Does anyone use fuel additives?
/ Does anyone use fuel additives? #1
1720DnTennessee
Tennessee
1720D
I hear a lot of talk today about stiction in diesel injectors and the fuel additives that help prevent stiction. Is this actually a concern or just a marketing ploy by those that make the fuel additives?
In general are diesel fuels additives beneficial or should they be avoided?
/ Does anyone use fuel additives? #2
i use power Service in the grey bottle in summer in both my Kioti and C15 Cat. I use the same PS in winter in the white bottle. I don't have any issues with fuel jelling in winter. Whether it is snake oil or not, I don't care. I use it anyway.
/ Does anyone use fuel additives? #3
I use Power Service more for the Cetane Boost than anything. It helps quiet the Diesel knock just a bit in these loud yanmars.
I also mix in a little TWC two cycle oil. To add lubricity to it that sulfur being stripped out reduced. Its one of the best according to some diesel tech articles I have read for adding lubricity and its cheap. I add it at about the 150-200:1 rate.
After all the diesel fuel my tractor was designed to run on in japan in the late 70s is far different than the diesel fuel of today.
/ Does anyone use fuel additives? #4
Same here....Power Service for cetane boost.
/ Does anyone use fuel additives? #5
I use Power Service more for the Cetane Boost than anything. It helps quiet the Diesel knock just a bit in these loud yanmars. .... After all the diesel fuel my tractor was designed to run on in japan in the late 70s is far different than the diesel fuel of today.
Ditto.
On the YM240 ('70's design) Power Service as a Cetane improver definitely calms that awful racket at cold idle that sounds like a rod is about to come through the block. I've described the sound as sledgehammers on a manhole cover, it's that severe. PS also reduces smoke if it lugs down. Their claims seem to be valid.
Also Seafoam seems to be useful as a fuel system cleanup. But one bottle then quit, not continual. I bought a bottle of SeaFoam when I bought the most recent Yanmar (a second 30+ year old YM186D, 18 hp diesel, this second one has a loader) and the seller told me he thought it needed valve guide seals due to smoking on startup and under load. 5~6 tanks later with my Seafoam/PowerService magic diet, that startup smoke is gone and there's little smoke when working hard. He may have had it crudded up from light use. Possibly my mowing and tilling with implements intended for my larger Yanmar (see my sig photo, below) are working the little guy hard enough to burn the crud out. Or maybe Sea Foam can take credit for this cleanup. This one runs nice with or without Power Service, it apparently was designed for American-spec Diesel which is a lower Cetane content than Japanese diesel fuel spec.
And like clemsonfor I'm adding 1:200 two cycle oil but that's just to use up an old pint that's been on the shelf 10~15 years and I wouldn't run it in a chainsaw now, I think its old enough it would cause hard starting for the saw. I have no idea if its needed in the tractor for lubricity or that's just urban legend. I read that the early low-sulfur diesel had too much lubricity removed along with the sulfur, damaging a lot of automobile engines, but I don't know if that problem continues with the fuel sold today.
/ Does anyone use fuel additives? #6
Striction usually only happens in HEUI or high pressure oil systems that are used to fire off the injector instead of high pressure fuel. In the HEUI systems, there is a spool valve in the injector that gets varnish on it and it then you have striction.
As long as you use a good oil with good detergents in it, you should not have any issues.
I have a Powerstroke with the 6.0 that is fired off using high pressure oil. I like the system as it's reliable and the fuel quality doesn't need to be perfect like on the common rail diesels. I've alwaysed used Rotella T-6 with no longer than 5k oil changes...No striction ever.
/ Does anyone use fuel additives? #7
Kubota recommends not needing any fuel additives. However, I do use Power Service in the white bottle in the winter. I had fuel jelling in my previous tractor and it was a PITA.
/ Does anyone use fuel additives? #8
Ditto.
Many of the diesel sites and mags and stuff recommend it. The fuel needs it for the older systems they claim. The older cummins pumps go out all the time without the use of something for lubricity enhancement. Those guys are always talking about it and if you have an older one to add TWC oil so it does not burn out the pump as it will sooner or later without an additive.
/ Does anyone use fuel additives? #9
Is this a discussion about street legal fuel or what in this area is known as red or off road fuel or both ? My tractor runs a little different with the red, it will smoke a little with the red. I was told the red had more sulfur but do not honestly know. Always eager to learn so please enlighten me.
/ Does anyone use fuel additives? #10
Here there is no difference in the fuel whether it's marked or unmarked . The only difference is a small amount of dye is added to regular diesel.
/ Does anyone use fuel additives? #11
I thought that was nationwide now. Same fuel, red dye just indicates no road taxes included in (lower) price.
/ Does anyone use fuel additives? #12
I have owned diesel trucks and cars for 20 yrs. I use to use PS and moved away from it years ago because of other claims saying it had alcohol in it. Also these old diesels were meant to run on diesel fuel that had a higher sulfur content in it. Sulfur is the lubricant in diesel fuel. Off road diesel supposedly has more sulfur in it than regular diesel but I can not say for sure. Anyways these tractors would benefit from some kind of additive that includes lubrication, cetane boost is just a plus. I use Howes diesel treat in the winter for anti-gel and use Optilube year round. I mix the optilube with the Howes and FPPF in the winter and mix the optilube with FPPF in the summer for all my diesel motors. As california said, 2 stroke oil works good for a lubricant too. I have used that in the past. Her is a link Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums that discusses diesel fuel additives for lubrication. Read this and decide if you want to add anything to your fuel.
/ Does anyone use fuel additives? #13
I use a little Power Service but I saw a study somewhere that said adding a little bio diesel is actually better. That is if you can find it. I only add an ounce of PS to 5 Gal of regular on road diesel that I buy from the gas station pump. I don't use enough diesel to go through the aggravation of getting off road diesel. Still looking for a local source of biodiesel. If I find it I'll buy a gallon or so to replace the Power Service to add to the regular stuff. A little dab will do ya.
/ Does anyone use fuel additives? #14
Also Optilube has several other products, I'm not trying to sell anyone on this stuff but it really works and has made a huge difference in the motors I've put it in. Check out this new one the have dfi-agricultural
/ Does anyone use fuel additives? #15
Dickfoster you are right, bio-diesel is a great lubricant, but be careful with adding to much of it. Biodiesel is also a cleaner, if you use to much right away you can plug up your your fuel system. It will clean all the crap out of you lines from the Dino fuel and plug S__t up. Lol
/ Does anyone use fuel additives? #16
Unless your running like 5 + year old off road or live in one of those random places in america like 1% . 99% of us there is no difference in red or clear fuel except dye and dye does not cause smoke
/ Does anyone use fuel additives? #17
I only use some 2 cycle oil in the yanmar & my Ram 2500
/ Does anyone use fuel additives? #18
Is TWC a brand name... for two cycle oil?
/ Does anyone use fuel additives? #19
It's a boating industry spec and 'TC-W3' is a trademark that can be put on any brand of oil that passes a test.
TC-W3 Two-Stroke Oil Certification Program | NMMA
It stands for Two-Cycle Water Cooled (version 3) and is a different spec from chainsaw oil etc.
Google on 'tc-w3 oil' and you'll see boaters arguing over whether this is a universal sign of quality or just a minimum spec.
/ Does anyone use fuel additives? #20
Thanks for the clarification...
My old 1958 Evinrude 35 Lark is still running on quarts of two cycle oil from the 1950's... my Uncle got a deal on 12 cases of it... the can shows mowers, chainsaws, outboards...
At least I know the 55+ year old oil is what not to use.
I've been using a Deere TY26784 Summer Fuel Protect for Lubricity and Cetane... and have about 10 16oz bottles left with a 4oz to 52 gallon mix ratio.
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2018 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 PETERBILT 579...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
20ft Driveway Gates (A65579)
20ft Driveway...
