Crack Rim.
/ Crack Rim. #1
Thomas
Epic Contributor
Lebanon,NH.
Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
M4800 only 550 easy hours but now the other front disk rim has completely crack around.
Lug nuts are torque to spec also tire air pressure okay.
:confused: What do you think could be causing this:confused:
/ Crack Rim. #2
Have they been welded before? See quite a bit of weld porosity at 7oclock?
To much high speed cornering with a full loader on concrete?
/ Crack Rim.
Other rim has been welded from cracking but not the one in pic.
Tractor been used for light farming towing wood wagon mostly and snow duty.
/ Crack Rim. #4
Looks lil gross overload, stress fracture
/ Crack Rim. #6
And what's with the colors on the wheel? Is this your rig from new? Hmm
/ Crack Rim. #7
You did say snow duties, if you are pushing an angled plow blade the front wheels end up taking high side stresses.
I have demolished my front rims due to that on my small tractor.
In my case I had a shop make up new center discs that I welded to my rims.
Rather then the thin material formerly used I had the discs jet cut in 5/16" stock and doubt that I will ever trash those.
(Think a 12" 'washer' with 2.5" center hole + 5 stud holes.)
Had no option as new rims were simply not available with closest being over $200 ea and at that only located one locally.
/ Crack Rim.
Was it 550 easy hours or is that what a previous owner stated? I find it hard to believe any wheel would crack like that from easy use.
Pre owner used it mostly for sawdust and wood chips,had 220 hours when sold...needed bigger tractor.
/ Crack Rim.
/ Crack Rim.
Just the standard bucket for snow removal,I plan stopping at my Kubota dealership and picking there brains what might be the cause.
Good chance I'll end up doing as you have done...discs.
/ Crack Rim. #11
Probably had a loader on it? If so, I'd guess that he was overloading it, caused the rims to flex until they fatigue cracked. I definitely wouldn't weld that crack. If anything go with a new factory rim. If you wanted to upgrade, these guys can take care of you: Wheels Now Home | Wheels Now Inc.
2018 INTERNATIONAL 4300 4X2 S/A 26FT BOX TRUCK (A67148)
2018 INTERNATIONAL...
213137 (A64276)
213137 (A64276)
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64194)
2015 Peterbilt 567...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
