Got the oversized tires mounted
/ Got the oversized tires mounted #1
sikmusicfreak8
Anza, CA
2005 Branson 4720, 8620 Backhoe
Finally got a free minute to take these in and get them changed out. They look great, really makes a difference on appearance. Glad I didn't decide to tackle this myself, would have taken all day and its pretty warm out. Thought about filling the tires, but I really haven't had any traction issues so opted not to at this time. You guys fill yours? How much difference? I think the extra weight would help with backhoe work...
/ Got the oversized tires mounted #2
Hay, thats the size I have on my 3400.. Look much fatter on your tractor :)
~61gals to fill to 75% btw..
/ Got the oversized tires mounted #3
Nice tires. What'd that set you back if you don't mind my asking.
For all 4 I want to say I was around $1400
/ Got the oversized tires mounted #5
What brand? Looking for some new ones. The best (cheapest) I found so far are some blems for $950 just for the rear 2.. But they are already mounted on the loop rims. $1400 for all for sounds much better.
edit: Nevermind.. I see Road Warrior. Where'd you find them at? Best I can find is $960 for 2, unmounted.
I bought them through a company on Amazon, fronts and rears.
12-16.5 fronts
16.9-24 rears
Searching for "backhoe tires" for the rears and "skidsteer tires" for the fronts helps bring up what you want.
/ Got the oversized tires mounted #8
Ok, Thanks.. I did see the 16.9s on there before - $1000 for 2. Same guy sells on eBay for $40 less.
/ Got the oversized tires mounted #9
Did your width increase enough to make a difference? I want to do this on my box blade tractor but do not really want to get wider than the blade.
/ Got the oversized tires mounted #10
needs a lift kit and a ranchhand bumper next.:laughing:
Looks great
/ Got the oversized tires mounted #11
With the rears loaded the outriggers on the backhoe will not lift the rear tires off the completely off the ground but does stabilize the tractor.
They aren't wider in the rear, just taller.
Problem I have been having is when I'm digging hard dirt and I'm digging sideways at all, the hoe just drags the tractor around like a rag doll.
/ Got the oversized tires mounted #14
Bigger tires make everything look better and give better floatation and stability. I'm sure you marched the fronts to the rears but how did you do that?
/ Got the oversized tires mounted #15
What tires did you have before? I was under the impression that you didnt change rims.. If it was simply from 13.6 or 14.9, then you went wider and taller.
I had 420/70 - 24 before, so the 16.9 are just taller.
I used what Branson offered from the factory to match tire sizes.
I had the IND20 tire package, which was 10-16.5 fronts, and 420/70-24 rears
I installed the IND25 package, which is 12-16.5 fronts, and 16.9-24 rears.
/ Got the oversized tires mounted #17
Pretty common with most backhoes as strong as they can be. Just have to pick at what you are digging until you get at it or use a different bucket.
/ Got the oversized tires mounted #18
Ahh.. I see. Thanks.
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2001 Mack Grapple Truck (A64127)
2001 Mack Grapple...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
