Your towing rigs and trailers
/ Your towing rigs and trailers #2,501
Nice looking new rig (and old one for that matter)...congrats!
What engine did the '09 have in it, and how does the 6.2L compare?
Congrats on post #2500, we only got the new F-250 yesterday, and i havent seen or driven it yet, although i will probably do both later today. The old one was the 6.8L V10, with 4.10s and the new F-250 has the 3.73 rear end. Ill update this thread when we have some miles on the new one, and have pulled with it.
/ Your towing rigs and trailers #2,502
The new to me trailer and fresh gooseneck hitch install loaded with mowers.
/ Your towing rigs and trailers #2,503
It will be interesting to here comparisons from the V10 to the V8. I've heard great things about the 6.2L, so hopefully it works out well for you.
/ Your towing rigs and trailers #2,504
I'm interested to hear your findings
/ Your towing rigs and trailers #2,505
Towed with this from OK to CA running 75 mph up all the passes on I 40. Cummins power with a few mods in my home shop including transmission that I build and BD torque converter.
/ Your towing rigs and trailers #2,506
Wow that's a nice shop!
Side note, pulled right around 20,000 lbs the other day with the 6.0L freshly BulletProofed and the mild (labeled 50 HP) tow tune... Very impressed. Had great power. Total rolling weight was 28760 (scales). No complaints right now :D
/ Your towing rigs and trailers #2,507
Not to derail this thread too badly but what sort of footer is under that job crane? Reason I ask is I have access to a nearly identical crane but have no footers in my slab.
Awesome shop, by the way!
/ Your towing rigs and trailers #2,508
It is 7' x 7' x 7' with two layers of #6 rebar on a 6" grid and the bolts are 6' long with plates on the bottom. I have more shop info on the Garage Journal.
/ Your towing rigs and trailers #2,509
7' deep, that's a heck of a footer but that crane with a load out at the would put a extreme amount of force on the attachment point.
Thanks for the info.
/ Your towing rigs and trailers #2,510
I can only imagine the diameter of the 6' long bolts....
SKLP SK-SYLJ100 Hand-Use Hydraulic Track Pin Press Machine (A60463)
SKLP SK-SYLJ100...
2016 Terex RL4 Towable Light Tower (A60352)
2016 Terex RL4...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2017 Case CX145D (A60462)
2017 Case CX145D...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
