Anyone own a 2540?
/ Anyone own a 2540? #1
jmh1783
Darlington, PA
Mahindra 2555 HST
I visited my local dealer again yesterday. Drove the 2540 again. I was wondering if anyone had any feedback on them? It looks like it has the same 2.7 liter engine that the 4540 has just tuned differently. 2650 vs 2058 RPM to get PTO speed. How is the 2540 on fuel? Anyone mow/brush cut on hills with it? Does it have enough power for up and down cutting? I'd be using a 6' cutter.
Anyone plow with one? I've been going back and forth with the 4540 and figured the extra weight would be better for plowing. The new property I'm buying has at least 1/4 mile of driveway. However I have pasture to mow and am concerned that 5200 lbs might be a bit much. The 2540 is lighter and should have less of an impact. The soil here is dense clay with some rocks.
Thanks for your help.
/ Anyone own a 2540? #2
A number of us have the HST version of that tractor, (2538 HST), and everyone seems to love it! Check out this thread: http://www.tractorbynet.com/forums/mahindra-buying-pricing/348064-info-mahindra-2538-a.html
The 2540 has slightly different specs, notably a more powerful loader. A few nuances too like a standard suspension seat and the foot guards are clear instead of metal.
I use mine for loader work with a grapple, dirt moving, and running a 6' rough cutter. It is a beast and cannot be stopped so far. Very stable, loads of power for my needs, and reasonable on fuel. I have not done a gallon/hr calculation, but perhaps one of the other 2538 HST owners have. A 2540 should be a bit better too as it has an almost identical engine and is more efficient without the hydro loss.
LA Confederate has some great videos of his 2538 ripping up a food plot on his property with his box blade and then with a plow as well I believe... I could only find the box blade vid
There was a picture on the garden forum of his 2 bottom plow work. Sure looks nice and here is the link. http://www.tractorbynet.com/forums/...your-garden-grow-post4424113.html#post4424113
Good luck with your decision!
Thanks Snowback. I have read all the stuff on the 2538 including the videos. Looks like a great machine. I was attracted to the higher lift capacity of the 2540. I did make the mistake of driving a 2538 cab model and I think I'm coming down with cab fever however the additional cost will likely keep me in check. As I've told the dealers I've been talking to, I can either buy less tractor and more implements or more tractor and fewer implements. :) I'm glad I still have time to make a decision.
Have you had any issues with your 2538? Anything you wish it had or perhaps added later? A lot of the tractors I'm looking at are missing the telescoping 3pt arms. From what I've read the solution is either a long crowbar or a quick hitch. How do you deal with manhandling heavy implements?
/ Anyone own a 2540? #4
I love the 2538. HST was a must for me as I do only a little true straight line ground engaging. Mostly loader and cutter work in the woods where i need to moderate speed frequently. A cab would be great, especially in the summer down here, but I would have it torn off in about a week in the tight woods.
As for implements, I find that I use my low back and a stray 2x4 that might be laying around, probably should get a big crow bar as that would make things a lot easier. Quick hitch is something I am interested in as well, but I use a 3 pt mounted drawbar to move my transport trailer around, so there would still be lots of on/off. In all honesty, I have found hooking up the 6' MD cutter and 6' HD box blade easier on this machine as compared to my prior Max 25 with 4' implements. That was a much smaller setup, but more pain in the rear. I am certain it is because of the clevis pins and brackets I went with on the heavier duty implements. I can back into where I last dropped it off, (as level as possible), and then lift the arms till it basically lines up. Then slide pins in through implement clevis brackets. Some wiggling involved, but much easier than trying to wrestle the lower 3pt arms around the permanent single pins on lighter duty equipment. Just my 2 cents.
Now on what I needed - I did add two things. The suspension seat from the 2540, as I do a lot of rough terrain work, and also a cruise control option. The seat was +/- $300 after sharing cost with dealer on the initial purchase. The cruise control was around $150 installed and is an electrically actuated magnet that grabs and secures the HST pedal at the speed you desire. Makes long mowing passes and transport down the county road a breeze. It is a utilitarian/basic machine with not too many frills like cupholders, but it's heavy, powerful, and sturdy for a mid size CUT. (And it's very reasonably priced too!) Some others may have more refined Hydros and loader controls, but this beast has suited me just fine. Also if you drive it around again, note how tight a turning radius it has. I think it can corner as well as the smaller Max did.
Not sure if it matters to you, but this machine with implements can still be hauled around with a half ton as well - barely...
Good luck!
/ Anyone own a 2540? #5
/ Anyone own a 2540? #6
Is the 2540 a slightly larger frame than the 2538?
I might be wrong, but I think the overall chassis/frame is the same. The HST changes up the tranny configuration of course, but when they were sitting side by side it looked the same to my eyes. (With the exception of the loader, seat, and deck shields, etc... Engine specs look a touch different, but I think that is tuning and HST effects. Maybe a dealer can straighten us all out.
At this link, the "Dimensions" and "Tire sizes" are identical - http://mahindrausa.com/sites/default/files/tractor/pdf/23386 MAH542500 2500 Ser_8pg 051216 (1)_1.pdf Doesn't look like the cab was available on the 2540 when this went to press.
There isnt a 2540 cab unfortunately. The 2540 gets a more powerful loader which is a head scratcher. The frame size is the same as the 2538. The engine thing is a pet peeve. The 2540 has to go all the way to 2650 rpm for PTO speed while the 2538 gets there at 2400. Weirder yet it looks like the 4540 has the same engine and it does it at a lowely 2058 rpm.
Snowback: You mention haulling around a half ton, I assume you mean logs like your picture or a trailer. I cant imagine you have many hills in your area. I wonder how the 2538 would deal with the load on a hill. Might be a bit much.
mike69440: No cab 2540. Would be nice. Mahindra actually has one of the better websites. None of them are that great. You should check out Branson's. Its dreadful. There are mistakes in their online data that contradict their pdf brochures. The printed brochures contradict the website and the pdfs. I was interested in one of their smaller tractors a 4015 which only shows gear models online. My dealer said no, they are availabe in hydros. Go figure.
/ Anyone own a 2540? #9
For clarity - when I said "this machine with implements can still be hauled around with a half ton as well - barely..." I meant that I can move a fully loaded 20' trailer with tractor and implements safely using my Ram 1500 half ton truck. Sorry for being unclear, but that is funny... :cool:
As for the tractor, I am certain it can haul around many tons on a trailer. It pulls my 2,400# equipment trailer like it's not even there in mid range. Our property has no really steep hills, but I do mow brush and tall weeds up and down a little bit of a grade from front to rear of the property in mid range, and there is no discernible difference from when mowing going down the slope. It would really be great if the dealer would let you try it out for an hour or two to make your final decision. Always is best to be certain that the machine will meet your needs. If you think about it, this mid size CUT with 38HP has a very high power to weight ratio relative to the very large CUTs. It's still a medium large CUT with lots of built in weight, but its a bit more nimble and lighter of foot than say a 3540 HST or something of that sort. (Plus it has very similar power...)
Below is final clarification of my "half ton comment".
/ Anyone own a 2540? #10
You're right jmh1783 - I've looked closer at Mike's link. That Campway dealer is either confused, or being deceptive. Clearly they used the same picture for their advertisement of the "2540 Cab" and the "2538 Cab". And in both pictures it is indeed a 2538 HST. In the description of the 2540 they also say it is available if HST... :laughing: I think they are just confused...
If you are concerned about ground engaging power, I would encourage you to private message LA Confederate and ask how he likes the way his 2538 HST handles his 2 bottom plow. I think that would be a really good testament to grunt and capability. His garden rows sure look good!
Take care!
/ Anyone own a 2540? #11
Take care!
The 2540 Cab would have bee a strong recommend to a friend down the road who very much wants a Cab for winter and summer duties but wants a smaller wood hauler and a strong loader for yard work. He lives on a privately maintained rural road. I really like the huge front tires.
Snowback: I like your hauling setup. I don't own a pickup and probably won't be getting one. My commute is too long. In any case the only reason I'd need to haul my tractor is to the dealer. Hopefully I won't find that economically justifiable. :)
I'm kind of conflicted on the cab idea aside from the expense. It would surely be nice to have AC while mowing for 3 hours in our hot humid summers. On the other hand I feel a cab separates you from the outdoors. The major reason I'm buying property is for the outdoors. I'll probably go with the 2540. I had never driven a gear transmission before starting my tractor hunt. Never learned to drive stick in a car. I did learn on a motorcycle but they don't really count. I was sure I'd prefer HST but I like the gear better. My back and forth loader work will be occasional at best.
Has anyone looked at the TYM version? My closest dealer is an hour and a half away. Looking at the specs and the owner's manual I can see why TYM bought Branson for their engines. The Mahindra engines are much better.
/ Anyone own a 2540? #13
I'm a gear guy, but straight gears in a tractor are a pain. HST can be a pain too. My Mitsubishi Max28 has a good shuttle. I usually have no problems shifting on the fly and I really like the way it shifts. I wonder how the TYM shuttles are? Loader work is easier with an HST, but for my use, I like shuttle.
/ Anyone own a 2540? #14
Just a quick tip on Cabs... windows are expensive... you will be puckered working around any trees once you pay for the first one... its a well put together set up though the 2538cab
/ Anyone own a 2540? #15
Id go with the 1538 over the 2540... and the 4540 as well
Navasot: Good point. The new property has 5.5 acres of woods but I dont intend to take the tractor in there. I didnt like the rocker pedal on the 1538. I also got my foot trapped between the forward part of the pedal and the brakes.
/ Anyone own a 2540? #17
Hi there! I know this is a few months old.. I just bought my 2540 a month ago, already have 19 hours on it and I am real impress with it plenty of power to spare. I got with a standard duty rotary cutter and a box blade and FEL. I went with the 2540 just because it has a little more power on the PTO.. I used the toy 7 hours and it only use a little less than 3 gallons.
/ Anyone own a 2540? #18
I test drove a 1538 HST and couldn't wait to get off of the thing finding the rocker pedal awkward and uncomfortable. I bought a 1538 shuttle. Maybe a two pedal HST would be better but then you'd have to get a TYM 2500 series machine if you want a Mahindra.
Thanks for the feedback. I ended up going with the 2555 HST. I'm glad I ended up going hydro. My pastures are very rough and I'm always changing speeds when mowing or even just driving across them.
/ Anyone own a 2540? #20
I think that's a two pedal so it might be a bit more comfortable to drive. I've never driven one but would like to sometime. It seems like a better arrangement but like most things I guess it's largely a matter of personal taste.
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
2007 JLG G6-42A 6,600lb 4x4 Rough Terrain Telehandler (A64553)
2007 JLG G6-42A...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
Hyster 50 5,000lb Propane Forklift (A64553)
Hyster 50 5,000lb...
