New L45 TLB
/ New L45 TLB #21
Wish I could help. My machine has the tool less quick change bucket and a custom thumb made by Michigan iron.
/ New L45 TLB #22
I remembered I had some pictures a fellow L45 owner took of their factory setup when I was researching thumb options for mine. I think I see a bolt through that pin.
/ New L45 TLB
Thanks, it is a different style quick connect unfortunately.
The dealer phoned me back this morning and said there's a set screw, I dropped the bucket and it was hidden under the ear.
It was tight, but not touching the pin, the set screw lines up with a hole in the pin meant for a bolt, which the set screw should protrude into and keep it from moving around. However it appears to be bottoming out before doing so. I may see if the local parts store carries one that has a longer taper to it. Or could spin the pin 90 degrees and see if it will hold like that.
/ New L45 TLB #24
Well, I tried. LOL
I'm glad it looks like you understand how it is supposed to work, shouldn't take much to make it work properly.
ac
/ New L45 TLB
Well, I tried. LOL
ac
No worries, I appreciate the effort greatly, it would be much simpler if mine was the same setup as yours.
/ New L45 TLB
Ok, so the set screw hole was not tapped all the way through and would not allow the screw to even touch the pin, nothing a tap couldn't fix. The other issue is the pin is designed to be used with a bolt passing through, so when it was assemble the bolt hole was in line with the set screw, but the diameter of the hole is larger than the screw and goes right through which would not allow the set screw to bottom. So the proper fix would be to have a small flat spot machined 90 degrees to the hole in the pin where the set screw could bottom onto and not allow the pin to shift side to side. For now I tightened it down onto the surface of the pin and it seems to hold well, but will talk to the dealer about having it machined or replaced with one that is designed for it.
Also please note while getting something new that has issues is a little frustrating, please don't take me too serious if I sound like I am actually upset, I like to joke a lot and sometimes it can come off the wrong way. The dealer was quick to respond and passed along any information they had to help. I'm an hour away from them so it's not like they can send a guy that easy to see what's up. I also know that not everything goes together smoothly all the time, once a couple things are sorted out I'll be golden.
I am back up and running for now, spent an hour spreading some gravel around the driveway where I removed part of the lawn to widen the parking area. It will take some getting used to with this larger bucket, it's not as easy to see around and lifting a full bucket of gravel is barely noticeable, the B2650 would feel very front heavy with a bucket full of the same stuff. I also have to be a lot more cautious of my surrounding as it's taller, longer, and wider than the B2650 was, plus if you bump into something with it there's going to be a lot more damage.
Thanks to all of those that posted replies, it is appreciated greatly.
/ New L45 TLB #27
I'm sure your dealer will make it right. It sounds like an easy fix. They could probably just mail you the proper part and you mail back the one you got to save everyone the hassle of traveling.
It sounds like you are getting the hang of the bigger, more capable machine.
I just dropped the landscape rake off the back of mine today and dug out the 6' brush hog. I did ~2 acres of hogging, still have another ~4 to go.
This machine is so versatile you simply can't go wrong!
ac
/ New L45 TLB
ac
Sounds like you were having fun too.
I think if I had a ssqa adapter plate that I could put the grader scraper on for doing the driveway quickly it would be a real benefit, then I could leave the backhoe on most of the summer.
/ New L45 TLB #29
Honestly I always fret and act lazy to remove the hoe and install the 3 point but in reality is a quick and easy task. Easily from hoe to 3 point implement in 30 mins or less.
/ New L45 TLB
Was down to help the neighbor dig out this maple stump today, figured we would use both tractors to make it go quicker. If you look closely his Mahindra 3016 is behind the stump. Should have gotten better picture with both machines beside it.
Can't believe how much faster pulling a stump is with this machine, both tractors digging took about an hour and a half, maybe two hours to have it out of the ground. We weren't exactly in a rush, so not too bad. We also stirred up a bees nest, but they didn't seem to care about us, just all over the place looking for their nest we think.
That bucket pin will not stay put, kept having to knock it back to center while digging. Hopefully the dealer comes up with a fix for that soon.
/ New L45 TLB #31
WOW! That's a serious stump! How'd you move it after that?
ac
/ New L45 TLB
Just pushed it with the front loader, I doubt it would be able to lift it up completely, but had no problem flipping it over a couple times to knock some dirt off.
/ New L45 TLB #33
Big stump, even my excavator would say ugh.
The BH is really nice, for non pilot controls, they work better than the small ag BH's
Hoe is strong also
/ New L45 TLB
Hoe is strong also
You appear to be levitating...
/ New L45 TLB #35
/ New L45 TLB
Noticed the paint was coming off the wheel after a bit of use, turned out to be some extra casting where the tie rod end attaches to the knuckle.
Took the wheel off and used an angle grinder to smooth it out and allow clearance between it and the wheel.
I'll have to get some paint for the wheel and knuckle to match the factory colors. I may take the other wheel off and clearance the same spot a little just to be sure it doesn't touch either once I get the proper paint to match.
Next on the list is installing the block heater the dealership forgot to install before delivering, they said it would be an easy install, but forgot to mention that the hydraulic pump has to come off first. Kind of disappointed with the dealer about this because parts and labour were already paid for, and when I inquired about them doing it after the delivery they just gave me the parts and basically said good luck. Same with the wheel touching the knuckle, when I mentioned it was rubbing all they really said was let us know how you make out with that.
As for the backhoe pin issue, I ended up going to a Brafasco and getting a 1/2"x13TPIx2" set screw, it passes right through the pin and bottoms on the opposite side of the coupler, and the bucket ear covers the open end. So far it has been holding the pin in place and have used it for few hours of digging.
/ New L45 TLB #37
It will probably be hard to keep the wheels from getting scuffed up.There is so little clearance that rocks get jammed in there and scratch them up.I painted the inside of one wheel but could see it would be a losing battle and gave up.It will be a long time before the wheel rusts through and they really aren't that expensive.Good luck.
/ New L45 TLB
I get that, but this was metal to metal contact, and would have worn into the wheel deeper if left long enough. I'm not worried about scratched paint on the wheels, just don't want the knuckle touching the wheel when it defects a tiny bit. I noticed gravel gets jammed in the wheels easy at the bottom, but nothing I can do about that.
/ New L45 TLB #39
I'm a little late but congratulations on your new L45 KyleH. I have 1300 hours on mine purchased new in 2012 and love it still. I am in Ontario just north of Toronto so nice to see a fellow Ontarian with an L45.
Regards,
Lauren
/ New L45 TLB #40
The Kubota TLBS always impress me. That stump is as large as anything I've pulled with my excavator, and it weighs over twice that of an L45. Kudo's
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
2009 JLG 600AJ Lift (A61166)
2009 JLG 600AJ...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
New/Unused Grapple for CFG Mini Excavator (A61166)
New/Unused Grapple...
New/Unused Landhonor 11ft x 19ft Carport with Open Side Walls (A61166)
New/Unused...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2016 Chevrolet...
