Drill bit sharpening
/ Drill bit sharpening #21
I am guilty of being lazy and not first doing a search on here for previous posts.... but,
has anyone had good experience with any commercial drill bit sharpening services?
I have just a few larger ones, 1/2" to 7/8" that I don't trust myself to do a really good job on.
A Drill Doctor will pay for itself in short order. Maybe you can get Santa to bring you one, he brought me mine.
/ Drill bit sharpening #22
No. Besides, most reverse helix drills (called reclaim drills) are tungsten carbide, not HSS and carbide takes a specific wheel, much softer than a conventional bench wheel.
What?! Tungsten carbide takes diamond tooling to do anything with it.
/ Drill bit sharpening #23
Green wheels work, Get diamonds for production or you girl friend.
/ Drill bit sharpening #24
The Drill Doctor 750 comes standard with a diamond wheel and will sharpen anything up to cobalt and carbide. Most concrete bits are carbide. The green wheels on the bench will also work as CalG mentioned.
/ Drill bit sharpening #25
Thanks for bringing this back (some) from the do-it-yourself crowd. I WILL try the very good local fab/machine shop; hadn't thought about that. I WILL NOT do these myself. I maybe should have more plainly stated at the outset, I suck at the required coordination to do a good job myself. Might be different if I had a sharpening rig, but for my amount of usage, a couple hundred $ for such a rig would be a real waste. Especially when there's professional services that will do a bit for $2-$3.
Sucking at something is the first step to being sorta good at something.
/ Drill bit sharpening #27
When I used to have the tool shop I found I could pay a machinist to stand at a grinder and sharpen drill bits or buy a Drill Doctor and have a flunky do it at a lot lower rate. The bottom line was that the Drill Doctor did it as well and more consistently than a machinist on a bench grinder and a lot quicker at a lot less cost. At first the machinists laughed but soon the machinists were just using the drill doctor if we did not have a sharp drill available.
/ Drill bit sharpening #28
In drillspeak, you have the lands, the heel, the point and the relief and all must work together to cut a cylindrical hole. I would suggest (if you offhand sharpen) getting a drill point gage.
The true test of a properly sharpened drill bit is you get equal swarf from both cutting edges when you feed the drill into the work with the drill secured in a drill chuck, affixed to an accurate spindle, such as a good drill press, a vertical mill or a lathe tailstock. Half arsed sharpening will suffice for cutting purposes, but the drill won't drill an accurate hole because the cut action is lopsided and that causes the drill point to run out and drill a non-concentric hole. In the shop, to offset that, we use chucking reamers to make oval holes concentric.
When both sides (heel and cutting edge) is sharpened properly and correctly, the line (center point) of the bit will be perpendicular to each side. That applies to ordinary split point drills and parabolic drills as well.
On drills over 1/4" 0.250, I always relieve the heel as well as relieving the heel allows easier drilling and also allows lubricant/coolant to reach the cutting edge easier.
I used to sharpen all my mills, I own a cutter grinder but it's actually cheaper to toss them unless it's a very large cutter, than sharpen them.
Offhand sharpening accurately and consistently is an acquired skill, just like playing a Guitar or TIG welding. Just because you do it correctly one time, don't mean you can repeat it. Takes practice and lots of it.
I don't throw any twist drill away until it's too short to work. For me, it's so easy to resharpen one, if a drill isn't cutting properly, I pull it out of the chuck and over to the Milwaukee bench grinder for a touch up and back to the machine... maybe a 45 second job.
/ Drill bit sharpening #30
I'm with 5030
if I don't like the way the drill is cutting, out it come, over to the grinder for a "dusting off".
I've been known to watch the chip formation and touch up the lip that needs attention. Somewhat easier on the lathe than the drill, as the bit isn't turning in the tailstock chuck.
/ Drill bit sharpening #31
Something like, You don't get good at something by not doing it! :)
Absolutely. Problem is, sucking at sharpening a drill bit only equates to a buggered hole (oval), or a buggered bit because of too much feed pressure applied. Practice on larger drills over 1/4" to sharpen (pun intended) your skill before trying drills under 1/4". I can offhand sharpen a 30 wire size bit with my magnifiers on. Any smaller for me is impractical, I can't see the end to get the relief right.
It's all in the hands. You develop the heel clearance with your left hand fingers while rotating the shank with your right hand fingers while maintaining the correct lead angle with both hands. Simple with practice. Frustrating for the inexperienced and why 'Drill Doctors' are always 'on call'.....:D Darex (Drill Doctor) builds some very fancy drill sharpeners as well as end mill sharpeners for many thousands of dollars. There retail Drill Doctor is just one of many models.
My issue with the retail store model is simply it's limited range. My shop drills run in all sizes from 1.5" down to a No.80
Sort of like TIG welding or Gas welding, keeping the filler rod in the gas envelope and feeding the proper amount in the weld puddle. Thats a 2 handed thing too. Not everyone can 'stack dimes'. Takes practice.
2 Row Cultivator (A64047)
2 Row Cultivator...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2007 Peterbilt 379 T/A Kill Truck (A64194)
2007 Peterbilt 379...
2012 T/A Frac Blender Trailer (A64194)
2012 T/A Frac...
