Ideas for bending cattle panels?
/ Ideas for bending cattle panels? #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
I'd like to bend two 52" X 16', unwieldy cattle panels into 'U' shapes like the attached sketch. Galvanized 4 gage, .225" wire.
Any ideas?
/ Ideas for bending cattle panels? #2
Do they need to retain this shape on their own?
If not, set some t posts in the shape you want and start attaching the panel to the posts with wire. You could put the posts inside the panel or outside, wouldn't matter.
If it does need to be free standing, I've had luck bending the panels one wire at a time using big pliers.
/ Ideas for bending cattle panels? #3
Mine are all bent... Tree fell on garden and smashed them all.
If I had to do what you want to i would be looking for the proper size tree to bend them around
/ Ideas for bending cattle panels? #4
I've done some bends by standing on the panel, near one end, and picking up that end. Then just hang on and walk backwards to the area that needs the bend. Change grips as needed. With a little practice, you can stomp in a pretty nice bend. An assistant is a big help.
/ Ideas for bending cattle panels? #6
Two trees the right distance apart, fence against trees, one old bull against fence and one cow on the other side of fence.
Of course a vertical log instead of the bull and pull with the tractor might do it.
/ Ideas for bending cattle panels? #7
Lay the panel on flat concrete, set a portion of your loader buckets cutting edge on the panel at the beginning of where the "U" shape should start, lift the panel trying to bend it some, preposition the bucket back a few inches and bend some again. Do this until you get the shape you want.
I made a sharp 90 degree bend it one of these panels for a dog fence like this. I needed a hammer for the sharp bend.
/ Ideas for bending cattle panels? #8
I have made a few hog traps in shapes not unlike what you show with the ends on one side overlapping. All secured to T posts except for one inside panel, so they push against the panels all around trying to get to the bait until they find the one that lets them get in then snaps back towards the outside, trapping them.
You can actually secure the top of the one that moves inward letting them in so they can bend in the bottom to get in but cannot lift it up to get out.
Other than that the best way I have found to bend them is to try and keep them flat ;).
/ Ideas for bending cattle panels? #9
we cut them to length with angle grinder than clip them togeather to form the shape. use them to pen up ewe's with new lambs for a day or 2
Greg
/ Ideas for bending cattle panels? #10
You may can find a barrel or fuel tank, tree, rear tractor tire or such that you can use to bend the panel around.
/ Ideas for bending cattle panels? #11
t
Makes me think that a wooden wire spool would also work very nicely. Could be set up in a number of ways and should make a nice smooth bend. Fix the spool and use it like a pipe bender.
/ Ideas for bending cattle panels? #12
t
Very good idea.
/ Ideas for bending cattle panels? #13
I'd try something like this. Lay the panel on flat ground with a 4x4 under it that you can chain to the top of your bucket. Press the cutting edge of your bucket at the bend point and curl while maintaining down pressure. It may require re-hooking the 4x4 depending on how much rotation the bucket has. Pardon the crude drawing.
EDIT TO ADD: If that doesn't pull a tight enough 90 degree bend, you could substitute something like a piece of plywood for the 4x4 that extends from the chains to the bend point to avoid the "belly" that could happen on the piece you pull upward. The piece on the ground is probably OK.
/ Ideas for bending cattle panels? #14
set two heavy posts, the distance you want apart, (maybe chain cross the top of the posts)
take a curved some thing, ( a few inches short of the width of the posts, and hook a chain on the curved thing, and pull the curved thing through the posts with the panel between the posts and the curved thing,
since there are long wires on one side and the short wires on the other, and the long against the posts, and the curved against the curved, thing.
the some thing could be an (old cable spool with some 2x4 nailed on the out side curve, to put even pressure on the inside of the panel).
/ Ideas for bending cattle panels? #15
another thought is to put two posts in about three inches apart, put the panels in between the the posts, and pull on one end and bend it some move it and bend a little more and keep moving it and bending every little bit until you have the bend you want, may take two or three people to get enough power to ben the panels,
/ Ideas for bending cattle panels? #16
They bend very easily. I would just set two steel posts 4' apart and then tie one end to one of them and bend the other around to the inside of the second. Then you can just start pushing on the sides until you get the bends where and how you want them. A third T-post on one side may help to push against. It all depends on how precision you want but 10 minutes should get you a couple of panels bent.
/ Ideas for bending cattle panels? #17
They do bend easily. When I buy them at TSC, I bend them into this shape to get them in the bed of F350.
2021 ISUZU NPR (INOPERABLE) (A63569)
2021 ISUZU NPR...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59910)
1996 FRUEHAUF 45'...
SET OF (3) HYDRAULIC HOOKUPS (A63569)
SET OF (3)...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
Caterpillar 302.5C Mini Excavator (A61572)
Caterpillar 302.5C...
