Buying Advice John Deere Tractor 4430
/ John Deere Tractor 4430 #1
Spa City
Little Rock
none
Looking at this tractor and need some advise. Probably more than I need for 33 acres but will likely own more property down the road. Old school vs newer models....thoughts??
/ John Deere Tractor 4430 #2
Probably more than you need for that many acres but the 30 series was not overly strong - not like the 40 series and later - so using it a little light is fine. Typically this was a very handy tractor for its size and age.
Powershift or Quadrange? I preferred the powershift but some complained of not enough gears.
Quadrange. Thinking like you that it's a bit big for my needs, I also am looking at a 5205. Thoughts on that tractor?
/ John Deere Tractor 4430 #4
If it is in good condition and the price is fair then you can use it and still get most of your money back when you sell it. The good thing about older tractors is that while you tie up money in them to own you can retrieve most of it after several years of use. If you need to make a lot of repairs it can be quite expensive for a tractor this size.
Most people would prefer a smaller 4x4 tractor for that acreage particularly if your land is hilly.
/ John Deere Tractor 4430 #5
I don't know much about the newer JDs so I cannot help you with the 5205. It may be a bit big but my Dad always said you cannot have too much power. This isn't a lawn tractor it's for farming and that 4430 will go a long way. A 50 hp tractor will do you fine for 30 acres but if you grow you will want more. You won't find a limit with the 4430 where you will with the 5205.
/ John Deere Tractor 4430 #7
4430 is way overkill for 30 acres. Earlier 4430's had 2 pinion diff while later or updated models had 4 pinion diff plus wider final drive planetaries. I disagree with creamer as 30 series with 404 cid engines although powerful but no as strong as 466 cid's in 40 series.
/ John Deere Tractor 4430 #8
My take away from Creamers thread was the 30 series were not as strong as the 40 series. You appear to agree with this.
/ John Deere Tractor 4430 #9
A 4430 is easy to work on if you are halfway mechanically inclined, we had on on our ranch where it was used for mostly haying and feeding, but did do some farming and it does just fine especially for 30 acres.
/ John Deere Tractor 4430 #10
should be just fine for 30 acres, maybe even a little too much
/ John Deere Tractor 4430 #11
The 4430 is the predecessor to one of Deere's most popular tractors of all time (and they still sell like crazy today on the used market when they come up) the 4440. The 5205 is a good tractor too, friend has a 5105 that's lived a HARD 600 hour life and only some electrical problems and brakes have been issues with his. But keep in mind he beats on this tractor. His 600 hours are more like my 1600 hours.
/ John Deere Tractor 4430 #12
I would happily buy a 4430 for my 30 acres if I found a good deal on one. When I bought my tractor for my 30 acres, I thought 50 hp would be plenty. Well, in some cases it is and in others it's not.
Be aware that implements sized to fit a 4430 (140 hp??) will be MUCH more expensive than Cat 1 implements that fit a smaller tractor. That's the only thing that would make me gag on buying a tractor that size. Well, that and the cost to keep diesel in it.
Thanks to all for your replies. One last question...would you choose a 5225 over the 5205?
/ John Deere Tractor 4430 #14
Yes and no. If the 5225 has power reverser and if you can tolerate the noisy 5cyl. The 5325 I have is a beast but it's loud and smokes a good bit, not the smoothest engine ever but pretty reliable. The 5205 will have the 2.9L 3cyl that has a better track record. Also some have found the 5225 to be sort of underpowered due to the weight compared to the 5205(both are 56hp).
Great advice for a guy who wouldn't know. Thanks again!
/ John Deere Tractor 4430 #16
What year is the 5225? Reason I ask is earlier ones had trouble with the fuel pumps but Deere corrected this in 07. My 5325 is an 05 but when my fuel pump goes, I'm prepared for it and can fix it. I'd stay away from an 05-06 if it was me and didn't feel like taking a chance.
/ John Deere Tractor 4430 #17
I disagree on the implement cost. Modern farmers use huge implements that a 4430 couldn't dream of pulling. Around here you can find tons of implements appropriate for that sized tractor rusting away on farms and dirt cheap at auctions. I actually think they are often cheaper than the compact implements because there is much less demand for them as they are too big for the compact guys and too small for the real farmers.
My tractor is a 4440 and I love it. I traded a 2006 95 hp case with cab and loader straight across for it. I went backwards 26 years, went from having a FEL to no FEL, and I still think I got the good end of the trade. Those old deeres have tons of parts a available and are simple to work on if needed. I haven't had to do much to mine in nearly three years of having it.
I owned a 4430 about 12 years ago. It was good tractor but not as refined as the 4440. I sold it for more than I paid for it when we sold our acreage and moved to town. Had we not moved to town I would still probably have it.
Don't be afraid of old iron if you have basic mechanical skills. I truly believe they are made stouter and you don't have to be an electrical engineer to work on them. I find it amazing tractor this old are still used daily today. I wonder if you will see a lot of tractors made today still in use 30 years from now.
As to that sized tractor and the acres I say it isn't the acres but what you want to do that matters. I have 25 acres and use my tractor to plow and plant. I don't want to spend a week out there doing these chores on a tiny tractor. I have a skid steer for loader tasks which happen far more often than regular tractor work. I use my loader for one thing or another almost daily and I do all my road maintenance with the skid steer as well. The tractor just gets used for chiseling, discing, planting and shredding. It is the perfect size for me. Now if you want to do a lot of stuff in confined spaces, work around your yard, or have a bunch of trees to work around, etc you might want to look at smaller machines.
Also one thing to consider is older tractors like that have fully depreciated. The value they have is due to their utilitarian value. That is as long as still works like it should it most likely will not go down in value any more and may in fact go up. Newer tractors have a lot of their value in the fact they are new and the value goes down every year.
/ John Deere Tractor 4430 #19
bdog, I don't know what part of the state you're in, but in the mostly metropolitan areas like DFW any implements sized for a tractor like the 4430 apparently are gold plated. At least it seems that way based on the asking prices I see.
But I grew up in southwestern Oklahoma in a small rural farming community, and I know what you're talking about. The smaller implements that were parked when tractors started getting bigger were usually just ignored and left to rust, and a guy could buy them pretty cheap. When my dad died, we sold off all of his old farm equipment. It went for pennies on the dollar. It ain't that way around here where I live now.
/ John Deere Tractor 4430 #20
Pappy - I have to agree with bdog - that size of equipment goes for cheap around here. Last Spring I saw an 18' tandem disc (Sunflower) that was in good shape go for $1000. The field cultivator went for $1800 and it was really nice. The well cared for 4430 went for $14,500 and the a 1066 went for $12,000. That disc was just barely over scrap metal pricing. This was a big well advertised sale too. There were over 500 bidders present.
2026 Steel Pines Cargo 7x14 Enclosed Trailer, VIN:7FWBE1424T1036524 (A61166)
2026 Steel Pines...
Lincoln Electric Ranger Welder (A61166)
Lincoln Electric...
2017 Ford Escape (A61569)
2017 Ford Escape...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2019 John Deere 30G Mini Excavator (A63109)
2019 John Deere...
