OP
- Joined
- May 12, 2004
- Messages
- 13,264
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Thanks. Good data.I have 2 that I have made, one about 7' wide and the other is 4 1/2' wide. Both have 4 crosses 2 on a angle and the back 2 stright. The 2 front ones have old grader blades turn around so the edge well cut better with the angle iron at 45 deg. I set the 3pt hook up to float and use the 3pt to do my adjusting while gradeing. I added 1' of skid plate after the last cross and as I get to the end I raise the 3pt up slow until it rides up on the 1' add on. That way I leave no piles, also the 1' add ons are turned up a little. I also made places to mount weights when I need to.
