Pin Hole Too Big
/ Pin Hole Too Big #61
Messick's has a new swing frame for the BT820 listed for $762 dollars. If it was my machine, that is what I would do. I should have looked that up in the first place. Could have had it installed and good as new by now.
/ Pin Hole Too Big #62
No there's an idea that solves the problem once and for all, no cob job required. Inexpensive, no, fixed, yes.
/ Pin Hole Too Big #63
If you buy equipment anywhere, especially an auction, you are lucky if that wore out pin boss and rigged up wiring is all you find.
Alot of rental companies run stuff till their unskilled mechanics can't patch it anymore, then auction it off.
I have almost give up on renting stuff because of how crappy it is when you pick it up.
Some companies are way better-they usually rent cranes and bucket trucks.
The majority of equipment (and work vehicles) I have seen are treated with very little care. Run it till it stops, then patch together as quick as possible to continue making money.
/ Pin Hole Too Big #64
I can't even imagine spending $762 + shipping to do such a repair.
cut the old worn piece off, weld on a new one, Done!
but hey, It's your money.
/ Pin Hole Too Big #65
I would first pull the pins on both sides so I could compare them (and the holes)to see if its actually worn, or if its just an undersized pin...
Aaron Z
/ Pin Hole Too Big #66
Yes that is the necessary start to anything. Folks have offered lots of ideas from "cob" to Cadillac. Need to hear from OP and pix of the pins and holes.
/ Pin Hole Too Big
Attached are pictures of the washer freshly ground off along with a side-by-side of a new pin versus the one removed. Best guess is that the assembly has not seen a bit of grease since it was manufactured. Strangely, the other side is greased and is good as new.
I am one dang bolt away from removing the swingframe from the boom. Heat and cussing failed to convince it to yield so the just delivered slide hammer is about to be put to the test. This was after constructing a Rube Goldberg frame to prevent the boom/dipperstick/bucket assembly from falling over and creating a cart that would hold the mainframe and stabilizers so that they could be wheeled out of the way when disconnected. It is an interesting education. Turns out that I have a welder/machinist a couple of hills from here and once that final bolt is coerced out I will be delivering the swingframe and DOM tubing to him. Hopefully, the end is near.
/ Pin Hole Too Big #69
Was the washer ONLY welded to the pin? If so, I still maintain it is purley cosmetic.
If the washer were welded to the swing frame, or both, then I could see it as a temp solution to lessen slop.
But from the looks of it and where it wore, there looks to be little wear around the center of the pin where the cylinder hooks. And this is the only place that should need it. The pin is bolted in place and shouldnt rotate in the swing frame. So there shouldnt be much wear there? Other than the pounding it takes. Certainly an odd occurance
/ Pin Hole Too Big
The washer was welded only to the pin. Had I been smart enough to put a mirror to the bottom of the pin, I would have noticed that the bottom bracket was hanging by a thread to the pin and a tap with a chisel would have negated the need to grind. There was minimal wear on the pin where it mates with the cylinder hook, but while I have it all apart I intend to replace that bushing also. Does anyone know if that should simply knock out or do I need a hydraulic press to remove and replace?
/ Pin Hole Too Big #71
Sometimes they hammer out easily. Other times even a 20t press wont get it, you just have to try and see.
A die grinder der and smapp carbide bur to split the bushing makes them come out easy if all else fails
/ Pin Hole Too Big #72
Thx for the new pix. This is a real puzzle. How one side would be ok and the other side such a mess. And as LD1 says, what happened to make the pin start chewing up the swing frame, while the part of the pin in the cylinder rod end stayed more or less ok.
/ Pin Hole Too Big #73
I would say that the cylinder end was hard fasted to the pin. No rotation put all the force above andbelow that area, which had no grease so it wore out the hole in the swing arm which is softer than the pin.
/ Pin Hole Too Big #74
Yep. My guess would be that the grease zerk on the cylinder stopped taking grease and whoever did the service didn't notice, or didn't care until the pin fell out. Then they probbaly welded it back together a couple of times and eventually put the washer on top.
Aaron Z
/ Pin Hole Too Big #75
The way the pin is retained, it HAS to rotate withing the cylinder clevis. It CANNOT rotate within the swing post unless the bracket breaks.
Which is quite possibly what happened. THEN it would be allowed to spin in the swing post. Which wasn't bushed with hard material, because as designed...it isn't needed
/ Pin Hole Too Big #76
Was the paint fresh, or had they been running it like that for a while?
IMO, fresh paint on something at an auction is a red flag. If they had been running with the washer for a while, they probably put it on to get it back in service while they were getting a replacement in (or waiting till the next budget year to order a new one).
True, but if they have been using it like that for a time, they may not have considered it to be more than "normal wear and tear" for such a machine.
Aaron Z
Around here, we call that the Five Gallon Finish...lol
I've seen some 'pretty' units where the 'finisher' just painted over old grease and called it good. Some things (especially at auctions) amaze me. Some buyers amaze me as well.
/ Pin Hole Too Big #77
It was broke in the picture
/ Pin Hole Too Big #79
Yep. But could have have broke during removal.
In either case, once fixed and kept freely spinning with lube in the cylinder eye, the swing frame shouldn't wear at all
/ Pin Hole Too Big #80
Looking at the welds on the bottom of the worn pin, I would guess that it was re-welded several times.
Aaron Z
Cattle Feeder (A65640)
FIFTH WHEEL ATTACHMENT PLATE (A65643)
FIFTH WHEEL...
2022 FORD F-450XL FLATBED TRUCK (A64277)
2022 FORD F-450XL...
Kinze 3600 Wiring Harness (A65640)
Kinze 3600 Wiring...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2011 Western Star Tractor (A62679)
2011 Western Star...
