New (to me) Miller Thunderbolt AC/DC
/ New (to me) Miller Thunderbolt AC/DC #12
SA
Did you do that with a VU weave? Looks more like a VU stringer. You told me your hand was not that stable anymore. Looks to me like it was plenty stable.
Just a little side to side motion. Pausing on the sides until the puddle fills. I think that weld was done with the PowerArc 300.
Hey I get lucky every once in a while!;)
That machine looks like new and your welding has really improved. Turn the heat a bit and it will perfect. You got a good deal. Just watch that Shield Arc guy, he'll have you doing 6" pipe in the 6G position and making us all look like hacks. :D
Thanks! I thought it was a bit cold, but not terrible for a newbie guessing at settings on a new machine (or any machine really) :D
No way I'll ever make you guys look like hacks, but I would like to get to the point where a good welder will look at my work and not laugh!
/ New (to me) Miller Thunderbolt AC/DC #15
You are already there!:thumbsup::thumbsup:
Sure that weld could wet out a little more. Turning up the AMPs would help. Or if you had arc force, turning it down will wet out a weld.
Now you are ready for vertical up hill with 7018!;)
Did somebody say vertical up hill with 7018?
I was pressed for time, but I had to at least do a quick trial....I think this was too cold, and there's also some undercut. I really haven't spent time on vertical up hill, but I'm going to soon!
I learned something while doing this bead. I thought I was getting burn through, but it was actually what seemed like a reflective dark spot (if that makes sense) forward and to the sides of the puddle....it looked like a hole was opening up, but it wasn't. Because of that I wasn't filling in the edges and got the undercut, and I didn't notice what was really happening until right at the end.
If anything, this is a great lesson that you absolutely need to have a decent mask where you can see what's going on!
/ New (to me) Miller Thunderbolt AC/DC #17
Not bad at all! Like you said, need to hold the outside edges just a little longer, to get more fill.
/ New (to me) Miller Thunderbolt AC/DC #18
Go Side To Side And hold on the edges a few sec. Then move on.
I did some side to side, but didn't hold the edges long enough. I was going to do another, but was out of cut pieces of scrap, and it was dinnertime :)
30KW GENERATOR (A58214)
30KW GENERATOR...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
159120 (A60430)
159120 (A60430)
1009 (A61166)
1009 (A61166)
