JD 5303 Dead
/ JD 5303 Dead #1
MF283
Lebanon, TN
JD 5303 JD 920M JD825I XUV Gator
It ran/started great yesterday, nothing today.
Checked/cleaned all terminals
Battery, starter , fuses showing good amps
No lights, not even a click when the key is turned:confused3:
Any ideas?
Thanks
Ronnie
/ JD 5303 Dead #2
No specific idea, but... it has to be something that is common to everything electrical.
The key switch itself?
/ JD 5303 Dead #3
Yep^^^
Check power on both sides of the fuse box? If you don't have a multimeter go out and buy a good one.
/ JD 5303 Dead
Thanks guys, something was telling me to check the key switch, after removing a coil spring tower from the truck, cleaning all connections & checking amps was as far as i made it yesterday evening on the tractor.
Hopefully, the new coil tower will show up today & i'll get back to the tractor in a day or so.
Ronnie
/ JD 5303 Dead #5
Have you unbolted the were the neg terminal from the battery connects to the frame. It may look clean on top but the bolt could be rusty.
You said no lights, but it could be a safety switch problem. There is only 2 safety switches PTO and neutral switch. You can try using JD parts to help locate the switches.
I have included a picture and write-up on the 5303 starting system. You can use this to start tracing the problem.
John Deere - Parts Catalog
  • 5103 5203 5303.pdf
/ JD 5303 Dead
Thanks JD5210, i have another project in the way at the moment, it will be a day or two before i can get back to it.
Ronnie
/ JD 5303 Dead #7
Thermistor. Unplug its pigtail and it will start. Sensor is in front of block, coming out of thermistat housing, pigtail is on left side near the injector pump. Very common problem. Replace when you get a chance.
/ JD 5303 Dead #8
What I was thinking too until I saw where he said no blown fuses. Been following to see what he finds. Just had to unhook mine on 2008 JD 5303 last week or so to get back going. Still haven't changed the part.
/ JD 5303 Dead
Finally got back to it today, checked all in-line connections & sprayed them with contact cleaner, checked the switch, changed out all fuses, NOTHING.
I cleaned the in-line fuse connections near the cluster & took cables off battery, cleaned the fire out of them again, removed battery tinder cables & hooked everything back up, RUNNING:fing32:
The battery tinder leads had some rust on them, whether that or i just plain didn't clean connections good enough the first time, glad it was a simple fix, dealer was ready to come & get it if i wanted them to.
Ronnie
/ JD 5303 Dead #10
I've had a periodic no crank issue with our 2002 5303. If you fiddle with the right shifter for a while, you can get it to start up so I'm fairly certain it's the neutral safety switch. JD parts diagram only shows the switch but not the location. Anyone know where it's located on the tractor?
Thanks for any input!
J
/ JD 5303 Dead #11
Hopefully the picture at the bottom of this attachment helps you. The wiring diagram shows 2 wires to it an orange 573 and a brown.
  • neutral_start_switch.pdf
/ JD 5303 Dead #12
That's a huge help!! I'm far from being a mechanic but I think I can handle replacing that. It'll sure save paying a service call!
Thanks so much!!
Jenn
/ JD 5303 Dead #13
here's all I could find in the tech manual on it,
if you shoot me you're email, I have a PDF of this manual you're welcome to -
Joe
