Backhoe 2420 BH attachment
/ 2420 BH attachment #1
draw54
Member
Idaho
Yanmar 2420d
Getting this unit setup with BH attachment. Has the V2A Vteks FEL. BH weight is 1,000# dreaded 3pt. Going to get material tomorrow to secure the backside to the FEL frame. Moved the BH with FEL out of a pickup, counter weight 55 gal barrel mounted to the three pt filled with water. So far so good. It is a self contained BH. Great to have this site for info. Slow but sure. Think I'll invest in the wheel spacers for stability insurance. 2420d.
/ 2420 BH attachment #2
Looking forward to pictures. I would love to have a BH even if only to play in the backyard!
Where did you get your backhoe?
From Betst Products in Oregon. I need it for small projects around my place an cannot get access with a regular sized BH, also lost my drive to hand dig.
/ 2420 BH attachment #4
Watched their video. Nice looking smooth operating backhoe. Seems like a good price too. Congratulations! :thumbsup:
/ 2420 BH attachment #5
Pics,more pics. Did i mention we Love pics.
Well a work in progress, like mentioned slow motion here, no blood was spilled so far. Hope the pictures open up. Used 3" bar stock was in search of 4" but thankful I went 3" got a 10 foot piece for $46.00. Used 4' on each side. Plan is to use chain an turnbuckle off the end of the frame ( see bolt through pic) to BH attachment too spread the load and stress. Not up in smoke yet!
Also swapped the rear tires for a wider stance. The wheel spacers offered by Doyle look good but the left side has three larger
lugs 1-inch so not sure if that will work.
Tractor and backhoe attachment worked great at 1600 rpm. Will probably be the deepest I'll dig around this place 5.5', installing a flow control valve on the well pipe line to a 3,000 gallon underground tank. Backhoe in service.jpg
/ 2420 BH attachment #8
Wow, really looks good. Yup wider the better. What size output is the pump? Can you add the seating area pic, a little better view plz.
Here is a view from the driver seat. Not sure of the hydraulic flow on the attachment, call Betstco 877-876-7895 for specs. For me they are good to deal with got the BH attachment at a lower listed price an a upgrade from 12" to 16" bucket no charge. ATTACH=CONFIG]467632[/ATTACH]
/ 2420 BH attachment #10
View attachment 465533View attachment 465537View attachment 465538
could you show a few more pictures of how you hooked up your backhoe, looking for ideas.
thanks
thanks
Well I didn't get all of the photos of the initial installation out of the crate to the tractor. Had to set the BH attachment up on blocks to get the drive-line connected to the PTO sort of a balancing act, once up on blocks I strapped it to the tractor so it would not tip over. Once the drive line was hooked up it was a matter of dropping the out riggers an extend the backhoe out straight. Then it was easy to lineup an pin it.
I'd post more pic's etc but I am on a limited bandwidth with satellite Internet, exceed the limit during the 30 day rollover period then it is reduced to dial-up speed = "useless".
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
725 Gal Poly Tank on Skid  (A62679)
725 Gal Poly Tank...
Concrete Mixer (A62613)
Concrete Mixer...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2010 FORD RANGER SINGLE CAB PICKUP TRUCK (A59914)
2010 FORD RANGER...
Backpack Leaf Blower (A66408)
Backpack Leaf...
