How to remove object fallen into Steering wheel compartment
   / How to remove object fallen into Steering wheel compartment #11
Before you go fishing around with a magnet make sure there is no electrical to come in contact with or to be safe disconnect the battery before you do it.
   / How to remove object fallen into Steering wheel compartment #12
Someone has never seen a Ferguson.
I wonder how many tractors have live electrics cables laying around in the clutch bellhousing.
( head slapping sound )
   / How to remove object fallen into Steering wheel compartment #13
Someone didn't read the thread title.
   / How to remove object fallen into Steering wheel compartment #14
There is no steering wheel compartment.. And the starter is on the bellhousing. English is probably not his first language..
   / How to remove object fallen into Steering wheel compartment #15
I read the title.. but I also read the thread.
i see you DID NOT read the thread.. or DID NOT understand what was said in it.
Remember.. if you are going to zing someone.. it's always good to doble check your facts! I wish you Better luck next time!
   / How to remove object fallen into Steering wheel compartment #16
I wasn't trying to "zing" anybody. I simply offered what I thought to be helpful advice. For all I knew he was holding said starter part in his hand when he dropped it into the steering wheel compartment.
SOME people just like to be antagonistic I guess.
   / How to remove object fallen into Steering wheel compartment #17
there is no steering wheel compartment!
I don't think you are being antagonistic.. I think you just have no clue about the ferguson tractor... Don't be so hard on yourself. ;)
2016 Ford Transit Connect Cargo Van (A56858)
2016 Ford Transit...
2018 Ford F-350 4x4 Ext. Cab Stellar EC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
20357 (A55758)
20357 (A55758)
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
