The things that we do and why...
/ The things that we do and why... #21
Thanks guys.........Guess it wasn't my time. BTW, the power company guys did a great job of restoring electricity....in less than four hours. The nice thing about downed and dead trees ...............It's Fall Party & Bonfire Time!!!
Cheers,
Mike
Glad you are still around Mike, roast a hotdog for me later..:)
/ The things that we do and why... #22
In almost all the cases, someone failed to first make an undercut when cutting a limb off, so they lost control of it and it landed tip first. Properly cutting a limb typically requires three cuts. The first two cuts are to remove the limb and are slightly out from the final cut. The removing cuts are an undercut, and then a top cut slightly out from the undercut. This should result in the limb breaking off cleanly and landing butt first (or nearly so). After the limb is removed, a final cut is made to remove the stub at the "branch bark collar".
This is also true when using a manual pole saw. Sometimes you have to adjust the blade (change the angle or flip it around) so you can make the undercut first.
I was thinking that the limb might of come down better that way to, but that high up on a ladder, I don't know, still might of went wrong if Murphy was there.
/ The things that we do and why... #27
If you do it once and it does not work out , that is ignorance . IF you do it again that is stupidity .
/ The things that we do and why... #32
I never thought of Channel Loks as an essential forestry tool before.
I usually reserve accordian felling for smaller trees; I think I would have just dragged the butt out with a truck or ATV winch or something.
/ The things that we do and why... #33
This is why you hire a tree removal specialist...:) 172390.gif
/ The things that we do and why... #35
Cut it ALMOST all the way (leaving a good hinge), get down, remove ladder, THEN pull on rope. :)
Bruce
/ The things that we do and why... #36
It is hard to tell from the video clip, but it might also have been possible to reach the cut line from the roof. When you are on a ladder, there is no clear line of retreat (I don't count "down" as a clear line of retreat!).
There are lots of videos online of ladder-felling disasters.
/ The things that we do and why... #37
Or start by taking off all the limbs and trunk above there and then take down the trunk in shorter sections.
Bruce
We'll maybe but where does the rope go and how did it get there,?, the ladder didn't look to tall. I could pull a 100lbs. so how thick is a 100lb. good hinge, I suppose if the neighbor comes over half in the bag and says hold my beer, that would increase to 500lbs. of pull, depending on what brand of beer......
(I don't count "down" as a clear line of retreat!)<<<<<<<<<<<good point, me either........
That plan might require a different taller ladder, but that also sounds risky. I beginning to think from what I've seen, cutting trees or tree parts from any ladder is a bad idea and or unsafe, but can be funny if no one gets hurt.
John Deere 348 Square Baler (A65579)
John Deere 348...
Brown 826 (A64119)
Brown 826 (A64119)
Decorative Pelican Statue (A61574)
Decorative Pelican...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
