half the failures were repairs attempted with already open material, laying about.
Hydraulic rail grinder (A61307)
Hydraulic rail...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
1991 FORD F-800 BED TRUCK (A60736)
1991 FORD F-800...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
