Need help with my geometry
   / Need help with my geometry #51
Cannot be solved. Need another piece of info. Either the overall height of the trapezoid, Distance between parallels.....that is assuming they are parallel (another assumption), One of the angles, etc.
Assuming they are parallel, simply adding an angle makes it solvable:
Sin60=h/24 will give us the height of the trapezoid. which would be 20.78.
then you can either use the trapezoid formula [(base + top) / 2 ] x height.......(10+30)/2 = 20.......20*20.78 = 415.xx
Or you can break it into right triangles. cos60=x/24 would give the third leg to the triangle on the right. Which would be 12.
So knowing the height, you now know everything needed.
   / Need help with my geometry #52
At first glance, it appears that one can't solve it without knowing the angle between the 30 foot and the 24 foot side. Besides, it isn't drawn to scale in the illustration, so measuring the angle would be nothing more than a guess.
Whoops! You beat me to it.
   / Need help with my geometry #53
Difference in grading the base will change the volume way more than the decimal points you all are calculating this to...
I ordered 3 yards for a project, the guy showed up with 4 on the truck, and I still ended throwing two bags in the mixer to finish it off.
So if the OP thinks he needs 8cy, I'd be really tempted to just order a whole truck, whether that turns out to be 9 or 10 yards. For whatever reason, when I'm forming up for slabs and walkways, they never seem to turn out too shallow, always a little too deep.
   / Need help with my geometry #54
The source of the question made me trust the symmetrical appearance. If it had been from a test by a prof with history of messing with you, every answer would become an essay.
I am a member of several different forums. some with names that would seem to be much more logical to send a mathematical question to than a tractor forum. However, over the years, I have learned that TBN members have a vast amount of knowledge about any subject that you can comprehend, and I trust their answers more than those from any other forum I am a member of.
Hence, my reasoning for posting that question on this forum and my thanks to all who replied.
   / Need help with my geometry #56
Agreed. But the source of the question wasnt revealed until post #13.
Prior to that, I would not have answered the question without more detail. After it was revealed that it was for a driveway apron, one can reasonably assume that it is symmetrical and the base parallel to the top. Thus the answer becomes easy. 436.xxx
So far, Dieselcrawler, 2lanecruzer, prichard, trailsend, vin-mil, RobertBrown, INK, Smstoneypoint, westcliffe01, Redneckintraining, and myself all have arrived at the correct answer.
RalphinVA got 520 the first go around, then 318
JPRambo got 480
Dap olksjj got 420
RSKY got 476
kidr got 615.1 (though I think he was joking)
So the real question is.....do you guys understand where you went wrong. We all learn from our (and others) mistakes. This thread is a nice learning exercise:thumbsup:
   / Need help with my geometry #57
JPRambo got 480
Dap olksjj got 420
RSKY got 476
I too solved the problem. (the nerd in me could not resist), but there was not point in posting after so many gave the correct answer. I used to really love to work these things. I know, that is sad isn't it?:)
JPRambo got 480
Dap olksjj got 420
RSKY got 476
LD1, I just posted a fairly easy question (that I didn't know the answer to) without complete details of angles, exact lengths, etc. because I just needed to know how much concrete to order and I always order at least 1/2 a yard extra so I didn't need an exact answer and I did not supply exact details because I did not think it would really matter. Most people would assume that the top and bottom lines were parallel from my original drawing and give me a close enough answer for my question, which they did.
Now you say you did not answer earlier because you did not want to assume that the lines were parallel until I revealed that it was for a driveway apron and then you "assumed" that they were parallel.
Well, so much for assuming. :D They actually are not parallel and the 2 sides are different lengths though I did not disclose this earlier because I did not want to over-complicate the matter and I had another part also that was a rectangle of 8' X 10' that I was easily able to figure was 80 sq. ft. that I added on to your correct answers without disclosing.
Now if any of you wish to tell me the exact measurement of my apron from the enclosed drawing, with more details, and the amount of concrete I should order, adding 1/2 yard extra, to be safe, please do so. I will see how much it varies from the 10 1/2 yards I am planning to order. ;)
PS: The concrete is 6" thick.
   / Need help with my geometry #59
JPRambo got 480
Dap olksjj got 420
RSKY got 476
I viewed tallyho8 as the source and suspected no trickery. I regarded the way to solve it as the most important to him. As in #19 u just have to sort the lines correctly.
   / Need help with my geometry #60
Are those angles at the top = ... and what value ?
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
2021 Doyle 8 Ton Trailer Tender (A52128)
2021 Doyle 8 Ton...
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
2012 Jaguar XJ Sedan (A50324)
2012 Jaguar XJ...
