Buckwheat and yellow clover
/ Buckwheat and yellow clover #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
Earlier in the year, I rototilled up about an acre plot, and broadcast both buckwheat and yellow clover as a food plot for bees.
I've never been very successful in growing anything, and this seems to be no exception. The buckwheat did come up, it was thin, and got maybe 6" tall and that was it. The yellow clover, didn't even see much of it come up at all. I did a simple broadcast and then drug a chained link fence back and forth across it, thinking this would be enough to work it in. My understanding is you don't want it very deep.
Some one educate me on how I can do it better.
/ Buckwheat and yellow clover #2
Buckwheat is about the strongest germinating seed there is.
Was the soil moist when you seeded? Was the soil CONTINUALLY moist until the newly germinated seeds/plants were up 2"?
Less likely, but possible, your soil is either very acid or very base and low in organic matter and the two seeds demand less extreme pH soil.
Timing of the rains after I planted was poor. Perhaps that's the major reason. I just want to be sure I wasn't screwing this up. I will try again.
/ Buckwheat and yellow clover #4
Clover is a very small seed.
Next year take one section and sow the Buckwheat and Clover without dragging afterwards. Buckwheat, in my experience in Maryland and Florida, will always germinate if kept moist. Very small seeds almost always need some light to germinate. If covered, they will not germinate.
A Cultipacker is a specialty implement for rolling in seed without covering. Ridges provide a moisture reservoir for at least half the seeds.
The germination of many medium and large size seed is improved by dragging as you did.
Photos: Everytfhingattachments.com Cultipacker.
LINKS: improve germination yellow clover - Google Search
Next year take one section and sew the Buckwheat and Clover without dragging. Buckwheat, in my experience in Maryland and Florida, will always germinate if kept moist. Very small seeds almost always need some light to germinate. If covered, they will not germinate.
As you likely know, a Cultipacker is a specialty implement for rolling in seed without covering it. Ridges provide a moisture reservoir to at least half the seeds.
Yes...don't have one. It did not occur to me that I perhaps covered them too much.
/ Buckwheat and yellow clover #6
A soil test is pretty cheap. Tell the testing service you want to grow Yellow Clover and Buckwheat. They will inform you of soil pH and any nutrient deficiencies, relative to Yellow Clover and Buckwheat.
"Broadcast seeding for pure sweetclover stands works in higher rainfall areas in early spring where soil moisture is adequate for seven to 10 days after planting."
Here is another good LINK: http://www.mccc.msu.edu/documents/managingccprof/ManagingCoverCropsProfitably_sweetclovers.pdf
/ Buckwheat and yellow clover #7
Yes. First thing to do.
fresh turned sod isn't the best for planting in.
Thinking back about this, I think the by far biggest problem is lack of moisture at the right time.....AND....I covered up the seeds way to much.
From reading about a cultipacker....I'm going to be on the lookout for one, but bet they are going to be hard to find at a reasonable price.
/ Buckwheat and yellow clover #9
/ Buckwheat and yellow clover #10
I agree about the moisture levels. Timing is everything with buckwheat. You need a good supply of rain at the right moments. What time of year did you plant it? How long did it take to flower?
/ Buckwheat and yellow clover #11
Glad to read you are planting for the bees. A while after the first time I planted a field of buckwheat, I heard a sort of roar from the direction of the field when I was walking nearby. I walked closer only to learn it was the hum of thousands of bees on the flowers.
I grow it every year, and don't cover the seeds. If I've tilled, then I drive the tractor over the plot (over and over again, paralleling my tread marks) since I can't find a reasonably priced cultipacker either. My R4s press the seeds into the soil, and make a kind of imprint not unlike what a cultipacker is doing. It takes a while, but can do it at a higher speed, and the germination rate makes it worth it. Once they've gone to seed, I sometimes bush hog them, and get a very nice second crop by just letting them germinate loose on the ground.
I do the same with my clover plots.
I only drag over the bigger seeds, like pure sunflower, or my soybeans/cowpeas/sorghum/sunflower/buckwheat mix.
Good luck.
/ Buckwheat and yellow clover #12
An old pine tree makes a cheap drag. it certainly isn't a cultipacker, but often does the trick in a similar fashion.
/ Buckwheat and yellow clover #14
Has anyone had success with buckwheat reseeding itself with a little help from equipment? What I mean is, my buckwheat is currently going to seed and I was thinking about taking a cultipacker and just packing it down. Sort of smashing it all down into the soil. If so, what is your method? I know it's not a traditional thing to do with buckwheat but I also grow for the bees and would love to just help it along and, take advantage of all that good seed on the plants.
/ Buckwheat and yellow clover #15
I use Buckwheat to suppress weeds in a small commercial Blueberry patch.
We seed in March, here in Florida. The second crop is about 20% of the size of the first crop and is in flower now. We do absolutely nothing to encourage the second crop as it is tight around the Blueberries.
Nothing germinates stronger than Buckwheat.
Just leave it alone. Water if it is parched.
Good luck.
That's good to know. If I don't find a cultipacker, and probably won't, I'll do it that way next time. I'm not giving up on getting a good stand.
As to when I planted, don't recall the exact date, but close to 04/09th. We had a dry spell after that.
/ Buckwheat and yellow clover #17
OP doesn't say what was on the plot previously and perhaps the soil contains residue of old herbicide used on corn ground. I bought two acres of land that used that stuff a few years ago...the old stuff would kill the ground for anything other than corn for several years. Thankfully things have changed. Not familiar with buckwheat but sounds like it "takes" easily. No sense in repeating that soil test thing because that would have been my first suggestion.
Fescue, fairly decent too.
/ Buckwheat and yellow clover #19
Ok then! Bad seed or just the "luck of the draw" on weather! Friend of mine planted chicory last fall...I think he broke the record on seed failure!
/ Buckwheat and yellow clover #20
I planted buck wheat one year by running over with a UTV. It doesn't need to be deep. I thought the advantage of it, was it could grow in many places, and help restore the soil. Getting ready to do some again.
