Danuser box scraper
/ Danuser box scraper #1
491ton
Member
Milton, Iowa
John Deere 3320 cab tractor
I just purchased off craigslist a Danuser HS-72 hydraulic scraper for $500 It has never been used, Just sat in a machine shed. Does any one out there have one of these? And is it as good as a box blade? Also will my JD 3320 handle it's weight when full of dirt? Thanks.
/ Danuser box scraper #3
That's a heck of a deal arround here. Well done.
/ Danuser box scraper #4
A 6' box blade is at the upper limit of what a 3320 will handle. Im sure flat ground will be no problem but once you extend the rippers and add an incline its gonna tax it good.
/ Danuser box scraper #5
Is this a wheeled scraper? Or conventional box scraper with hydraulic scarifiers?
Bruce
I'll get a picture posted, Its like a box scraper except the back is a hydraulic round scoop. Its awfull heavy.
/ Danuser box scraper #7
Is this what it looks like? Hopefully less abused.
/ Danuser box scraper #9
That looks like it does the same function as a wheeled scraper (dirt pan).
It lets you carry the dirt to the destination instead of having to drag it. The greater the distance, the greater the advantage over a regular box blade.
Bruce
Hedge Posts (A65640)
7 Barrel Masport Vac Pump (A62679)
7 Barrel Masport...
2018 RAM 2500 (A65643)
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2006 Toyota Tacoma (A66408)
2006 Toyota Tacoma...
