How to remove object fallen into Steering wheel compartment
/ How to remove object fallen into Steering wheel compartment #1
Willsk
Member
Harare
Massey Ferguson
I have a vaaljapie tractor and a metal object fell off the starter and fell inside, how best can i safely remove this object
/ How to remove object fallen into Steering wheel compartment #3
A magnetic pickup tool, long needle nose pliers might work.
If all else fails turn the tractor over and shake it good that worked for my cat last year.
/ How to remove object fallen into Steering wheel compartment #4
I don't know what your tractor is like but on my Kubota the dash and dash cowl come off very easily.
/ How to remove object fallen into Steering wheel compartment #5
For magnetic objects use a magnetic retrieval tool for non magnetic objects some chewing gum on a stick. Barring that, dynomite.
/ How to remove object fallen into Steering wheel compartment #7
I'm curious. Is Vaaljapie Ferguson in another language or is it a specific model of Ferguson? I believe the op lives in Zimbabwe.
/ How to remove object fallen into Steering wheel compartment #8
I dont know why its called a Vaaljapie, but it is a TO-20 Ferguson (export version of TE-20) as far as I know. The manuals are the same.
/ How to remove object fallen into Steering wheel compartment #9
If its a t?-20 the starter drive probably fell off in the bellhousing. A 3 jaw might get it.. But the flywheel and ring hear make it hard to see unless you have a borescope to go with it.
There is plenty of storage space down there, but occasionally the parts tide the ring hear and bust out a chunk of bellhousing.
/ How to remove object fallen into Steering wheel compartment #10
Thanks, Midniteoyl.
/ How to remove object fallen into Steering wheel compartment #11
Before you go fishing around with a magnet make sure there is no electrical to come in contact with or to be safe disconnect the battery before you do it.
/ How to remove object fallen into Steering wheel compartment #12
Someone has never seen a Ferguson.
I wonder how many tractors have live electrics cables laying around in the clutch bellhousing.
( head slapping sound )
/ How to remove object fallen into Steering wheel compartment #13
Someone didn't read the thread title.
/ How to remove object fallen into Steering wheel compartment #14
There is no steering wheel compartment.. And the starter is on the bellhousing. English is probably not his first language..
/ How to remove object fallen into Steering wheel compartment #15
I read the title.. but I also read the thread.
i see you DID NOT read the thread.. or DID NOT understand what was said in it.
Remember.. if you are going to zing someone.. it's always good to doble check your facts! I wish you Better luck next time!
/ How to remove object fallen into Steering wheel compartment #16
I wasn't trying to "zing" anybody. I simply offered what I thought to be helpful advice. For all I knew he was holding said starter part in his hand when he dropped it into the steering wheel compartment.
SOME people just like to be antagonistic I guess.
/ How to remove object fallen into Steering wheel compartment #17
there is no steering wheel compartment!
I don't think you are being antagonistic.. I think you just have no clue about the ferguson tractor... Don't be so hard on yourself. ;)
