How to remove object fallen into Steering wheel compartment
   / How to remove object fallen into Steering wheel compartment #1
Willsk
Harare
Massey Ferguson
I have a vaaljapie tractor and a metal object fell off the starter and fell inside, how best can i safely remove this object
   / How to remove object fallen into Steering wheel compartment #3
A magnetic pickup tool, long needle nose pliers might work.
If all else fails turn the tractor over and shake it good that worked for my cat last year.
   / How to remove object fallen into Steering wheel compartment #4
I don't know what your tractor is like but on my Kubota the dash and dash cowl come off very easily.
   / How to remove object fallen into Steering wheel compartment #5
For magnetic objects use a magnetic retrieval tool for non magnetic objects some chewing gum on a stick. Barring that, dynomite.
   / How to remove object fallen into Steering wheel compartment #7
I'm curious. Is Vaaljapie Ferguson in another language or is it a specific model of Ferguson? I believe the op lives in Zimbabwe.
   / How to remove object fallen into Steering wheel compartment #8
I dont know why its called a Vaaljapie, but it is a TO-20 Ferguson (export version of TE-20) as far as I know. The manuals are the same.
   / How to remove object fallen into Steering wheel compartment #9
If its a t?-20 the starter drive probably fell off in the bellhousing. A 3 jaw might get it.. But the flywheel and ring hear make it hard to see unless you have a borescope to go with it.
There is plenty of storage space down there, but occasionally the parts tide the ring hear and bust out a chunk of bellhousing.
   / How to remove object fallen into Steering wheel compartment #10
Thanks, Midniteoyl.
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
UNUSED CHERY INDUSTRIAL 11' CATTLE SQUEEZE CHUTE (A51248)
UNUSED CHERY...
CAT CHALLENGER 65B (A53843)
CAT CHALLENGER 65B...
Truck Wheel Fenders (A51692)
Truck Wheel...
2023 LMC M30018 LOT NUMBER 192 (A53084)
2023 LMC M30018...
2017 Ford Taurus Sedan (A51694)
2017 Ford Taurus...
