rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,234
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
41F and overcast ... high for the day predicted to be 66F with mostly cloudy skies, but with a little sun here and there.
Got a few things done yesterday:
Have oil filter and most of the oil for the o.c. on the Kubota, probably have to pick up an additional quart.
Probably just go ahead and pick up the complete seal kits for the bucket cylinders since the price seems fairly reasonable @ $50 per ...
Replaced the hydraulic hose on the grapple.
Found some angle that will work to protect the locking pins on the QA, didn't get it cut tho' ...
Ordered turn signal housing for The Woman's car ... about $40 with the shipping.
Didn't get Weather Pack connector installed ... did manage to do a little surgery on the bucket and pallet forks though:
RNG,
I did "fill the gap" on the pallet forks ...
What happens to a zip disc when it's spinning @ 10,000 rpm and it gets pinched (not good):
On today's menu:
1. Weather Pack connector
2. A little more research on bushings for bucket cylinders
3. See if I can find a good location for mounting the centrifuge filter on the Kubota. Not very likely but worth a shot.
4. Remove MMM, sharpen spare set of mower blades.
5. If sun ever comes out: rake leaves off topsoil I have piled up behind the polebarn and shove it over a little, so the trail is more open ... so's I can move brush to the south end of the property.
6. Clean up shop and put tools away.
7. Make calls/faxes to various authorities regarding Junior.
RNG,
On today's menu:
