What is in and where is a good overall chain?
/ What is in and where is a good overall chain? #1
nightdevil
Upper Marlboro, Md
JD 1025R FILB
I've been in need of a good chain at least 3 times since I've had my tractor. So I head off to the home depot and its just not as simple as I thought. I'm getting the bolt on hooks by Ken so i want to make sure the ends are also compatable.
I don't plan on doing any heavy hauling with my small tractor so it may not matter. Although how everyone else uses chains I thought I'd ask.
What's the best overall chain to have with the most versatility? Any 20ft 3/8" chain?
Also my needs were to lift up or pull stumps from their holes. Another want to pull a stuck truck (had a tow strap).
/ What is in and where is a good overall chain? #3
I use a 5/16 grade 70 chain. HD does sell this chain.
/ What is in and where is a good overall chain? #4
While Ken sells chain grab hooks in other sizes, he started with 5/16" size, which will grip 3/8", 5/16" and 1/4" chain securely.
Home Depot and Lowes sell Grade 70, 5/16" chain, in a 20' length, with grab hooks on both ends in the TOWING department of HARDWARE. Walmart sells Grade 70, 1/4" chain in 20' length. These chain packages are in a bag.
Have the store cut chain into one 8' length, which will leave you a second 12' length. (Have the store cut the chain. Very difficult to do at home.) Buy two Grade 70 chain SLIP HOOKS for the two new ends, install, and you are good to go. You can link the 8' and 12' lengths via grab hook, should you need a 13' to 20' length. You will use the 8' chain much more often than the 12' chain.
It is best to buy high grade chain and fittings, no heavier than you need. On a hot day, 3/8" chain is much heavier to carry than 5/16" chain.
WHAT IS A JD 2015R FILB??????? Grade 70 1/4" may be ample for your needs.
Best to use a shock absorbing nylon strap for pulling a truck, in preference to chain.
/ What is in and where is a good overall chain? #5
+1. 5/16" Grade 70 (transport/truckers' chain) is easy to handle and rated to 4700 lbs. Harbor Freight frequently has it on sale with a "super coupon" for $30. But HD is much nearer to your location for a few dollars more.
/ What is in and where is a good overall chain? #6
I have several sizes of chain I've accumulated over the years. For my tie down chain I bought the 20' grade 70 chain as Jeff suggests but I cut them in half so I have 10'ers. Mainly I use 5/16" which has more than enough load rating for any vehicle I may need to tie down. My current inventory that I carry in the truck consists of:
6 - 10'ers of 5/16" chain
2 - 16'ers of 5/16" chain
2 - 10'ers of 3/8" chain
1 - 30erof 3/8" chain
4 - 10'ers of 2" x 10' 3335lb. rated ratchet straps
6 - 5/16" or 3/8" ratchet binders
Several 1" ratchet straps for smaller items
2 - 50'ers of rope
I'd rather have extra than not enough.
/ What is in and where is a good overall chain? #7
I use a 12' section of 3/8" Grade 70 chain. I've used it to pull tree stumps and rocks, among other things.
/ What is in and where is a good overall chain? #8
Grade 1 Chain - Industrial 1 Grade Chain Supplier, Alloy Steel Overhead Lifting Chain Products <<<<<<<<<<<Here's high grade chain at a high price, since I always push equipment to the extreme, I'll probably get the high price chain, not much faith in HD chain.
I just stretch my 40 year old USA made 20' 5/16 chain today yanking on a stump with old Army 6x6, been a tough chain until it went through a fire couple years ago, so now I'll replace it soon as I get the funds.
My first attempt at the 12" stump I hooked the 20' chain to a 5/16 Chinese made logging chain that was rapped around the stump and that chain broke, so then my son was yanking with the 20 footer hooked to the 6x6 and I was push with my over worked tractor, finally that blanking stump came out, for small roots, it sure was tough to get out.
/ What is in and where is a good overall chain? #9
I've been in need of a good chain at least 3 times since I've had my tractor. So I head off to the home depot and its just not as simple as I thought. I'm getting the bolt on hooks by Ken so i want to make sure the ends are also compatable. I don't plan on doing any heavy hauling with my small tractor so it may not matter. Although how everyone else uses chains I thought I'd ask. What's the best overall chain to have with the most versatility? Any 20ft 3/8" chain?
For my needs a 1/4 grade 70 chain is great. It has worked well for 16 years on an M6800, 60 hp. Grade 70 is good because it is lighter and easier to handle. Grade 70 is almost 2x the strength of g43.
A chain box added to the tractor makes storage easy. No need for a cover, just make sure it has large drain holes/slots.
I carry three chains. One 8', and two 16'.
/ What is in and where is a good overall chain? #10
... I'm getting the bolt on hooks by Ken so i want to make sure the ends are also compatable. ...
Just to make sure you know this - you do not use the "ends" of the chain to connect to Ken's bucket hooks. You put any link into the hooks, never put a hook to a hook, they don't fit.
/ What is in and where is a good overall chain? #11
If the OP is as dyslexic as I am on occasion, I suspect he mixed up his numbers a little. Could it be that his 2015R FILB is actually a 1025R FILB or a 2025R FILB?
If so, then I think 1/4" 70 grade would be plenty strong enough. That is what I use with my jd 2720.
/ What is in and where is a good overall chain? #12
The OP's avatar says 1025R. Either the OP changed his tractor in the avatar or Jeff misread the model number. I agree that 1/4" chain is adequate. What's a FILB?
/ What is in and where is a good overall chain? #14
Updated it through the website
The FILB acronym is John Deere's idea to tell us Factory Installed Loader & Backhoe.
/ What is in and where is a good overall chain? #15
We have several of the HF package chain deals all bought on sale (grade 70) and all have worked fine.
Use them to chain down the machine to haul as well as lift, pull, yank,drag anything we need to.
The 3/8 is a good move - not as heavy to carry around than 5/16 and will hold a but more than 1/4".
Since you have a front loader, we just use the length needed to connect and toss the rest in the bucket - that way 20' is a fits all chain.
/ What is in and where is a good overall chain? #16
I just use 1/4 grade 43 from Walmart to lift fence post
/ What is in and where is a good overall chain? #17
Wait, what? 3/8" is heavy chain... 5/16" is a bit lighter, and 1/4" lighter yet... ?? Did you mean the opposite of what you posted? 5/16" being a good compromise as not as heavy as 3/8" and stronger than 1/4"??
FWIW, Grade 43 "High Test" is pretty good chain for general use too, IMO. Gr 70 "Transport" is about 20% stronger than Gr 43.
/ What is in and where is a good overall chain? #18
For a SCUT there really isnt a need for more than 1/4" GR70 chain. But I'd probably opt for 5/16 GR70 just because is really isnt much heavier than a 1/4" or that much more $$.
I have chains of all sizes. Most of my short chains are either 1/4" or 5/16" used alot for lifting stuff with a FEL.
I dont think there is a FEL on a sub-100hp tractor that would break a 5/16 chain. But tractors can usually pull way more than they can lift. I have 3/8" gr 70 chain for tie downs as well as for skidding and pulling. I actually need to find some 1/2" chain. Been keeping an eye for some yardsale gems, and on c-list.....cause 1/2" is a big price jump over 3/8" new. But I am patient.
/ What is in and where is a good overall chain? #19
A general guide, hopefully you can read this when clicked on (subject to individual manufacturer recommendations & rating)
Size of chain (1/4", 5/16" 3/8", 1/2") means nothing, unless you know the grade.
What I find difficult, if not impossible at a general hardware (or TSC), is to then buy a suitably rated hook or a "connecting link" to connect the hook to the chain.
....the next step is then figuring out what the rating is. "Working load" versus other rating, versus safety factor (1.5, 2.5, etc...)?.
Detroit Diesel Auxiliary Hydraulic Power Plant Generator (A61568)
Detroit Diesel...
RING 2 STARTS HERE @ 9:15 AM (A62131)
RING 2 STARTS HERE...
PORTABLE SAND BLASTER (A62131)
PORTABLE SAND...
2011 CHRYSLER 300 SEDAN (A62130)
2011 CHRYSLER 300...
2020 Toyota Tacoma Pickup Truck, VIN # 5TFRX5GN2LX180496 (A61165)
2020 Toyota Tacoma...
Bestway 40ft Sprayer (A64047)
Bestway 40ft...
