Kubota B2650 Mods?
   / Kubota B2650 Mods? #11
How does it affect finish work with you bucket? Back dragging, etc.
You can still backdrag with the bottom of your bucket.
The only time I remove the toothbar is when I'm moving snow. With the bar and a coupla hooks welded to the top of the bucket you can pry,scoop, lift and carry all manner of things which would be all but impossible without them.
   / Kubota B2650 Mods? #12
I also just upgraded to a B 2650 with cab and my first mod was a rear camera. The bracket for the safety triangle in the rear is a great place to mount the camera and the monitor is mounted at the top center of the dash. The next was to add a ballast box filled with 400 lbs of concrete. Before I poured in the concrete, on each of the inside back corners of the box I taped a 2" length of PVC that is now sealed in by concrete. These sections of PVC are now tool holders for a rake and shovel. Mu next mod will be wheel spacers for increased stability . Coming from a B 2920 open tractor I find the B2650 a little top heavy with the cab so spending the rear wheel base is a safety concern. Since the installed radio does not have bluetooth I'm going to mount a small blue tooth speaker near the top of the cab close to my head so I can hear the phone if it rings. I also added a 12 volt pigtail with a dash switch to control the electric pump on my rear mounted sprayer. So far I am very happy with the B 2650, plenty of power and the A/c great in the Texas heat
The quick disconnect FEL and the new style three point are a great improvement and make it a quick and easy job to change out the FEL for the ballot forks and switching rear attachments
What is the new style 3 point? Can you elaborate?
I was wondering the same thing. I presume he's referring to the extendable link arms and telescopic stabilizers. Great things to have on a CUT.
   / Kubota B2650 Mods? #13
That is a sweet tractor. Any pics available so we can admire it?
   / Kubota B2650 Mods? #14
YES I will try and get some pictures this weekend, the rains have finally stopped ( of which we are not complaining as rain it August in this part of Texas is a blessing)
   / Kubota B2650 Mods? #16
Don't know how to post any pictures!
Only hard the first time. When you reply, there is a box above and when you "hover" over it will say "insert image". Click on it find your picture in your computer or card or flash drive and post it. Put the picture exactly where you want it in the reply. Piece of cake.
I'll jut presume you have a radio in the cab?
   / Kubota B2650 Mods? #17
My B 2650 . The ballast box is filled with 400 lbs of concrete, the two PVC tubes imbedded in the concrete are rake and shovel holders
   / Kubota B2650 Mods? #18
Here are shots of the new style "quick attach" FEL makes it a snap to change from bucket to ballot forks. Also see the changes to the new style three point hitch
   / Kubota B2650 Mods? #19
Showing rear camera mount and monitor on dash
   / Kubota B2650 Mods? #20
I had to show an image of my ten year old Kubota ZD 1800 a great mowing machine
By the way, sorry for the duplicates and the images upside down. My first attempt at uploading images on this forum and I have no clue what I got dups nor why they uploaded upside down
NEW HOLLAND LB75B BACKHOE (A51242)
NEW HOLLAND LB75B...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
2011 INTERNATIONAL PROSTAR PREMIUM DAY CAB ROAD TR (A51243)
2011 INTERNATIONAL...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
