Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #3,361
Thanks for posting this. Ozarks Landowner might could benefit from trying this. Over the road truckers used to use something like this, I guess the glass beads with powder maybe, but I had forgotten all about that. Heck it might smooth mine down a bit also. Mine smoothes somewhere close to PTO speed and runs fairly quiet for an old Mott so I just thought it was one of those things it does when picking up speed.
I'm going to get it as close as I can with a static balance and see how it feels. I will do some research on this for sure.
/ Let's talk flail mowers #3,362
On Sunday evening after the spouse left I figured I'd start cutting the other field. I cut until almost midnight, cutting around the bigger stuff. When I looked at the field the next day I was surprised to see well over half left do do. Out of about 24 acres there is about 4-5 acres of larger poplar and willows that will need to be cut down with the saw and picked up with the grapple before I finish with the flail. Not many people would consider this to be very entertaining, they have no idea what they're missing. image.jpegimage.jpegimage.jpeg
/ Let's talk flail mowers #3,363
Glad to see your using the grapple in a lowered position to
protect the mule and the mower.
Keep looking for your missing shredder bars if possible.
Happy Mowing
/ Let's talk flail mowers #3,364
On Sunday evening after the spouse left I figured I'd start cutting the other field. I cut until almost midnight, cutting around the bigger stuff. When I looked at the field the next day I was surprised to see well over half left do do. Out of about 24 acres there is about 4-5 acres of larger poplar and willows that will need to be cut down with the saw and picked up with the grapple before I finish with the flail. Not many people would consider this to be very entertaining, they have no idea what they're missing. View attachment 478098View attachment 478099View attachment 478100
When mowing that low how often does the knives get into the dirt? Mine does not have a roller but runs at a fixed height as it is a pull type.
/ Let's talk flail mowers #3,365
About the only time I get into the dirt is if I happen to miss an anthill. Usually I see them and just lower the grapple and push through them. Some of them are over a foot high. On occasion there is also a hump in the field as well, I can usually feel those as the front wheels go over. I just back up, lower the grapple and push through those as well. Don't get me wrong, I have scalped the ground in a few places but I'm not to concerned. I have only clay under a thin layer of topsoil in the two fields, no rocks.
/ Let's talk flail mowers #3,366
You may have already said and I missed it but how does your mower maintain its hight. Does it have 4 casters simular to a finish mower.? or wheels on each side of the mower.? like some of the pull type I've seen pictures of. Never seen one used but I do like pull behind attachments and like using them if I've plenty of time to get something done.
/ Let's talk flail mowers #3,367
/ Let's talk flail mowers #3,368
The height adjustment is a top link mounted from the hitch to the shroud. It runs right under the pto in the one picture so it can't be seen. It's really a pain to adjust it like that. A person could run a cylinder too make it much easier.
I have connected it to my tractor drawbar and used the three point for height adjustments. works pretty good but I have to really pay attention and not lift it high enough to get into the pto.
On a good note I did work on this thing yesterday. I got the grass guards fixed on the ends of the drum and started trying to balance. I used the heavy weight that I cut off of it which I weighed at nearly 3 pounds. I did fine tune it's location a little over where it was before and welded it on. to my surprise the drum would stop at any location. I didn't put any of the other weights back on. I installed all the knives and got it spinning. Much better than it was but still seems to be too much vibration. I'm not sure how much is too much though.
/ Let's talk flail mowers #3,369
The pictures are dark and hard to see but it looks like it has wheels in the back instead of a roller drum. And there's no 3pt. I don't know how you would keep that out of the dirt. ??? The front pull bars look like they aren't fixed and can move up and down. I think I would mount that up, set some front ground clearance and weld those bars. Or add some wide skids to the front edge. Then use the rear wheels to fine tune height.
Yeah, I don't think that flail is for grass. Probably for crop/stubble mulching. The flails are well used (up).
/ Let's talk flail mowers #3,370
Here are some pics I took way back on post 2955. This is when I was trying to figure out just what kind of flail I had. Still not sure but Leonz thinks it's a flail crop chopper.
Thanks for your trouble. I missed that. Like you said you can't see the adjuster in the pix but now I think I know the type you're talking about. I see the tires at the rear that should make it move across the ground smoother than a steel roller. Where I cut the ground is never smooth and the mower bounces a good bit. I'm guessing the purpose of the roller, besides being the height adjuster, is for a manicured look.?
I know its all factory made for a reason but mine don't have any give at the top hitch connection. Just a hole for the top arm and no slot or no swing joint (or whatever you call that) I suppose it's OK because if going up a rise the whole mower will lift to keep from breaking something but when you get to the top and go over the rise the mower will be up off the ground. No way for it to go with the flow like my finish mower and I don't care for using a chain for the top link.
CCWKen's idea of making the pull bars rigid to the mower then using your 3ph for height adjusting seems like would work as long as it wouldn't interfer with the pto shaft.
Thanks for keeping us informed about your mower. It's different from the rest and very interesting to see it grow up:thumbsup:
/ Let's talk flail mowers #3,371
The hitch is not free to move up or down unless you take the top link adjuster completely off. When the top link is lengthened out it it causes the shroud and drum to rise.
I can use a drawbar on my lift arms to control the cut height. If I don't the knives would be in the dirt often as my ground is not near flat enough otherwise.
I will take a better picture of the set up later.
/ Let's talk flail mowers #3,372
I think there is zero chance a flail mower could cut within 6 inches of the ground without a roller.
A bushhog has big skids, the flail does not have those. If you only had 2 tires, and tried to cut within 4" of the ground, the blades would constantly be digging dirt.
The roller can take rough conditions,,, mine has no problems.
I mow pretty fast, and the roller works perfectly.
I would not want tires.
/ Let's talk flail mowers #3,373
I'm curious about the proper 3 point hitch set up. As you can see in the photo there is a slot that I'm currently using and holes for I'm assuming if you want the mower to be more rigid. Anyone have some insight on this. The 40 acres I'm mowing is by no definition smooth. I'm thinking it was ploughed or disced maybe 20 or 30 years ago and then allowed to grow in. View attachment 476821View attachment 476822
What are the advantages and disadvantages of using the slots or fixed hole for the top link? I was using the fixed hole until I saw this post and the answer in the next post recommending the slot over the fixed hole. So I switched to the slotted hole and it worked well too. Are there conditions which favor using the slot over the fixed hole and vice versa?
/ Let's talk flail mowers #3,374
The slot allows the mower to respond to dips and bumps without changing cutting height by keeping weight and pivot point on the rear roller. I cannot think of any particular benefit to he fixed holes unless mounting the mower on the front of a tractor. Not sure even that would be different.
/ Let's talk flail mowers #3,375
I was thinking on adding a swinging hitch on my Mott as it don't have the slot. It would be based on the design of my finish mower. Do you see any reason this wouldn't work.? It would be an easy fix.
I quoted IslandTractor so everyone would see what my question was about. Anybody have an opinion about me adding this or any reason I shouldn't.
/ Let's talk flail mowers #3,376
Follow up on my belt smoking, albizia project
My start with the old belts
Today, about 10 minutes in:
When I quit a few minutes ago - luv those hammers :)
/ Let's talk flail mowers #3,377
I was thinking on adding a swinging hitch on my Mott as it don't have the slot. It would be based on the design of my finish mower. Do you see any reason this wouldn't work.? It would be an easy fix. I quoted IslandTractor so everyone would see what my question was about. Anybody have an opinion about me adding this or any reason I shouldn't. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=478283"/>
Same principle. I don't see why it wouldn't work. Key point is just to remove the topping lift as a rigid pivot point. People use chain instead of rigid topping lift on rotary mowers for the same reason.
/ Let's talk flail mowers #3,378
I grow rocks small ones and large ones and for some reason they like hiding on the edge of the fields and the field roads. My roller finally bit the dust. It had a dent where it looks like a previous owner might have dropped the mower off a trailer or something like that. It lasted a little while but the rocks won the battle. Mott Roller.jpg It's constanly jumping up and down when rolling over small rocks, roots, even sticks. I don't mean jumping several inches just bouncing I guess I should say.
Around here you'll run into that situation if you're mowing and no matter what speed it's going to bounce a little. I was just thinking of a smoother running with the tires giving a little cushion instead of the steel roller. The tires would have to be adjustable of course and set them to run the same depth as you would set the roller.
I can imagine what you're saying about not being able to cut as low when using the wheels so maybe I could have both and just raise the wheels out of the way for cutting close.
I built another roller out of schedule 40 black iron pipe. I didn't have any schedule 80 so I used what I had. So far it seems to be holding up well. I tried without success repairing the original roller but it's some kind of material that I can't weld. May take it to a real welder someday and get it repaired. It's some kind of cast steel or cast iron or cast something. :laughing: I tried mig, stick, stainless wire on mig, reverse polarity, I even tried brazing with no go. I finally got tired of patching and almost wore the bolts out taking it off and on so I built another.
If you keep showing me pictures of that JD 390 you're going to cost me a lot of money as that's what I want. :thumbsup:
/ Let's talk flail mowers #3,379
Can you believe the 390 is almost the only new tractor or attachment I have ever bought?
I have built a few machines, I guess they are "new",,, :confused2:
I drove past the Deere dealer, and almost ran off the road when I saw it!! :laughing:
I did buy a new TroyBilt MANY years ago,,, a couple chain saws were bought new,,,
BUT, otherwise,,, I want used,,,,
/ Let's talk flail mowers #3,380
CADPlans that some nice equipment. Got to love the gravelys. I bought a sickle mower few years back form a gentleman that owned a lot of restored gravely equipment. His was not for use but for shows and he had some of those hit and miss engines running different gadgets. They were set up on trailers and he carried them to shows and fairs.
After I bought the mower he almost had to run me off. I went inside his shop while he was trying to find a box of sections and rivets that he was to give me to go with the mower. It was amazing at the parts new and used he had for the gravelys. Yours look show quality do you still use any of them.
(2) BEST FLEX ROLLER CONVEYORS (A62131)
(2) BEST FLEX...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
UNUSED WOLVERINE TDB-11-84W 84" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2022 BIGHORN EXPLORER 400 EFI UTV (A62130)
2022 BIGHORN...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
