Spreading lime
/ Spreading lime #1
jack707
up North wisconsin
farm trac 555
Is there a hopper I can mount on my tractor or at that can broadcast 80-89 lime??. The Co op can't do it plot not big enough for truck driver didn't want to back in afraid of getting stuck so I'm filling the bucket and speeding with a shovel!.
/ Spreading lime #2
TSC sells a 300# 3 pt spreader.
Is that pellet or powder? Not sure how powder form would spread. May even find a 3 pt spreader at a rental yard.
/ Spreading lime #4
The TSC spreader, or similar, should work then, I have used mine for seed as small as clover and rape. Mounts right on your 3 point easy and is light enough to maneuver into the linkage easy.
/ Spreading lime
It will work if I change lime to 60-69 those are the pellets they work slower then what I have now. All the ones on line are broadcast.
/ Spreading lime #6
Check rental places, a lot of them have pull behinds for fertilizer/lime/seeds. They make for a quick easy job
As a matter of fact, when I was checking into renting one, the first place I went to had just put for sale signs on all their older pull behinds (They'd gotten in a lot of new ones).
So instead of renting one for $45 per day, I negotiated them down to $200 for a 5 footer. I've been using it for several years now and not had a minutes worth of problems with it.
/ Spreading lime
I look up some rental places Monday am I will call them -thanks for the idea.
/ Spreading lime #8
You need a drop spreader. A spin spreader will not work with powdered lime and will break within moments. The material is simply too dense and compacted. Pelleted lime will usually work, however if you don't put too much in at a time. If your area is not too big you could put it down with a lawn drop spreader.
Here's a pic of an old and modern drop spreader, also called a "lime sower" by some.
or by hand
/ Spreading lime
Those are what I need! Save my arms flinging lime with a shovel gets old quick.
/ Spreading lime #10
Something like this should work well, I spread lime with it and it also worked for spreading seed. agree that Lime is expensive
/ Spreading lime
I paid 28 a ton they delivered 6.1 tons for 234.08 not bad if I had a drop spreeder. I seen HE has a drop spreeder with a poly hopper 218. It a tow behind
/ Spreading lime
My last post was changed by this program I have on my phone!!!! HD. has a tow behind for 218
/ Spreading lime #13
Whatever you need for lime, do what the soil test says and don't cut back. Lime makes fertilizer works and chances are you need a lot of it. All things considered, it's cheap money spent if you want a good crop.
/ Spreading lime
My soil test PH is 5.6 it called for 6 tons 80-89 lime or 60-69 8 tons. Now the spreed is a lost over now I have to deal with weeds! The whole field was covered what I have is
1 crossbow
2 2-4 do
Eraser
AS
What would be good to use??.
/ Spreading lime #15
I think you got a great deal- can't find the paperwork but seems like i paid over $400 for less than half of that weight...
/ Spreading lime #16
1 crossbow
2 2-4 do
Eraser
AS
What type of weeds do you have?
2, 4-D is a broadleaf herbicide. Crossbow contains 2.4-D and triclopyr (which is more effective on brush) and is more expensive. Neither will kill grass. I had not heard of Eraser, but it is glyphosate (generic Roundup) and is thus non-selective (i.e., it will kill broad leaf plants and grass).
Steve
/ Spreading lime #17
I really don't think you'll like the two behind that HomeDepot sells, not a very heavy duty unit, plus it only holds 175 pounds. I mistakenly called mine a tow behind, but after reading the later posts, it's a drop spreader, a Gandy to be specific. Large flotation wheels, good bearings, holds about 500 or so pounds
/ Spreading lime
Here you go Steve I'm no weed expert but I can tell you this weed is a pain there everywhere.
/ Spreading lime #20
Don't let those weeds go to seed. Not ever.
Use generic roundup--glyphosate--and buy at Rural King if one is nearby.Cheap and effectve. Kills all but marestail and nail that with 2,4-d.
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
3 Propane Bottles (A65579)
3 Propane Bottles...
Heavy-Duty Round Livestock Bale Feeder w/ Hay Saver (A66408)
Heavy-Duty Round...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
1000bu FEED BIN (A64277)
1000bu FEED BIN...
