Is it time for a gasoline engine tractor?
/ Is it time for a gasoline engine tractor? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Considering all the angst and disappointment over TIER IV diesel engines and tractors, is it time for a manufacturer to bring back a gas engine tractor? I mean, they worked well for lots of years under lots of conditions.
My understanding is that Kubota currently sells gas engines to repower diesel tractors?
/ Is it time for a gasoline engine tractor? #4
Carefull. Somebody will use thier experience with 1960's gasoline and diesel tractors to make a decision in 2016.
Since the EPA was unsuccessful in it's efforts to make the Tier IV diesel too expensive to purchase and operate. Tier V diesel regulations are on their way.
Some people are not familiar with light duty, medium duty and HD operation.
/ Is it time for a gasoline engine tractor? #6
Would not be surprised to see these in carrier transicold units. I might even venture to say it was part the reasoning for the new line. It's hard enough cramming it all in a little box but add a lot of emissions to it also would be a lot. I believe they use Kubota diesels in those.
/ Is it time for a gasoline engine tractor? #7
If they make a F.I. gasoline engine, it may be ok, they seem to stand up to the ethanol gas without varnishing up. I would never buy a gasoline tractor with a carb. I do hope the ones I have last me a lifetime. Stricter gov. regulations and more BS might make my interim tier IV more valuable in the future.
I would think that engine manufacturers could come up with a diesel that meets the federal requirements and not cause a ton of BS with urea, regen etc to aggravate the user.
/ Is it time for a gasoline engine tractor? #8
The manufactures are no more able to break the laws of physics than you or I are able to.
/ Is it time for a gasoline engine tractor? #9
/ Is it time for a gasoline engine tractor? #10
Our Troybuilt already HAS a gas engine.
/ Is it time for a gasoline engine tractor? #11
/ Is it time for a gasoline engine tractor? #12
Where does a compact tractor fall? Id say medium duty at best.
Trying to use light duty, medium duty or heavy duty in relation to compact tractors is a waste of time. The formal definitions of those terms generally apply to trucks, not tractors, and are based upon weight.
If modern CUTs weren't considered heavy duty/continuous use engines the manuals would specify an acceptable duty cycle (actually a drive cycle if you want to get picky).
Has anybody seen a line in their manual that tells them they can only run at PTO speed for a given time or damage will occur? What people traditionally call light and medium duty engines aren't rated for the equivalent of PTO speed indefinitely the way tractors are.
/ Is it time for a gasoline engine tractor? #17
We've got two D-17 Allis-Chalmers in the shed right now with over 4500 hours on them that are gassers. Doubt any new EPA compliant gas engines would resemble those now. At 60 engine HP they get awful thirsty. But they were stone cold reliable. Hopefully the EPA will stop the insanity but too many people are getting wealthy changing the regulations on emissions every four or five years. Guess who is paying?
/ Is it time for a gasoline engine tractor? #19
I'd settle for one that uses politicians.
2nd that & buy older tractors w/o the crap on them. IMO, the EPA dosen't have a clue about this & is just stabbing in the darkness.
Ronnie
/ Is it time for a gasoline engine tractor? #20
yeah right!!! For decades they said they were making the engines as fuel efficient as possible but they only got 10 mpg with a best in class of around 20 mpg. Now after feds mandated better fuel economy for decades, we now have 300+HP engines with 31MPG claims (Dodge Charger/Challenger) so the laws of physics change over time especially when government steps up and demands it. I can still remember the automakers claims that it was not possible to make car engines to meet the requirement but they did when faced with possibility of heavy fines and/or not being allowed to sell their products. So far they continue to make the engines more efficient and also with more HP.
I think they can do the same with the diesel engines if they have too. Right now they are just scabbing on whatever they can come up with to barely meet the environmental requirements and we all know they can do something better than Urea injection. A double turbocharger comes to mind to prevent the carbon from forming in the first place. Maybe even an electric motor driven one like I see proposed on a new model car to reduce the turbo lag.
Lot of things they could do, but the price goes up. Right now they are just getting the minimums with minimal effort but causing the public a PIA with the operation and maintenance of these new Tier IV engines.
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
1042 (A60430)
1042 (A60430)
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2015 FREIGHTLINER...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
