Do your own Fluids and Filters on a BX
   / Do your own Fluids and Filters on a BX #381
How does SUD2 give you better starts? I hope you're not putting it in the motor...........
First, no gear whine in my B7800. I had whine with a different brand and by better starts I mean that there is less hesitation and a faster response when I step on the pedal. My guess is the SUD2 is a full synthetic and if you found another full synthetic it would probably work. It wasn't worth my time so I'm going with SUD2. It's not the cost of the SUD2 that's the issue but rather the difference in price between what you might substitute and the price of the SUD2. It's probably $10 or $20 or whatever and that's no big deal. It's not going to make me poor or Kubota rich so I'm OK with it.
   / Do your own Fluids and Filters on a BX #382
I posted this elsewhere but it should be here.
I just did my 50 hour maintenance, and most likely a lot more.
I used Amsoil synthetic for everything.
-Engine oil and filter went good (color was dark)
-Hydraulic filter went good (color of oil looks like new still)
-2 fuel filters (bottom was a little PITA, but doable) (saw some junk in the first filter near the tank, both were darkish in color, could be normal)
-The mower gear oil was very clean but I wanted my synthetic gear oil in and it does not take a lot at all, my deck is the 54" fine cut. (color of oil looked like new)
-Now I also did the front axel, I drained both sides then filled, my manual states 5 Qts of oil, as I found out the hard way my front axel really only takes less than 3 Qts., yea I had to use a baster to suck out the extra (took some time, but it worked) I don't know if any of you did this and what your manual states but mine is wrong by 2 Qts. the old axel oil was dirty also glad I did it.
Any other BX 2370-1 owners notice this front axel fluid not taking 5 Qts.? I think mine takes what the BX1870-1 takes and specifies. I also think the book should state to change the front axel at 50 hours as mine was dark and it was extremely easy to do.
   / Do your own Fluids and Filters on a BX #383
I got only 3qt in it when I changed, but eventually got about 4.5qt in. I believe it's been discussed that air gets trapped and by using the machine it works it's way out and you can get more fluid in.
   / Do your own Fluids and Filters on a BX #384
I read air gets trapped but I did not think it was that much. I just had to add 1/2 Qt more.
Thank You
   / Do your own Fluids and Filters on a BX #385
Thank You
When you're all done it will wind up taking pretty much what it's supposed to. Lots of posts and threads on this.
I agree and if it doesn't you probably didn't get all of the fluid out. If it's difficult to get it filled I would think it would also be more difficult to get it all removed.
Many posts concerning front drive low on fluid on BXs from dealers. I've owned many BXs along with many other Kubota models and always keep checking front for first few months to ensure front at proper level. Nature of the beast, settling or filling voids or whatever is happening. I've never changed the front fluid on any Kubota I've owned. Any I've checked always looked like it was just added on the dip stick. I also don't change fuel filters until there is a problem so only done it one time over 12 years and around 20 different Kubotas.
I do change engine oil and all engine oil and transmission/hyd filters at 50 hours with Kubota oil and filters from Barlows, local Kubota Dealer with never any issues.
Also change deck gear lubricant with gear oil at manual given hours, I think 50.
I say do what makes you feel good and satisfied that your giving your machine your best.
   / Do your own Fluids and Filters on a BX #387
Just out of curiosity
1. when you change the hydraulic filter do you remove the metal protector or does the filter just make it, I removed mine but not sure if I needed to, thats why I changed the fuel filters.
2. Every 50 hours, the book does state longer intervals ? I know it is a personal preference, any technical reason to do it so often or something you read, I am just curious and prepping myself .
3. did you ever change the hydraulics and at what interval? Is there any bleeding of lines involved ?
Thank You
And thank you all for your replies, very appreciated!!
Not sure what your asking?
I think the owners manual says first one is at 50 but I follow manual. Manuals have changed over the years and I have different models but I do when the owners manual says for the particular model.
Thank You
I do or have changed the hydraulic fluid and use SUDT/SUDT2 for all hydraulics and again, just when the owners manual for the particular model says to do it. Some years ago the interval was 50/100/200 hours but the interval time has expanded over the years. This will start the great debate of doing it sooner because of cost of machine, etc., etc., I follow Kubota owners manual for the particular model and year, sleep good at night and feel good about doing it that way. No line bleeding except occasionally if I can't get the FEL hyd lines connected back on after removing FEL then I open a hyd line fitting to release the built up pressure so the fitting will hook back on
   / Do your own Fluids and Filters on a BX #389
Thank You, I was just curious on what you did.
Thank you for taking your time
   / Do your own Fluids and Filters on a BX #391
Thank You,
My BX2370-1 has a protector shield under just before the hydraulic filter, I have to pull the shield off to change the fuel filter and maybe also the hydraulic filter. I pulled the shield but was wondering if I even needed to pull the shield off to change the filter, I think I do as its tight and most likely no way to get some tool in their without pulling the shield.
Each model has some slight differences and I've never had a BX2370-1.
Maybe some BX2370-1 owners will respond to your question.
   / Do your own Fluids and Filters on a BX #393
I just did mine again for 600 hours. Did the front axle, hydro, and engine oil. Used SUDT, two new filters, and Amsoil 10W-30 for the oil. I also switched to a grease, Amsoil 75W-90 in the front axle. The front axle oil was pretty dirty and needed changed pretty bad, the hydro fluid was an amber color instead of clear but was probably good for another 100 hours or so. One thing I forget was how much this process cost. I didn't keep an exact cost, but I'm betting it was around $300.
Didn't think it cost that much for engine oil, filters, grease and hyd fluid. :eek: Anyone else paying that much?
   / Do your own Fluids and Filters on a BX #395
I'm not sure how I came up with $300. I revisted my numbers and its more like $150 to $175.
   / Do your own Fluids and Filters on a BX #396
The price can easily be well over $200 for parts if using all synthetic. Amsoil is good stuff, but the cost adds up quick!
   / Do your own Fluids and Filters on a BX #397
all fluids done with Amsoil synthetic before amsoi customer preferred program $263.05 + $18.75 ship + $16.44 Tax TOTAL = $298.24 Fluids only needed for one change and one grease cartridge.
$212.23 after Amsoil preferred discount shipped with tax.
now we need the filters
$9.29 oil filter
$11.75 Hydraulic Filter
$14.52 for 2 fuel filters
$20.46 Air filter
$12.75 ship and/or Tax
$281 on filters and oil total today ( as tomorrow may/will be even higher) with the Amsoil discount program
Seems like very close to 300 to me
Amsoil oil is going up as of august 1st 6%
Maybe you had some liquid refreshment(s) and included the price for them in the total. :laughing::cool2::drink:
   / Do your own Fluids and Filters on a BX #399
I also overfilled my front axle, mowed with it two times, the level dropped, and I added another quart yesterday. I'm not sure why it takes so long, or where the fluid goes, but it seems to take a while for it to show up low.
Apparently there are nooks and crannies or air preventing filling. Seems to be a common issue and real common on new BXs.
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56438)
Bulk Lot of over...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
