Changing from power adjust rims
/ Changing from power adjust rims #1
glinka
Lansing,Mi
MF 65
I have a diesel MF 65 with power adjust rims that are rusting out. The tires are 13.6 x 38, which I'm told would be on a 12 x 38 rim. Can't find any used in good condition. Buying new runs around $450 per rim. I need both replaced. A regular rim is $175. What is involved going from one to the other, is it possible?
/ Changing from power adjust rims #2
Where on the rim are they rusting out? Ken Sweet
They re rusting mostly at stem areas, bad.
/ Changing from power adjust rims #5
I have seen a rusted rim have a plate welded over the stem hole,,,
then,,, drill a new hole at a different location,,,
That procedure is pretty common and works well at almost zero cost. Ken Sweet
/ Changing from power adjust rims #6
Yep. Grind it smooth on the inside so the patch doen't tear the tube.
/ Changing from power adjust rims #7
I have seen a piece of old inner tube cur to cover the patch on the inside. Then, the new tube will not be in contact with the irregular patch surfaces. Ken Sweet
/ Changing from power adjust rims #8
I had rusted out valve stem holes on my IH. I welded washers over the hole and used the washer hole for the new valve stem hole. Has worked now for 14 years.
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2018 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2018 BOBCAT MT85...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A67147)
2012 FREIGHTLINER...
2016 CATERPILLAR 303.5E2 CR EXCAVATOR (A65053)
2016 CATERPILLAR...
