John Deere 2440 No PTO
/ John Deere 2440 No PTO #1
Jperkins
Dryden
John Deere 4020 2440
I have just finished replacing the charge pump and one of the pick up lines on my 2440. The Hi-Lo works, the power steering works again, the three point hitch works, the only thing i cant get to work is the PTO. When i pull up on the lever it makes a whining/groaning sound but it wont engage. The tractor also makes a groaning sound at lower RPMS but clears up when given throttle (1800 RPM and higher). The groaning sounds somewhat like a power steering pump with bad bearings. Could someone give me somewhere to start with diagnosing this? Thanks!
/ John Deere 2440 No PTO #2
If this was my MF, I'd read up on the pto component of the 2 stage clutch and hope it was simply out of adjustment.
Its a hydraulically controlled PTO. No 2 stage clutch on this one.
/ John Deere 2440 No PTO #4
Darn, I even checked your tractor on tractordata.com must'a missed something. Good luck.
/ John Deere 2440 No PTO #5
Remove PTO engage lever between the gearlevers and check inside if the very small c-clip is still in its place ? To repair ...gearshiftcover must come off .
Alright so I pulled the shift cover off and it seems like the c-clip has fallen out. But I can not figure out how to remove the clutch control valve cover to replace the c-clip. Any suggestions?
/ John Deere 2440 No PTO #7
Remove gearshiftcover...remove plug infront of shiftcover...remove valve and replace c-clip...take care not to strip valve...replace and test !
Pulled the tractor back apart and found the fibers in the PTO clutch were destroyed. Starting with a new PTO clutch pack.
Yes the independent PTO clutch. The new clutch pack is in the mail. Ill update when the tractor is back together and working.
/ John Deere 2440 No PTO #12
Did you ever get your tractor running again? I assume so, my 1840 had a slipping PTO and it resulted in a new clutch pack, but the cause was a bracket on the internal hydraulic line to the PTO piston had chaffed and worn a large hole in it so PTO piston was not getting full pressure. New hydraulic line no longer has the bracket so unlikely to reoccur in my lifetime. Apparently this issue was common in the 1840/2440 machines.
2017 Ford F-250 Single Cab Reading Service Truck (A61573)
2017 Ford F-250...
2025 Swict 78in Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63291)
KNOW BEFORE YOU...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
