Quick Hitches Video about 3 Point Quick Hitch
/ Video about 3 Point Quick Hitch #1
ProjectKing
USA
Kubota L3830 FEL, Kubota L3301 FEL/BH, Ford Golden Jubilee, Honda Foreman 450ES, Polaris Ranger 400, Kubota ZD326, etc, etc
Hello, Just uploaded a new video about quick hitches. I give basic info about my I-Match hitch connected to a Kubota L3830.
Let me know if you have any questions.
#1, Accessories Your Tractor Needs! Quick Hitch - YouTube
/ Video about 3 Point Quick Hitch #2
I liked your video. Just got a 5' KKII tiller and haven't even used it yet. I was wondering if it would fit my I-Match, which is the old fixed top link model like yours.
Thank you for the kind words! Here's the quick hitch standards.
You can use the below measurements to check your equipment. They should be correct.
If your tiller is new it should work. Mine is also a King Kutter Tiller 6' and it fits perfect with no mods needed.
/ Video about 3 Point Quick Hitch #4
You need a hydraulic top link for sure. :)
/ Video about 3 Point Quick Hitch #6
Yes I do! I need to work on that. Need to do some research.
I went many years without TnT. Once I started using a Quick Hitch ony Cat II tractor it quickly followed. I now pay little attention to how I park an attachment. I can easily reattach in almost any situation.
TnT is pricey but worth every penny in conjunction with a QH.
Congrats on your QH, you are gonna love it. :)
/ Video about 3 Point Quick Hitch #7
Are you saying that Quick Hitch and TnT go together like peas and carrots?:)
/ Video about 3 Point Quick Hitch #8
I went many years without TnT. Once I started using a Quick Hitch ony Cat II tractor it quickly followed. I now pay little attention to how I park an attachment. I can easily reattach in almost any situation. TnT is pricey but worth every penny in conjunction with a QH. Congrats on your QH, you are gonna love it. :)
Yeah I would love to hydro top link so I could use my pallet forks on read of tractor! That would be a very handy set-up when doing heavy lifting.
I need to price a remote kit first from Kubota.
/ Video about 3 Point Quick Hitch #10
Prepare yourself for money shock. I bought Kubota kits to add 2nd and 3rd to my M9540. Then I built my top and tilt cylinder kits.
Fortunately the ole Ford already had two rear remotes. So all I had to buy was a top link cylinder to have that function. Haven't added tilt to it yet. But I don't use a QH on it.
Keep us posted on your progress!!!!
/ Video about 3 Point Quick Hitch #11
Great video! I have a quick hitch from Tractor Supply since 2004. Tried the Pat's quick change things for about a year, switched back.
It was better to modify the attachments- just did the York Rake last week. It was the "reason" for the year of change, LOL.
I've found that by extending the top link to "grab" the top pin, I can draw some attachments into place, lining up the lower pins.
Many times I can reach over the back from the seat and flick the top latching handles closed. If the implement doesn't have a drive shaft, I don't have to get off the tractor :)
My handles are a bit longer than the ones in your video.
Your tractor looks just like my Mahindra 3510, except you must keep it indoors ;)
Prepare yourself for money shock. I bought Kubota kits to add 2nd and 3rd to my M9540. Then I built my top and tilt cylinder kits. Fortunately the ole Ford already had two rear remotes. So all I had to buy was a top link cylinder to have that function. Haven't added tilt to it yet. But I don't use a QH on it. Keep us posted on your progress!!!!
Yeah I have a feeling it's gonna be pricey! Wish I would have purchased remotes with the tractor.
Did you install the Kubota kit yourself? And if so how difficult was it?
Thank you for the advice!
Great video! I have a quick hitch from Tractor Supply since 2004. Tried the Pat's quick change things for about a year, switched back. It was better to modify the attachments- just did the York Rake last week. It was the "reason" for the year of change, LOL. I've found that by extending the top link to "grab" the top pin, I can draw some attachments into place, lining up the lower pins. Many times I can reach over the back from the seat and flick the top latching handles closed. If the implement doesn't have a drive shaft, I don't have to get off the tractor :) My handles are a bit longer than the ones in your video. Your tractor looks just like my Mahindra 3510, except you must keep it indoors ;)
Yeah the convenience of the quick hitch is worth the hassle of modifying implements in my opinion if you have too.
I can also flip the levers without getting off tractor! Can't beat that!! Such an improvement over struggling with hooking three point links up. I have telescoping link ends and they were still a huge hassle on heavier implements like a bush hog.
/ Video about 3 Point Quick Hitch #14
The Kubota kits come with detailed instructions and diagrams. Very easy and simple with no special tools required.
/ Video about 3 Point Quick Hitch #15
I went with the Kubota valves/levers/hydraulic block/hoses/rear connectors and Fit-Rite cylinders and hoses. Will be installing it all in a week or two. Was about $1830 for all the Kubota parts (3 detented valves), and $950 for the cylinders.
I'll disagree a little bit about "easy". There's just pictorial diagrams of how the valves and block fit together and bags of different sized o-rings and lip seals, some of which will not be used for your installation, so you have to figure out what to use by trial fitting. I found that among several different Kubota dealers/sources, the pricing was virtually identical. I talked my local Kubota dealer into 10% off by also buying a LandPride grader at the same time. I'll have a nice tax deduction now!
/ Video about 3 Point Quick Hitch #16
Congrats!!!
Easy is a relevant term!!!
In the Kubota world they call these kits "Whole Goods" and there is no wiggle room on price. Sounds like you were able to use it to get leverage on an additional purchase.
Take pics and post your install progress.
I went with the Kubota valves/levers/hydraulic block/hoses/rear connectors and Fit-Rite cylinders and hoses. Will be installing it all in a week or two. Was about $1830 for all the Kubota parts (3 detented valves), and $950 for the cylinders. I'll disagree a little bit about "easy". There's just pictorial diagrams of how the valves and block fit together and bags of different sized o-rings and lip seals, some of which will not be used for your installation, so you have to figure out what to use by trial fitting. I found that among several different Kubota dealers/sources, the pricing was virtually identical. I talked my local Kubota dealer into 10% off by also buying a LandPride grader at the same time. I'll have a nice tax deduction now!
Great info!
Pics would be really nice when it's done. What tractor is this kit going on?
/ Video about 3 Point Quick Hitch #19
FWIW you can just get the slip on pin bushings to convert cat 1 to cat 2 for a couple bucks apiece and just leave your keeper pins in place. I actually changed the lift pins completely on a couple of implements as they can be bought for less than 10 bucks each from cat 1 to cat 2
Wooden Glider Chair (A64557)
Wooden Glider...
Gehl RS6-34 (A64119)
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
New/Unused Wolverine 72in Quick Attach Rock Bucket (A65583)
New/Unused...
2019 Nissan Rogue AWD SUV (A64557)
2019 Nissan Rogue...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
